Fasteners For Composite Decking - Decks & Fencing - Contractor Talk
Old 10-20-2012, 06:43 AM   #1
90%-er
onmywayup's Avatar
Rewards Points: 2,224
Thought I'd throw a quick question out to you full-time deck guys:
I have a customer who has asked me to re-attach some composite deck railing to a newly remodeled deck. It's only a couple of eight-foot sections and the deck is 2 feet off the ground (already pre-built railings, they were sections from the previous deck configuration).
If this were wood, I'd be using some counter-sunk heavy-duty lag bolts and washers.....but I'm wondering if there's anything different about re-securing composite? Or can I treat it just like wood in this case?
onmywayup is offline
Old 10-20-2012, 10:32 AM   #2
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Re: Fasteners For Composite Decking
most composite railing out there is sleeves that go over wood posts, so what is different?
killerdecks is offline
Old 10-20-2012, 11:05 AM   #3
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Composite railing is only a pt 4x4 with a composite sleeve that is slid over it.
Theres a few ways to do this
One way to do it is mount it on the outside or inside of the rim. through bolt the post through the rim with 1/2 bolts and the use of hold downs to a joist .
If attaching post to end joist you need to use blocking with a hold down, you must add another hold down to attach blocking to joist. If attaching posts to outside you can add an additonal rim board to hide the exposed posts.
Do not notch posts it makes them weak.
If i confused you heres an excellent article on the issue.
http://www.deckmagazine.com/anchors/...ail-posts.aspx
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
The Following User Says Thank You to Rich D. For This Useful Post:
onmywayup (10-21-2012)
Old 10-21-2012, 08:55 AM   #4
90%-er
onmywayup's Avatar
You partially lost me there, but the article was very helpful. Thanks.
Old 10-21-2012, 01:22 PM   #5
Repair & Renovation
Rich D.'s Avatar
I figured i would confuse you. Without visuals its hard.
That article is awesome, deffinitly add it to your favorites.
Rich D. is offline
Fiberon decking and fasteners edmontondecks Decks & Fencing 10 06-12-2011 09:46 AM
Decking Care kenhue design General Discussion 1 02-24-2010 08:31 AM
