Cutting A Positive Arch In A Wood Fence - Page 2 - Decks & Fencing - Contractor Talk
Old 04-25-2011, 09:33 PM   #21
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Cutting A Positive Arch In A Wood Fence
Originally Posted by SAW.co View Post
How do you cut an arch with one of these?
I could post pics of hundreds of arcs cut with a Skil wormdrive and a 20 tooth framing blade, but if you want to be a bit more precise, try one of these...
http://www.arcusblade.com/woodsystem.html
loneframer is offline
Old 04-25-2011, 09:37 PM   #22
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 429
Riz:
Have you used those before? I was wondering about the cost and availability. The old 20 tooth framing blade will generally only do about a five foot radius. Anything tighter than that and we have to go with the jigsaw. Would be nice to have a better option for a few select jobs.
Warren is online now
Old 04-25-2011, 09:44 PM   #23
KemoSabe
loneframer's Avatar
Originally Posted by Warren View Post
Riz:
I've never tried them myself. I don't think they make one with a diamond arbor and I ain't giving up the wormy.
With framing work, on tight radii, I'll do more than one pass to hog out the material more efficiently.
If I have the space though, I'll set up a trammel for the router and a straight cut bit. Locate the centermark, drill in a pin, perfect circle.
Old 04-25-2011, 09:45 PM   #24
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
I've never seen that before.Way cool
I'm just a simple boy. Mark with string, jig saw cut & kiss it with a belt sander.
I'ts the only way I know...
SAW.co is offline
Old 04-25-2011, 09:47 PM   #25
KemoSabe
loneframer's Avatar
My favorite way...
One piece trim for a half circle
Cutting a positive arch in a wood fence-006-copy-2-.jpg   Cutting a positive arch in a wood fence-003-copy-6-.jpg
Old 04-25-2011, 11:59 PM   #26
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
stihl ms170
jlsconstruction is offline
Old 04-26-2011, 12:56 AM   #27
Fence's Avatar
Trade: Fences
Rewards Points: 75
Originally Posted by jlsconstruction View Post
stihl ms170
and it leaves a fine quality finish?
Deck Builder In Oakville
Fence is offline
Old 04-26-2011, 01:05 AM   #28
stacker of sticks
Rewards Points: 590
depends on the operator
but tbo i use it more then i use my saws all
Old 04-26-2011, 01:06 AM   #29
stacker of sticks
Rewards Points: 590
but my honest answer would be to use a router
Old 05-22-2011, 05:11 PM   #30
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
I use a beaver.
smalpierre is offline
Old 05-22-2011, 05:27 PM   #31
Dirtywhiteboy's Avatar
Rewards Points: 11,720
Originally Posted by smalpierre View Post
I use a beaver.
keep the beaver well lubed
Dirtywhiteboy is offline
John Hyatt (06-09-2011)
Old 06-04-2011, 11:40 AM   #32
bcf's Avatar
Trade: Fence Contractor
Rewards Points: 75
Fiberglass tension bar and a circ. I've used a chainsaw before, with a fresh blade and scoring works ok.
Matt Ehrenzeller
bcf is offline
Old 06-09-2011, 05:43 PM   #33
Amoore84's Avatar
One of the best ways to cut an arch in any material is to use router attached to a 1x4 or piece of plywood with a strait cut bit. Basically you would mimic the idea of a string tied around a nail with a pencil at the end, only you would be cutting not marking. One way to do this is to take a 1x4 for example and drill a hole in it towards the end of the piece. Make sure when you drill you stay in the center of the 1x4(1-3/4inches). The hole will need to be large enough for a straight cut router bit. You will then mount your router to the 1x4 with the bit penetrating through the hole you just drilled. Make sure again to mount your router as close to center as possible, this will help for an accurate cut. So by now you should have a router mounted to a 1x4, lets call it 8 feet long, with a straight cut bit. You will find that you will need a long bit, as you will be using 3/4 of its length for the jig, plus the depth it goes past the base into the router, plus the depth of the material you will be cutting. You will then flip the 1x4 over and measure from either the near side of the bit or the far side of the bit to the radius of your arch. keep in mind if you are cutting the bottom of the arch you will want to measure from the farside of the bit, so your tearout will be on the waste. for a 8 foot diameter, obviously 4 feet from the farside of the bit and so on. I recommend using a nail on the other end as a screw tends to move the piece slightly. hope this helps.
www.constructionplusmoore.com
Amoore84 is offline
Old 06-11-2011, 10:49 PM   #34
jamesonthornton's Avatar
I have cut an arch in two ways on a wood fence gate. One is one person bend a 1 x 2 board to the desired arc size while a helper marks the board in place. Then, you cut the mark with a jigsaw and sand the top if needed.
Two is to put a nail in center of gate and reference with a string tied to the nail and a pencil tied to the other end to mark the top of the gate in a arc. Check out quality fence at http://www.choosepatriot.com
jamesonthornton is offline
Old 06-16-2011, 09:24 PM   #35
koolj156's Avatar
Trade: Fences
piece of 1/2 in pvc, tack nails in at the sides and center and place pvc to create arch, pencil in. Set depth to 1/2 inch past board depth and cut on line with a circular saw.
koolj156 is offline
Old 06-16-2011, 09:26 PM   #36
koolj156's Avatar
Trade: Fences
10 foot fiberglass tension bar works great too
koolj156 is offline
Cutting Small Parts (without cutting any of your parts) basswood Finish Carpentry 17 05-27-2010 09:15 PM
cutting a solid wood interior door to match angle of roof AustinDB Finish Carpentry 5 02-18-2010 08:40 AM
Wood Fence using Chinese Fir AKA Import Cedar Cascade Fence Decks & Fencing 4 11-02-2009 09:05 AM
concrete inside vinyl fence post? pjwinstalls Decks & Fencing 3 07-17-2009 01:36 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
