Cedar Rot Question - Decks & Fencing - Contractor Talk
Cedar Rot Question
Old 04-04-2013, 11:47 PM   #1
Gbrogden's Avatar
Trade: Finish Carpentry/Cabinets
Rewards Points: 25
Cedar Rot Question
We are currently installing cedar skirting on a mobile home. We are using 1x6 cedar fence planks. They are being attached to existing 3/4" PT ply with stainless nails. There is a pvc 1x2 trim between the top of the cedar and the bottom run of vinyl siding. The cedar is cut tight to the bottom of the pvc 1x2. The h/o is going to paint the pvc and apply Sikkens something-or-other to the cedar at a later date.
A local handyman (who has a bit of a reputation for stirring chit) contacted the homeowner today and informed him that we were doing the job wrong. He said that there has to be some form of dripedge over the top of the cedar or else it will stain and/or rot away very quickly. Needless to say, the homeowner is beside himself.
I have very limited experience working with cedar. Don't really know much about it, other than this guy's yard smells like a hamster factory now. Do we need to yank the 1x2 off and put on some z-flashing or will it be fine?
I will try to grab a pic in the AM in case my description isn't clear.
Gbrogden is offline
Old 04-04-2013, 11:58 PM   #2
bmcquin's Avatar
Trade: deck builder
Rewards Points: 1,646
Re: Cedar Rot Question
The ends of cedar are like a sponge, especially when jammed up tight to something with no room for air circulation.......
bmcquin is offline
The Following User Says Thank You to bmcquin For This Useful Post:
Chris G (04-05-2013)
Old 04-05-2013, 12:15 AM   #3
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 11,486
First, find the handyman and and let him know what he did was not professional and you wont tolerate it again. He should have came to you as a man and confronted his opinion of how things should be built.
Now onto the cedar. I would cap it if it was me but likely it wont matter. Anytime I hear the words mobile home, I think of string trimmers and s**tty looking skirting anyway.
Cole is offline
The Following 2 Users Say Thank You to Cole For This Useful Post:
dkillianjr (04-05-2013), John Hyatt (04-05-2013)
Old 04-05-2013, 12:16 AM   #4
Gbrogden's Avatar
Rewards Points: 25
I didn't know that. All I've ever heard about cedar is how rot resistant it is as long as you keep it out of ground contact.
Gbrogden is offline
Old 04-05-2013, 01:12 AM   #5
Dirtywhiteboy's Avatar
Rewards Points: 14,596
Last week I pulled off a lot of 2X12 belly ban ceder and 2X6 corner trim ceder, had a lot of rot going on and termite damage.
Dirtywhiteboy is online now
Old 04-05-2013, 05:20 AM   #6
Big Shoe's Avatar
Rewards Points: 2,110
Gbrogden........Are you associated with Ikea. That name looks familiar, Its on all their assembly instruction books
Pics would be nice. But how about a bead of clear caulk where the cedar buts up to the pvc 1x2 ?
You don't want any trapped water behind cedar.
Good luck
Expect the Unexpected
Big Shoe is offline
Old 04-05-2013, 06:41 AM   #7
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I'd slip a z in between... anyway, the bottom will probably rot out first
-Steve
TimelessQuality is offline
Old 04-05-2013, 07:07 AM   #8
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
I trim more with cedar than more than any other material (except PVC). I'm not sure of the grade of the cedar you're using, but since they are fencing planks I'm assuming is a lesser grade and more prone to rot (??? --- I could be totally wrong here).
Western Red Cedar has much higher "natural preservatives" than Eastern White Cedar and therefore more rot resistant. The heartwood has the most rot resistance, while the sapwood has the least.
I would remove the board, treat the back side and endgrains, flash with a drip edge and re-install. D-U-N.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 04-05-2013, 07:19 AM   #9
B.Scott's Avatar
Rewards Points: 296
I think it depends on the 1 by 2 on Top.
If the 1 by 2 is "on the flat" and the cedar is butted to it's EDGE then yes it should have drip edge.
If the 1 by 2 is on it's edge and pitched like a small window sill then just butt the skirt under is the way I'd do it. Like a water table detail we do around here.
B.Scott is offline
Old 04-05-2013, 10:23 AM   #10
Gbrogden's Avatar
Rewards Points: 25
Didn't get a chance to take a pic of the actual job but here's a pic of an identical setup:
The only difference is the planks and the 1x2 in this pic are pt.
The cedar is a cheap grade the homeowner got from Lowes or Home Depot. I guess the safest bet is to tear off the trim and put in a z flashing. I'm not too worried about the bottom of the planks because they are sitting on top of gravel, not dirt.
Gbrogden is offline
The Following User Says Thank You to Gbrogden For This Useful Post:
CENTERLINE MV (04-05-2013)
Old 08-28-2013, 04:06 PM   #11
Marven's Avatar
Trade: Accountant/Builder
Rewards Points: 165
oops
Marven is offline
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Cedar prep Tom M Painting & Finish Work 0 12-30-2012 12:00 PM
Cedar shingles below grade - how to correct zing Windows, Siding and Doors 9 07-08-2012 07:30 AM
