Deck And Porch Framed - Decks & Fencing - Contractor Talk
Old 09-14-2012, 08:27 PM   #1
maleko's Avatar
Trade: carpentry
Rewards Points: 268
1000sqft screened porch is 16 x 19. Decking will be Mahogany with hidden faster system all post will be boxed out to look like columns painted white
I figure about 2 more weeks to go.
Mixed,100 bags of concrete for the footings. 16 total. Thank god I bought a mixer.
maleko is offline
The Following 6 Users Say Thank You to maleko For This Useful Post:
Andrew6127 (09-15-2012), BCConstruction (09-15-2012), Bone Saw (09-15-2012), BuiltByMAC (09-15-2012), deckman22 (09-15-2012), dkillianjr (09-14-2012)
Old 09-14-2012, 09:41 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Deck And Porch Framed
How does the roof flash under the siding?
Are your first rafters nailed through the siding?
CrpntrFrk is offline
Old 09-14-2012, 09:52 PM   #3
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
mixed by hand?
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 09-14-2012, 11:09 PM   #4
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
$375ish for those 100 bags, I could have had a truck deliver that much mud already mixed and my employees could have wheelbarrowed it in 30 mins, cost would have been about $300... saved $75 and a day of labor... I call a truck in for anything more than 30 bags.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
killerdecks (09-15-2012)
Old 09-14-2012, 11:13 PM   #5
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Any flashing where that covered porch runs into the house?
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
The Following User Says Thank You to Rich D. For This Useful Post:
CrpntrFrk (09-14-2012)
Old 09-15-2012, 12:28 AM   #6
Dirtywhiteboy's Avatar
Rewards Points: 10,114
SHhhhhhhh
Dirtywhiteboy is offline
Old 09-15-2012, 01:06 AM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,444
You don't drop your first step down from your deck, make the deck the top step? Or am I not seeing it right?
Calidecks is offline
Old 09-15-2012, 01:14 AM   #8
GC/carpenter
Calidecks's Avatar
Also what are your plans for stair railing? I noticed there aren't any posts.
Old 09-15-2012, 06:15 AM   #9
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
I get so much movement from the pt 4x4 rail posts while the decking goes on I cover them with white demo bags.
Not exposed to the Sun they seem to behave a lot better.
Nice Project.
J.
John Hyatt is offline
The Following User Says Thank You to John Hyatt For This Useful Post:
Calidecks (09-15-2012)
Old 09-15-2012, 07:06 AM   #10
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Nice Project.
J.
We quit decking around railing post 20 years ago, are you guys in the stone ages?
Frame, deck, rail, only way to go unless you have the rest of your life to build 1 project. Cut them rail post in after the decking is down, block the posts, rail. If the deck is low to the ground put your blocking in first, assuming that is you know how to use a tape, if you can't well than by all means put your rail post up before you deck, or better yet put the rail to the outside.
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
I Mester (09-15-2012)
Old 09-15-2012, 07:16 AM   #11
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
What makes cutting the deck boards after quicker than cutting them before? You got to cut the deck boards either way. I have tried putting in the post blocking before the post go in and that didn't go to good as not every post was the same dimensions and some were half inch bigger or smaller.
www.bcconstructionllc.com
BCConstruction is offline
Old 09-15-2012, 08:07 AM   #12
John Hyatt
John Hyatt's Avatar
It must be all in what a person is used to doing.
Installing the rail posts/blocking upside down from under-neath after the decking is fastened would defentley not be faster/better for my outfit.
Geting the titebond adhesive in alone would be a real pain.
J.
Old 09-15-2012, 08:35 AM   #13
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
you don't have to cut around the deck boards or make the deck boards fit around the post.
Frame your deck, deck it, cut the deck boards off @ the perimeter, with no cutting around the posts.
Take a 2x bolck find the inside of the floor joist, set your post on top of the marks drill and cut, slide the post in, it will look better than broyhill, basset and lane furniture.
If your lumber is that bad you should find another supplier
The Following 2 Users Say Thank You to killerdecks For This Useful Post:
Rich D. (09-15-2012), SmallTownGuy (09-15-2012)
Old 09-15-2012, 10:19 AM   #14
Trade: Construction
I can't picture what your explaining. If you don't cut the deck boards how do your posts come up through the deck boards without a hole?
Old 09-15-2012, 11:01 AM   #15
Repair & Renovation
Rich D.'s Avatar
This is what i do. Works good. No guess work.. i also add blocking in before. All my posts are the same dimension...
Rich D. is offline
Old 09-15-2012, 11:03 AM   #16
Repair & Renovation
Rich D.'s Avatar
He does cut a hole into the finished deck. Thats why he uses the 2x block to find the edge of the rim board. Then marks the post out and cuts it out and slide the post in.
Rich D. is offline
The Following 3 Users Say Thank You to Rich D. For This Useful Post:
BCConstruction (09-15-2012), killerdecks (09-15-2012), SmallTownGuy (09-15-2012)
Old 09-15-2012, 11:09 AM   #17
Repair & Renovation
Rich D.'s Avatar
In situations ive done that. I guess its an old school way to do it from balloon framing days.
Rich D. is offline
John Hyatt (09-15-2012)
Old 09-15-2012, 11:11 AM   #18
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
yea, save time make money, that's a new approach to deck building.
Old 09-15-2012, 11:15 AM   #19
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
Dropping the step down is another fine way that saves time and money, eliminates the need for another 4x4 at the top of the steps and a short rail section between the deck post and step post.
You hang your stairs from the 4x4 bolted to the frame and blocked and adding another 2x8 on the 4x4 under the frame. Than again you could always support simpson and buy one or two of their $10.00 brackets for the sake of a piece of scrap 2x8 which probably goes to the land fill anyway.
Old 09-15-2012, 11:38 AM   #20
Trade: Construction
Ok that makes sense now. Just couldn't picture how he was getting a post in without cutting the boards. I have seen people cut their holes from underneath after the blocking is in. I would do it like that but the material around here is dimensioned awful. One post wouldn't fit in another posts hole and I like being able to shim the posts square between the blocking before I tighten them up. Not sure how easy that would be after the decks down though.
t&g porch flooring vs. deck boards phnola Carpentry 3 11-17-2011 07:03 PM
Backyard walkway and deck from porch to pool tcleve4911 Carpentry Picture Post 19 10-10-2010 09:28 AM
Spec critique: screened porch floor stone, adjacent deck Trex UpNorth Decks & Fencing 0 01-21-2010 06:28 AM
Porcelain Tile Porch jbtn9 Flooring 1 09-22-2009 03:45 PM
building a screened porch atop a deck AustinDB Decks & Fencing 1 02-21-2007 10:29 PM
