Deck Joists Parallel Elevation To Beam - Acceptable Approach? - Decks & Fencing - Contractor Talk
Old 12-25-2018, 04:36 PM   #1
staticGenerator's Avatar
Trade: General
Rewards Points: 6
Iíve been solicited to build a low profile deck (as low as possible relative to ground level). My thought was to build the deck so that the joists and beam are at the same elevation to achieve this low profile deck. I considered an option to install 2x8 joists using joist hangers against the 2x8 (x2) beams (instead of resting them on top and across the beams). From there the 2x6 decking would be laid across both the beams and joists and secured using deck screws.
Iíve seen this method used in deck construction, but Iíve never seen as an approved or recommended design. There are no codes for decking where this will be installed. Iím new to decks, are there any concerns with this approach from a structural approach?
staticGenerator is offline
Old 12-25-2018, 05:13 PM   #2
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,622
Re: Deck Joists Parallel Elevation To Beam - Acceptable Approach?
Yep flush beam and joist hangers are totally an acceptable method assuming the rest of your deck meets local codes.
TheConstruct is offline
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
hdavis (12-25-2018), staticGenerator (12-25-2018)
Old 12-25-2018, 05:18 PM   #3
hdavis's Avatar
Rewards Points: 1,262
You just have to size the beam correctly. Hangers are fine.
hdavis is online now
greg24k (01-04-2019), staticGenerator (12-25-2018)
Old 12-25-2018, 05:58 PM   #4
Trade: General
Rewards Points: 6
Thanks, good to know. No deck codes here, but want quality a build either way.
Old 12-25-2018, 06:07 PM   #5
Trade: General
Rewards Points: 6
Yes, Iíve done all the calculations for post/beam/joist spacing.
I believe proper selection and attachment of joist hangers would be more critical in this type of construction.
Old 01-04-2019, 05:54 PM   #6
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
Yes it's fine. I do flush beams on low decks all the time.
Sent from my SM-G930W8 using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 2 Users Say Thank You to heavy_d For This Useful Post:
Calidecks (01-08-2019), TheConstruct (01-04-2019)
Old 01-08-2019, 07:09 PM   #7
blindtradesman's Avatar
Rewards Points: 8
My only concern would be the soil and the climate indigenous to where this deck is being built. Here in the Carolinas, with our warm temps and high humidity even top grade pressure treated lumber will rot too close to the ground due to moisture. It might be advisable to put in 4 to 6 inches of sand and gravel under the deck to make sure moister moves away.
America's Blind Tradesman
blindtradesman is offline
Old 01-08-2019, 10:12 PM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,094
A non issue with MM.
Mike.
_______________
Calidecks is online now
Old 01-09-2019, 10:32 AM   #9
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 452
Pour concrete.
ScipioAfricanus is online now
Deck joists in concrete block pockets and notched into steel beam Mr_Stop Decks & Fencing 17 01-13-2018 10:22 AM
Steel Deck Beam Steeling4Bucks Construction 19 01-02-2018 01:29 PM
Steel frame deck need engineered input rotarex Decks & Fencing 18 05-26-2013 10:54 PM
Joists Replacement While Maintaining Fire Escape Access? Lovegasoline General Discussion 17 11-19-2010 02:06 PM
Cantilevered beam in basement LetItBeLEED Framing 6 12-01-2009 10:56 PM
