Deck Around Tree? - Decks & Fencing - Contractor Talk
Deck Around Tree?
Old 12-08-2014, 06:51 PM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Deck Around Tree?
Never done a deck around a large tree before but have this once coming up. is there any advice as to what to do around the tree as in the amount of gap between tree and deck boards as an example or any code issues i may open up doing this?
www.bcconstructionllc.com
BCConstruction is offline
Old 12-08-2014, 07:03 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,008
Re: Deck Around Tree?
I haven't done one either, but the most obvious thing I think an inspector would look at is the potential for someone to get a foot/leg jammed in the gap. You could probably bulletproof that with a railing (plus allow more gap for future growth), but doing it aesthetically might be a bit tough.
I want to see pics when you're done.
Tinstaafl is online now
BCConstruction (12-08-2014)
Old 12-08-2014, 07:14 PM   #3
Trade: Construction
The rail around the tree is a great idea. Didn't even consider that.
Old 12-08-2014, 07:19 PM   #4
Windwash
Windwash's Avatar
Rewards Points: 150
My thoughts when reading this are how big of a tree and what type? A medium cottonwood might get a foot bigger in a few years but an oak may take much longer to gain much diameter. Haven't done this before but I would header it off 18" in all directions and do sacrificial infill framing to within 8", decking to within 4".
Windwash is offline
The Following 2 Users Say Thank You to Windwash For This Useful Post:
BCConstruction (12-08-2014), concretemasonry (12-09-2014)
Old 12-08-2014, 07:38 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 10,386
I was thinking of some type of removable framing and decking as the tree grows too.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Old 12-08-2014, 07:43 PM   #6
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
you second that,
I'll 2nd your 2nd.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
The Following User Says Thank You to jaydee For This Useful Post:
Old 12-08-2014, 07:45 PM   #7
Trade: Construction
Originally Posted by jaydee View Post
you second that,
I'll 2nd your 2nd.
No idea what type the trees are. Shouldn't be hard to find out though but the removable framing is a great idea too.
Old 12-08-2014, 07:45 PM   #8
I'm The BOSS
jaydee's Avatar
maybe frame the hole octagonal ,
that way you can get the decking closer to the tree
Facebook
jaydee is offline
Old 12-08-2014, 07:58 PM   #9
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
Never done it either but I had thought the same idea of a well-done header a bit back that should never need to be touched. Then joists/blocking that are more removable. Such as the A35 connectors or something like that installed with screws instead of nails.
Xtrememtnbiker is offline
Old 12-08-2014, 08:02 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Removable framing is a great concept, but face it, no one is going to get around to removing it until the tree is tight up against it. At which point, how do you get it loose?
Old 12-08-2014, 08:07 PM   #11
Rewards Points: 342
The way I have in mind would be removed from underneath even if the tree was touching it. That being said, we see plenty of stuff HO's are supposed to keep up with but don't so I agree with you.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Tinstaafl (12-08-2014)
Old 12-08-2014, 08:19 PM   #12
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
No biggie. just keep it the framing about 5-6" away from tree for future growth and float the deck boards with in 3-4" of tree. The decking could cut back in 10years. Mac has a done quite a few I did all in all 3-4 I gotta look deeper into in to my picts.
CITY DECKS INC is offline
Old 12-08-2014, 08:20 PM   #13
no rail.... maybe a small seat wrapped around the tree.
Old 12-08-2014, 08:26 PM   #14
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
My concerns would be digging the post in ... hitting roots, killing the tree, .. you know
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 12-08-2014, 08:35 PM   #15
Texas Wax's Avatar
Rewards Points: 2,170
Yup
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
CITY DECKS INC (12-08-2014)
Old 12-08-2014, 08:39 PM   #16
I found a cpl. I know have the framing and at least 2 or 3 more others.
don't know how they got that way but yo get the idea.
Old 12-08-2014, 08:40 PM   #17
Talking Head
EthanB's Avatar
Rewards Points: 438
Just brainstorming but you could tighten up the gap around the tree by building a float ring to go on top of the decking with some spacers under it to allow drying. Hold the decking back 4" and the ring 1.5" so that little feet don't end up in it. The BO around here is really picky about that.
I think you could make a ring or polygon around the tree and have it be two pieces connected by a couple pieces of EPDM or bungie so that it would spread when the tree finally got to big.
It all depends on budget of course. You can always just run the decking to within a couple inches of the tree and remind the HO that they'll have to cut it back before it gets snug. I typically hold back hardwood deck framing 6" for hot tubs and there's no noticeable deflection so I wouldn't worry about making the joists removable.
Planer.....
EthanB is offline
Old 12-08-2014, 09:13 PM   #18
Box Builder
You can make the main framing whatever shape you want and temp framing run it as needed depending on trunk shape. I would either make the cut out circular or actually scribe it to the tree shape.
Old 12-09-2014, 07:30 AM   #19
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
If you go to my site, www.deckmastersllc.com , third row from the bottom under Showcase. A very cool tree we went around.
I put a half round rail on with alum balusters. I used a plywood template to get the curve right. The top,bottom and cap rail cut out of a glued up Ipe 3/4.
J.
John Hyatt is offline
Old 12-09-2014, 08:08 AM   #20
J.
J. just toured your site. Nice stuff buddy. Very nice
The Following User Says Thank You to CITY DECKS INC For This Useful Post:
John Hyatt (12-09-2014)
Summer deck projects C2projects Decks & Fencing 149 01-16-2013 12:24 AM
Roof top Deck issue mandaloril Decks & Fencing 22 04-24-2012 10:19 PM
