Question of the day... How would you flash this?
Ok, what would you do. I am finally getting started on this project, I had another post about flashing some cantilevered joist. Got that figured out, got some copper flashing all done up for the joist and the project has started.
I was not happy with the plans as drawn of going thru the brick veneer so I have taken off 4 courses of brick under the sliding glass door. The plan is to build out the section underneath with 2x12s allowing me to have 102 inches of direct connection with the Rim board of the house.
Haven't done many connected decks, and those I have done did not have this setup with the brick at a sliding glass door.
Current plan is to use flexwrap with duraflash. Flexwrap will be used under the duraflash in the door area. Both will go over the ledger. The area that is brick will have a typical z flashing into a cutout in the brick joints above and then over the ledger. This joint in the brick will then be back filled with silicone.
The attached pics are when the brick was still there. The brick will be gone replace with 3 2x12s stacked screwed and glued to give me depth needed to bring everything flush with the brick veneer.
