Deck With Built-in Benches & Gazebo - Decks & Fencing - Contractor Talk
Old 08-11-2015, 12:23 AM   #1
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Pretty gazebo (20 years old or so) but very crowded under it, not much room to do anything there besides admire the backyard.
Demo day almost got reeeeaaaaaal interesting... As you can see, she has a very full backyard - not much room other than on the old deck. Chopped the posts intending to drop the gazebo on the deck to cut it apart. Damn thing tucked and rolled towards the house! Had to grab the the posts to stop the roll.
On these smaller staircases, I'll build the stringers in pairs. It helps keep them from getting squirrelly and makes the whole staircase more stable.
The angled section was not my best effort. Decided to just block the hell out of it to make it strong. I missed the angle somehow so my tread/riser cuts were climbing off the stringer.
Made sure my roof beams were all the same size to the structure would be perfectly square.
Been a while since I've cut a roof..was a bit rusty figuring my compound miters! Needed to be clean with my connections, no soffit going on this.
Made the apex block out of a 4x8 beam cut-off - cut it down to 3 1/2" square, then ripped chamfered edges so all 8 main rafters would have a solid connection to it.
Built-in benches wrap around the gazebo posts
BuiltByMAC is offline
The Following 10 Users Say Thank You to BuiltByMAC For This Useful Post:
Calidecks (08-11-2015), CITY DECKS INC (08-12-2015), EthanB (08-12-2015), hdavis (08-11-2015), JAH (08-14-2015), Jeff1984 (08-11-2015), jlhaslip (08-11-2015), Timuhler (08-16-2015), Tom M (08-14-2015), Xtrememtnbiker (08-11-2015)
Old 08-11-2015, 12:28 AM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
Re: Deck With Built-in Benches & Gazebo
I like watching your builds unfold. I use a lot of your same methods. Nice work as usual Mac.
Calidecks is offline
BuiltByMAC (08-11-2015)
Old 08-11-2015, 12:31 AM   #3
BuiltByMAC's Avatar
Trade: Deck guy
Roof was fairly wobbly even with dropping the posts into the ground and stiffening them with the deck framing and bench structure. Too many screws to be visible so I sandwiched the knee braces. Pretty one only got 4 screws (which will be caulked and painted), hid the 10 screws between the pair.
Still need to wrap the bench posts tomorrow but she's about done.
Nipped the corner so they wouldn't catch their knees on the 90 point.
The Following 8 Users Say Thank You to BuiltByMAC For This Useful Post:
asevereid (08-11-2015), Calidecks (08-11-2015), CITY DECKS INC (08-12-2015), EthanB (08-12-2015), ghhartmann (08-11-2015), greg24k (08-17-2015), hdavis (08-11-2015), SelectDecks (08-11-2015)
Old 08-11-2015, 08:09 AM   #4
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Nice work man, check out the cortex plugs for those benches - I think you would like how they look on the finished product. I'm stealing your clipped edge idea on the bench corner, sweet little detail
James
www.selectdecks.com
SelectDecks is offline
The Following 2 Users Say Thank You to SelectDecks For This Useful Post:
ghhartmann (08-11-2015), Timuhler (08-16-2015)
Old 08-11-2015, 04:28 PM   #5
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
I like the work Mac.
The total look, not so much.
J
John Hyatt is offline
Old 08-11-2015, 05:12 PM   #6
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
How are you attaching the rafters?
TG Deck is offline
Old 08-11-2015, 05:34 PM   #7
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,464
Last time I did a Gazebo was 18 years ago (commercial job). It must have ben 30' wide with an octagon exterior and a square plexiglass dome at the top. There were four flats on a 6/12 pitch and 4 pies on an 8/12 pitch. 1x4 T/G decking with purlins for a standing seam roof, couldn't show any missed fasteners from underneath. What a pain... All in all your project brought back memories! Looks good! Typing this reminded me we threw a guy in the pool, that was next to us, for his birthday. Good times
Builders Inc. is offline
Old 08-12-2015, 09:41 PM   #8
BuiltByMAC's Avatar
Trade: Deck guy
TimberLoks down into beam
Old 08-13-2015, 08:49 PM   #9
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
why no pitch
killerdecks is offline
Old 08-13-2015, 09:39 PM   #10
BuiltByMAC's Avatar
Trade: Deck guy
2/12. Shallow, but it's there. HOs wanted a low pitch. If it was a flat roof, I wouldn't have bothered with all the jack rafters.
The Following User Says Thank You to BuiltByMAC For This Useful Post:
Calidecks (08-13-2015)
Old 08-13-2015, 09:49 PM   #11
FrankSmith's Avatar
Rewards Points: 5,124
All I can see is the one post under the bench that is still raw. It is somehow visible in almost every picture.
FrankSmith is offline
Old 08-14-2015, 12:11 AM   #12
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
I thought anything under a 4/12 required roll roofing or 1/2 lap
Old 08-14-2015, 12:14 AM   #13
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
That roof ain't going to leak. You can nail them high and double the felt. But I don't think it would leak anyway.
parkers5150 (08-14-2015)
Old 08-14-2015, 12:15 AM   #14
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
We use comp on 3/12 all the time.
Old 08-14-2015, 06:58 AM   #15
deck aficionado
Rewards Points: 973
Metal not big out there? Use it on 1 and 2/12 a lot
James
www.selectdecks.com
Old 08-14-2015, 07:24 AM   #16
BuiltByMAC's Avatar
Trade: Deck guy
Take just a second and a half and read the text above that pic. Since I post up progress pics throughout my builds, I don't always have everything complete. The bench post wrap was the last thing I needed to do. As I stated.
I throw the watermark on any pic that's mostly finished. Someone who's willing to steal images online to post as their own is probably the type of guy to leave one post unwrapped on their project!
When I go to build something I'm not super familiar with, I read the installation instructions. I'm not a roofer so I double check what I'm doing so my build will be warrantied. 2/12 is the minimum for shingles (at least the brand I purchased) as long as the roof is covered with two layers of 15# tar paper. On this build, I ran out of ridge shingles based on the counter lady's recommendation for coverage. Installation calls for doubling the ridge shingles. I went back to buy more and no one there had heard of that. They all just use a single layer of ridge shingles. Great, fine, but installation instructions on the freakin' package call for doubling.
Sure, we use metal. Just not on this project, HOs didn't want a metal roof on their gazebo.
Calidecks (08-14-2015)
Old 08-14-2015, 09:43 AM   #17
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Nice job Mac. Still not much room under the gazebo, but at least you can sit down.
I've done a few gazebo's and the low pitch just doesn't seem right. But the clients are the boss in the end.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 08-14-2015, 12:51 PM   #18
John Hyatt
John Hyatt's Avatar
What Mark said.
A Man builds what the Wallet wants . The project would look better with more pitch and a metal roof but we don't get paid doing what We think. The way it rains in Portland the more protection the better but O WELL.
I am very hesitant to post up pictures after a major lumber supplier stole one and put it on a brochure / their web page. It's not worth the fight so I lived and learned.
J.
Old 08-14-2015, 05:45 PM   #19
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
the price difference tween a 2 and a 4 on such a small roof might be $100
Old 08-14-2015, 06:01 PM   #20
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
amen to that. we just have to make sure it lasting quality good looking finished product. i tell them all the time.. i'm just passing through you'll be living with it.
CITY DECKS INC is offline
Steel frame deck need engineered input rotarex Decks & Fencing 18 05-26-2013 10:54 PM
12" jointer- shop built PrestigeR&D Tools & Equipment 6 03-20-2013 02:21 PM
Summer deck projects C2projects Decks & Fencing 149 01-16-2013 12:24 AM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
