Fence Section On A Deck - Decks & Fencing - Contractor Talk
Old 05-30-2015, 05:03 PM   #1
Tom M's Avatar
Rewards Points: 11,280
Have a customer looking to use a fence section on one part of a deck for privacy. Other than a couple of DDT's not sure how I can combat wind and leverage.
Anyone ever do it?
Tom M is online now
Old 05-30-2015, 05:10 PM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,022
Re: Fence Section On A Deck
Yep with privacy glass.
Those panels are 63" if I remember right.
Calidecks is online now
Old 05-30-2015, 05:11 PM   #3
Creter's Avatar
Rewards Points: 1,966
Add a couple posts into the design or if it's already existing cut out/remove the deck board(s) drop you a couple posts - block and fasten, replace deck boards
Creter is offline
Old 05-30-2015, 05:13 PM   #4
GC/carpenter
Calidecks's Avatar
They drop down and bolt to the beam as well as the rim.
Old 05-30-2015, 05:13 PM   #5
Creter's Avatar
Mike, you do great work. I love when you post pics of your stuff. Top notch, man.
Creter is offline
The Following 2 Users Say Thank You to Creter For This Useful Post:
Calidecks (05-30-2015), Tom Struble (06-01-2015)
Old 05-30-2015, 05:17 PM   #6
GC/carpenter
Calidecks's Avatar
You can also bring your rail posts all the way down to a footing and Simpson bracket if you really need the strength to counter leverage.
parkers5150 (05-30-2015)
Old 05-30-2015, 08:28 PM   #7
Tom M's Avatar
That would be the way if the deck is a few feet of the ground. This guy's deck is second story. Unless I drop it down a couple of feet below the rim joist and bracket back to the underside of the deck. I can hide it with lattice maybe.
Tom M is online now
Old 05-30-2015, 08:47 PM   #8
Talking Head
EthanB's Avatar
Rewards Points: 438
Extra blocking should be able to pick up a lot of load. If it's on a end joist then block back 2-3 more joist bays in a line and that's a crazy amount of strength. Mark has posted some cool methods using threaded rod with nuts and washers if you want a cleaner look on the underside. For the ribbon joist, header, whatever you call it, full blocking and Simpson tension ties should be plenty of strength.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
Calidecks (05-31-2015), Tom M (05-30-2015)
Old 05-30-2015, 08:54 PM   #9
Tom M's Avatar
Your probably right. Im think a about 7:1 is a lot of bad leverage but in the end its more about the shear of the post which is plenty.
Tom M is online now
Old 05-31-2015, 09:38 PM   #10
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
we back block and bolted these, they are 72" tall
fence section on a deck-11263953_1438260323142258_2245931386773051750_n-1-.jpg   fence section on a deck-10917859_1406200949681529_893693576811645825_n-1-.jpg
killerdecks is offline
Old 05-31-2015, 09:42 PM   #11
GC/carpenter
Calidecks's Avatar
Here's a detail explaining what I mean by bolting your rail posts to your support beam. It picks up a lot of strength
CITY DECKS INC (06-07-2015), Tom M (06-01-2015), Tom Struble (06-01-2015)
Old 06-01-2015, 12:08 AM   #12
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Ethan mentioned the threaded rod technique, which I think works well.
I would carry the post down as far as you can and bolt through to whatever you can.
fence section on a deck-kern-final-8-red.jpg   fence section on a deck-geiger-progress-2-small.jpg   fence section on a deck-cable-rail-const-11-red.jpg
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following 4 Users Say Thank You to redwood For This Useful Post:
Calidecks (06-01-2015), CITY DECKS INC (06-07-2015), EthanB (06-01-2015), Tom M (06-01-2015)
Old 06-01-2015, 12:50 AM   #13
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
I think all the strength comes from the 2x6 laid flat, on the beam and nailed to the bottom of the 2x12 rim board
Old 06-07-2015, 10:35 AM   #14
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 4,780
I use louvered walls for blocking views. Here's an example.
Deckman
deckman22 is offline
The Following 4 Users Say Thank You to deckman22 For This Useful Post:
Calidecks (06-07-2015), CITY DECKS INC (06-07-2015), EthanB (06-07-2015), redwood (06-07-2015)
New hardwood deck over vinyl duradeck jonno38 General Discussion 3 04-27-2013 10:03 PM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Trex Deck damage ?'s Celtic General Discussion 15 11-02-2009 07:45 PM
Looking for Deck and Fence Builders in Toronto/GTA area SMC Help Wanted or Looking For Work 1 08-25-2008 06:38 PM
