Deck Design Question - Decks & Fencing - Contractor Talk
Old 10-01-2018, 05:16 PM   #1
DavidBarret223's Avatar
Ok guys, so im building a deck. The foot print is 30'x11'. The client wants to remove 2 of 5 existing columns on the end of the balcony, increasing the span from post to post on the one side (30ft side) to 15ft, center to center. The rim (its a second story balcony) is currently 2-2x12 with with 4 center beams (2- 2x12) and 2x8 joisting between beams. Can the 2x8 joisting be run at 15 ft lengths, beam to beam, if I eliminate 2x posts, upsize the existing posts (6x6 to 8x8), use WRC 4x12 for the rims, and WRC 4x12 beams? Ill attach drawings if I can fifure it out.
No, im not an engineer, the little muni I'm building this in doesn't require an engineers signature, just drawings apporved by the chief inspector.
Gimme feedback guys. Thanks.
DavidBarret223 is offline
Old 10-02-2018, 06:34 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,640
Re: Deck Design Question
All the weight that the 2 columns support, will be diverted onto remaining columns and you up the beams to 8x8 does the existing footing is wide enough designed to support that size column and the load?
Why not keep existing 6x6 posts and use 5 1/4 X 11 7/8" Prallam Plus to cover that span if your load is 40LL (if you have to meet 60LL even 14" might not work with a 15' span? Or better yet call someone who knows what they doing of get an engineer.
greg24k is online now
Old 10-02-2018, 07:53 AM   #3
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 7,464
Could also just use red iron I beam and wrap it.
He knows nothing about everything and isn't afraid to prove it, so he defends ignorance with stupidity.
Deckhead is online now
The Following User Says Thank You to Deckhead For This Useful Post:
greg24k (10-02-2018)
Old 10-02-2018, 07:58 AM   #4
Greg2k I do know that the red cedar 4 X 12 that I'm thinking of using to cover a 15 foot span from 8x8 to 8 x 8 is sufficient enough to handle the weight. The 30 foot span runs parallel to the house the 11 foot span runs perpendicular to the home. There are going to be three posts across both 30 foot spans, on either side. There will be 4 X 12 on the left and right edge, and a 4 x 12 down the middle, and two 4 X 12 across the front 30 foot span. In between the Forex twelves that run perpendicular to the home, I am anticipating using 2 by 8 on 16 Center. What I'm wondering is, most importantly, are the two by 8 sufficient size to run at 14ft 6in? Or should I upsize them to 2 by 10?
Old 10-02-2018, 08:09 AM   #5
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,648
You want 2x8s at a 14 foot span? Googling a simple span chart will show you that that's a big no.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
The Following 2 Users Say Thank You to heavy_d For This Useful Post:
deckman22 (10-07-2018), TNTSERVICES (10-02-2018)
Old 10-02-2018, 08:11 AM   #6
Heavy, I just looked that up, thanks. I appreciate your Reply.
Old 10-02-2018, 02:28 PM   #7
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Have you done the load calculations to make sure the existing footings will support the deck? (since you are removing some)
heavy_d is offline
Old 10-02-2018, 04:12 PM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 5,324
Not sure what the minimum requirements to be a GC is in your state, but these are basic questions a GC should know around here.
At least know where to get the load calcs.
Mike.
_______________
Californiadecks is offline
Old 10-02-2018, 05:16 PM   #9
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 230
Mike.
_______________
There are no min standards in my state and I know how to calc loads and find span charts.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 10-02-2018, 06:21 PM   #10
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,318
There is no license required to be a GC in the state of Texas.
They require a license for electrical and (I think) plumbing contractors.
Andy.
ScipioAfricanus is offline
Old 10-04-2018, 05:47 PM   #11
Mike.
_______________
Mike, I did the load calcs and submitted for review for the building inspector. Along with my drawings and ratings for the materials speced to be use, they were approved. Like i said, I'm not an engineer, but I can figure stuff out and I know where to ask if I have trouble with something. The span charts helped out in solving my joist with question, and the load bearing question about the footings was reviewed previously by an engineer who had written up an estimate for the removal of two posts a while back. Bit he didnt have the issue of the joist spacing and length in his paperwork. Just the removal of the 2 posts.
Old 10-04-2018, 10:48 PM   #12
Hair Splitter
Trade: General
Rewards Points: 230
Holy crap, 4 posts and he's calling you Mike.
The Following 4 Users Say Thank You to TNTSERVICES For This Useful Post:
Bull Trout (10-05-2018), Californiadecks (10-04-2018), griz (10-04-2018), sunkist (10-13-2018)
Old 10-07-2018, 12:24 PM   #13
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 7,734
Andy.
Mechanical also.
Out in the boonies where I live there are literally no inpsections. I did have to get a permit for the septic system but, it was never inspected.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 10-07-2018, 02:24 PM   #14
Tom M's Avatar
Rewards Points: 8,650
Beams are the easy part
The footprint of the remaining footings have to become bigger.
How does one do that below grade with not way to epoxy rebar into the existing?
Tom M is offline
Old 10-08-2018, 03:23 PM   #15
deckman22's Avatar
Trade: Deck Builder
Prop it up and make new footings.
Deckman
The Following User Says Thank You to deckman22 For This Useful Post:
Californiadecks (10-08-2018)
Old 10-13-2018, 03:13 PM   #16
Tom M's Avatar
I have a deck design question.
Any better solution to the two side by side deck posts at the top of a landing? A returned upper rail to the adjacent post would look better but the finish material is composite. Maybe Radiance Rail
Tom M is offline
Old 10-13-2018, 03:16 PM   #17
GC/carpenter
Mike.
_______________
The Following 2 Users Say Thank You to Californiadecks For This Useful Post:
Rio (10-13-2018), Tom M (10-13-2018)
Old 10-13-2018, 03:25 PM   #18
Tom M's Avatar
Hmmm so you added another soldier for aesthetics.
Tom M is offline
Old 10-13-2018, 05:50 PM   #19
GC/carpenter
Both sides I thought it looked better. I could've designed it differently.
Mike.
_______________
Old 10-13-2018, 06:23 PM   #20
Tom M's Avatar
Gotta plan at least a 5ft step then.
Tom M is offline
Californiadecks (10-13-2018)
deck coating question BThomas Painting & Finish Work 4 03-04-2014 11:51 AM
deck coating question BThomas Decks & Fencing 12 02-26-2014 07:23 AM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Log cabin deck design KennMacMoragh Architecture & Design 14 03-20-2011 08:01 PM
