Cable Rail Options - Decks & Fencing - Contractor Talk
Cable Rail Options
Old 01-23-2019, 01:19 PM   #1
Dan_Watson's Avatar
Rewards Points: 2,748
Cable Rail Options
I am looking for a cable rail that can be used on a coastal project and has the least amount of posts possible, IE longest span between. Also looking for narrow posts, ~2", and if there is a system that does not require a large top rail.
Dan_Watson is offline
Old 01-23-2019, 01:26 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Cable Rail Options
check these out, both are pretty high quality:
mike may know of more.
https://www.atlantisrail.com/?gclid=...EaAlPIEALw_wcB
http://www.feeneyinc.com/CableRail?u...et=1&rl_frag=#
griz is online now
Old 01-23-2019, 03:24 PM   #3
MarkJames's Avatar
Rewards Points: 16
This looks cool.
https://www.viewrail.com/
MarkJames is offline
Patrickstew (01-29-2019)
Old 01-24-2019, 12:34 AM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 80
Here's what I'm working on now. These rails still need tensioned is why the cables are still sagging. Feeney cables are an excellent choice, imo.
Mike.
_______________
Calidecks is online now
griz (01-24-2019), Idothat (01-24-2019), rblakes1 (01-24-2019)
Old 01-24-2019, 12:35 AM   #5
GC/carpenter
Calidecks's Avatar
Rewards Points: 80
Mike.
_______________
Old 01-24-2019, 05:22 PM   #6
builditguy's Avatar
Rewards Points: 2,190
Here is one we did. We made our own 2” x2” steel post and 2”x2” top rail. We we bought the stainless steel cables separately.
Of course steel won’t be that great in a coastal area, but it is an option. Maybe 2”x2” aluminum posts?
I don’t know how far they will span.
builditguy is offline
The Following 3 Users Say Thank You to builditguy For This Useful Post:
CityDecks (02-25-2019), Mordekyle (01-24-2019), pathbuilder (03-24-2019)
Old 01-29-2019, 07:52 AM   #7
Patrickstew's Avatar
Trade: Exterior Remodel and Repair Contractor
Rewards Points: 412
Originally Posted by MarkJames View Post
This looks cool.
I used the viewrail system on a custom new construction in Wild Dunes/Mt. Pleasant SC for the first time recently. Only drawback is the baseplate under the Newell’s isn’t as wide as I preferred for stability, and as we ran Dectec waterproofing membrane prior to install with a drip edge, we had to cut into it and add block under to give it more bite.
On a positive note, the quality is outstanding, the grade of Stainless for the cable and tensioners is really good. Also, the customer wanted white so it shipped powdercoated from the factory with a really nice finish.
Patrickstew is online now
Old 01-29-2019, 08:01 AM   #8
rrk's Avatar
Rewards Points: 28
Customer at the beach had aluminum posts and top rail 1 1/2 diameter welded up and Feeney cables, looked really good
rrk is online now
Calidecks (01-30-2019)
Old 01-30-2019, 12:56 AM   #9
jimwalter's Avatar
Trade: carpentry
Rewards Points: 383
cool hopefully I get to install some of these one day.
are they considered climbable?
jimwalter is offline
The Following User Says Thank You to jimwalter For This Useful Post:
Old 01-30-2019, 01:24 AM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 80
Climbable is no longer relevant. It wss taken out of the code in 2001.
Mike.
_______________
jimwalter (01-30-2019)
Old 01-30-2019, 03:19 AM   #11
jimwalter's Avatar
Trade: carpentry
Rewards Points: 383
Mike.
_______________
Sorry, shoulda stated that I'm a canadian eh
Old 01-30-2019, 08:31 AM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
In Ontario they are a no go for that reason.
Inner10 is offline
Old 01-30-2019, 03:19 PM   #13
Bluudog's Avatar
Trade: Fencing, Decks and Railings
Rewards Points: 617
If you are in Canada (Ontario) you have to go vertical to meet code. Well, you have to ensure the cables withstand the 4" sphere test and an engineer signs off or the manufacturer has an engineer stamped drawing/spec sheet. I have seen horizontal cable approved but you must have the climbable part on the outside far enough if a kid climbs it they can't get over the top rail.
Some vertical systems are pre-assembled and make installation a lot easier.
Here are a few more links for reference -
1) https://www.fortressrailing.com
2) https://keylinkonline.com
3) http://www.crlaurence.com/apps/sites...able%20railing
Bluudog is offline
The Following User Says Thank You to Bluudog For This Useful Post:
jimwalter (02-09-2019)
Old 02-07-2019, 02:49 PM   #14
deckdog's Avatar
Trade: deck builder
Rewards Points: 48
We install a ton of keylink vertical and horizontal cable railing (link below)
https://www.customcraftdist.com/horizontal-cable
and Deckorators has a new SLX stainless steel slim line horizontal cable railing (link below)
https://www.deckorators.com/en/Produ...X%20Cable.aspx
DD
deckdog is offline
Old 02-26-2019, 05:11 PM   #15
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Having installed a few cable railing projects in a past life, your governing limitation on post spacing will be the cable. Thicker cables will span farther with a big increase in cost, as well. Metal frame will be mandatory for smaller posts and frame.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following 2 Users Say Thank You to redwood For This Useful Post:
Calidecks (02-26-2019), Patrickstew (02-27-2019)
Old 03-12-2019, 01:19 PM   #16
srexteriors26's Avatar
Rewards Points: 34
Key link for horizontal and westbury verticable for vertical both extremely easy to install a cave man could do it.
srexteriors26 is offline
The Following User Says Thank You to srexteriors26 For This Useful Post:
Calidecks (03-12-2019)
Angled holes for cable rail system phnola Finish Carpentry 8 08-16-2017 11:09 AM
Options when you run into asbestos cutback platinumLLC Flooring 12 02-20-2015 07:15 AM
Let me explain this and tell me if I'm wrong Dustincoc Electrical 9 03-18-2013 10:48 PM
Labor for cable rail installation Lewwax General Discussion 1 01-17-2012 06:34 PM
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 05:09 PM
