Butting Trex Boards To Picture Border Have A Lip - Page 3 - Decks & Fencing - Contractor Talk
Old 01-11-2019, 10:04 AM   #41
MarkJames's Avatar
Rewards Points: 19,655
Re: Butting Trex Boards To Picture Border Have A Lip
Originally Posted by JFM constr View Post
let me know if you need more pictures .
We had a small deck installed a couple months ago with Veranda. The butts are doing that, but less so (more tolerable).
MarkJames is offline
Old 01-11-2019, 10:17 AM   #42
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,642
yes -end cuts are doing the same thing .
Can you get me a Pic of a complete end?
Mike.
_______________
Calidecks is offline
Old 01-11-2019, 10:58 AM   #43
GC/carpenter
Calidecks's Avatar
This butt was right when we installed it on 72 degree Temps. It's 51 right now. So this gives you an idea how much it opens up.
Mike.
_______________
Old 01-11-2019, 11:17 AM   #44
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,448
thanks for taking the time to check this out for me .
JFM constr is offline
Old 01-11-2019, 11:18 AM   #45
JFM constr's Avatar
another view
Old 01-11-2019, 12:45 PM   #46
GC/carpenter
Calidecks's Avatar
Saw basically stays at this angle.
Mike.
_______________
Old 03-12-2019, 01:29 PM   #47
srexteriors26's Avatar
Rewards Points: 34
Trex boards dont swell at the ends and all boards are nearly exact thickness. One thing that can cause this is if you dont pre drill your cortex you get a bit of composite mushrooming in between the board and the framing member.
Other than that cant say I've seen this issue on any of my decks, I did 15000 square feet of composite last year.
srexteriors26 is offline
The Following User Says Thank You to srexteriors26 For This Useful Post:
Calidecks (03-12-2019)
Old 03-12-2019, 01:59 PM   #48
JFM constr's Avatar
Sorry but I just bought another load from the yard and they all have this slight swelling on the end .
Old 03-12-2019, 02:43 PM   #49
GC/carpenter
Calidecks's Avatar
I've literally put down thousands of Trex board not one issue.
Send me a Pic of an uninstalled end from a couple angles.
Mike.
_______________
Old 03-12-2019, 02:45 PM   #50
GC/carpenter
Calidecks's Avatar
That deck step looks like ass. Is that how your leave them?
Mike.
_______________
Old 03-12-2019, 03:05 PM   #51
Rewards Points: 34
another view
you know they make square edge boards right?
They don't swell at the ends I really don't care what you tell me
I always square off the factory ends maybe that has something to do with it.
I built a 1500 square foot trex display at my lumber yard and I look at every day during all seasons here in newengland and cant seem to even remotely agree with you
Old 03-12-2019, 03:06 PM   #52
JFM constr's Avatar
Mike.
_______________
excuss me - what are you asking
Old 03-13-2019, 09:05 PM   #53
rblakes1's Avatar
Rewards Points: 4,068
I think he's talking about that
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Calidecks (03-13-2019)
Old 03-14-2019, 03:13 PM   #54
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
Is that a grooved board as the tread lip? It's common practice to use solid edge boards so you don't see the unsightly groove.
Sent from my SM-G930W8 using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 2 Users Say Thank You to heavy_d For This Useful Post:
Calidecks (03-14-2019), mrcat (03-14-2019)
Old 03-14-2019, 08:45 PM   #55
JFM constr's Avatar
forgot all about that .back stairs ,my house .recently digging through my lumber supply i found a spiced rum no groove and just couldn't figure what i got it for . Well hopefully i can forget again .
The Following 2 Users Say Thank You to JFM constr For This Useful Post:
Calidecks (03-14-2019), heavy_d (03-14-2019)
Old 03-26-2019, 08:55 PM   #56
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,780
I think your joint might be too tight/ close and when it expanding it pushed upward. The only time I've that is our production deck where we install azek chepo one with the letter E profile. Never on Trex transcend. Which is what we install on retail side (ho). I keep them all butts at 3/16. If it's really hot 95+ I'll go an 1/8 on butts. We usually use there clips because most of our Decks are around 300sf and find less hassle not dealing with guns and hoses using clip's vrs tcg clips which is what I use 450+ SF . How many times has this happened??
Sent from my E6810 using Tapatalk
CityDecks is offline
Old 03-26-2019, 09:01 PM   #57
CityDecks's Avatar
Trade: Deck Builder
Originally Posted by CityDecks View Post
I think your happy is too tight and when it expanding it pushed upward. The only time I've that is our production deck where we install azek chepo one with the letter E profile. Never on Trex transcend. Which is what we install on retail side (ho). I keep them all butts at 3/16. If it's really hot 95+ I'll go an 1/8 on butts. We usually use there clips because most of our Decks are around 300sf and find less hassle not dealing with guns and hoses using clip's vrs tcg clips which is what I use 450+ SF . How many times has this happened??
Carpenters dream right there....flat as a board.
The Following User Says Thank You to CityDecks For This Useful Post:
Calidecks (03-26-2019)
Old 04-17-2019, 05:57 AM   #58
Patrickstew's Avatar
Trade: Exterior Remodel and Repair Contractor
Rewards Points: 392
No issues with mine
Patrickstew is offline
The Following User Says Thank You to Patrickstew For This Useful Post:
Calidecks (04-17-2019)
Food for thought about a few peeling boards....exterior Derek1157 Painting & Finish Work 17 07-31-2015 11:41 PM
triple post of picture astor Site Feedback and Suggestions 5 11-23-2012 01:05 PM
made crown molding out of plaster of paris Spike7 Finish Carpentry 19 10-28-2012 07:15 AM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
