Deck Board Gapping - Decks & Fencing - Contractor Talk
Deck Board Gapping
Old 01-25-2012, 07:31 PM   #1
timfratar's Avatar
Deck Board Gapping
When deck was built two years ago I snugged up each board to the other expecting the boards to dry out and leave a nice little gap. That did not happen. Anyone have experience ripping a larger gap with boards in place.
timfratar is offline
Old 01-25-2012, 07:34 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Deck Board Gapping
I think it will be easier to remove and reinstall the boards. The alternative is to attach straight edges and run the roundover down each joint finishing the ends by hand.. Why all the sudden the issue, give it until this spring...
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
timfratar (01-25-2012)
Old 01-25-2012, 07:35 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 478
Why would you want to?
Tinstaafl is offline
PA woodbutcher (02-01-2012)
Old 01-25-2012, 07:37 PM   #4
jb4211's Avatar
Rewards Points: 2,306
If that's possible, it wouldn't be easy. Ripping a gap, easy. Easing the edge (rounded over) not so easy with boards in place. If you don't care about the sharp corner left by cutting, why not just screw down a straight edge and run the saw down the joint?
Jon
jb4211 is offline
Old 01-25-2012, 07:38 PM   #5
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
put two blades on your skillsaw and have at it
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
Metro M & L (01-25-2012)
Old 01-25-2012, 07:42 PM   #6
He probably told the ho that they would shrink nicely, now the puddles are becoming skating rinks...
Old 01-25-2012, 07:43 PM   #7
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 42
What was it decked with?
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 01-25-2012, 07:44 PM   #8
Since the boards were supposed to dry out we can assume pt wood.
Old 01-25-2012, 07:46 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 478
If the boards were wet when installed, they had to shrink after drying, even if only a little. There wouldn't be any puddles lying on them.
I've never had a HO question NO gaps.
Old 01-25-2012, 07:46 PM   #10
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
I use fir alot here and it shrinks after a year, I still gap a pencill though
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 01-25-2012, 07:49 PM   #11
You would think but then why is he in this pickle? No gaps is usually the goal great point!
Old 01-25-2012, 07:51 PM   #12
Sawdust Sweeper
Rewards Points: 42
I would think that if it was PT it would have shrunk some. I will always gap an 1/8" minimum no matter what. Some of that PT decking can come in pretty soggy
Old 01-25-2012, 07:52 PM   #13
jb4211's Avatar
That seems like a pretty big gap to start: probably a 1/4", then add shrinkage. Seems big, like swallow a high heel big.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
boman47k (02-01-2012)
Old 01-25-2012, 07:54 PM   #14
Last summer it seemed our pt boards were all straight out the river. We installed them butting and they all dried out nice. Had one where we had to replace a couple boards before staining but most of it was perfect. Maybe the op will return..
Old 01-25-2012, 07:55 PM   #15
jb4211's Avatar
With P/T wood, I never gap, I always install tight. Then they shrink and a small gap is left.
With composite, I use a regular, common 16d nail on ever joist. Nail the new deck board, place nails on the other side, repeat till done. I was going to buy deck spacers, but for the cost of one space I bought a whole box of nails.
Jon
jb4211 is offline
Old 01-25-2012, 07:56 PM   #16
Gen. Contractor
That's just what everyone seems to do, I ran into a few guys that slam em tight. Maybe it's cause there is so much moisture here, they don't realy shrink.
Old 01-25-2012, 07:57 PM   #17
The composite we installed this year had the spacing built into the clips. What a PITA but it looked nice
Old 01-25-2012, 08:19 PM   #18
Italian75's Avatar
Rewards Points: 87
rip them up and put down composite. And then no problem.
Italian75 is offline
Old 01-25-2012, 08:33 PM   #19
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
a ts-55 track saw would work nice in this instance.
i wouldnt imagine you would need too much space cut in, a blade width should be fine.
i also would like to know why this is a problem
CK Carpentry
chris klee is offline
Old 01-25-2012, 09:44 PM   #20
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Never thought about putting two blades on a skilsaw. I'm sure that'll come in handy sometime!
Metro M & L is offline
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
Winter Deck in Montral mat casters General Discussion 3 10-19-2009 06:19 PM
Deck Staining & Sealing Problem Acer1 Painting & Finish Work 1 08-28-2009 09:12 PM
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 10:59 PM
