Butting Trex Boards To Picture Border Have A Lip - Page 2 - Decks & Fencing - Contractor Talk
Old 01-09-2019, 01:35 PM   #21
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,805
Re: Butting Trex Boards To Picture Border Have A Lip
I'm not a deck guy, but I've seen that Trex edge swelling on repair calls. I thought it was due to prolonged wet weather over time.
Seen it on competing composite stuff, too.
MarkJames is online now
Old 01-09-2019, 10:20 PM   #22
GC/carpenter
Californiadecks's Avatar
Rewards Points: 9,112
Wouldn't you think I would've seen it or heard about by now? Thousands of square feet not once have I seen it. I also speak regularly to others around the country who've never had an issue.
Amazing! Lol
Mike.
_______________
Californiadecks is online now
Old 01-09-2019, 10:22 PM   #23
GC/carpenter
In fact I soaked Trex in water for two weeks without any swelling. I've put it in mud zero issues.
Mike.
_______________
Old 01-09-2019, 10:22 PM   #24
GC/carpenter
Pictures or it didn't happen. Imo
Mike.
_______________
Old 01-09-2019, 10:29 PM   #25
MarkJames's Avatar
Amazing! Lol
Mike.
_______________
You live in what climate?
But seriously, I did not mean to doubt or challenge your expertise.
In your travels, have you seen swelling in any of the competing products to Trex, or am I imagining that, too?
Also, could be that I saw it in earlier versions of it.
Old 01-09-2019, 10:52 PM   #26
GC/carpenter
Yes the old Accents had issues which they don't make anymore. The capped composite is a different animal.
Mike.
_______________
The Following User Says Thank You to Californiadecks For This Useful Post:
MarkJames (01-09-2019)
Old 01-09-2019, 10:55 PM   #27
MarkJames's Avatar
Mike.
_______________
Is sawdust, etc still a component?
Old 01-09-2019, 11:03 PM   #28
GC/carpenter
Matters none it doesn't swell.
Mike.
_______________
Old 01-09-2019, 11:09 PM   #29
GC/carpenter
Here's the probable cause. My opinion. It was installed on a cold day and butted tight. Then when it got hot on a summer day they didn't leave enough space between the joints the ends will mash together from expansion, an improper installation. Also if screwed down, screwing too close to the ends may not split until this expansion takes place. Then you get shrooming around the screws. This combination can look like the product is swelling.
Mike.
_______________
Old Yesterday, 04:11 PM   #30
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,648
let me know if you need more pictures .
JFM constr is online now
Old Yesterday, 06:49 PM   #31
pathbuilder's Avatar
Rewards Points: 322
That's a good pic of the issue, following thread.
Are butt joints commonly installed?
Sent from my Pixel 3 XL using Tapatalk
pathbuilder is online now
Old Yesterday, 09:38 PM   #32
GC/carpenter
Never seen that before. Is there a doubler at the joints?
Mike.
_______________
Old Yesterday, 09:41 PM   #33
GC/carpenter
That wet situation there tells me you should have a bigger gap than that. I've had them open as much as a1/4 inch and had them completely closed when it's hot.
Also you NEVER biscuit butt joints. Who knows the situation that might have caused. What's the biscuits make of?
Mike.
_______________
Old Yesterday, 09:49 PM   #34
GC/carpenter
Domino doesn't allow it to move properly. More than likely binds when it bottoms out against the domino. I'll shoot this photo to the big cahunas at Trex. Ill get some answers for you JMF.
Mike.
_______________
Old Yesterday, 09:53 PM   #35
GC/carpenter
One other thing I always do when I butt (which is rare) all my butts are cut at 2 degrees so the bottom of the cut is always spaced without the visual.
Mike.
_______________
Old Yesterday, 11:52 PM   #36
JFM constr's Avatar
Mike.
_______________
that one in the picture has no domino or such .
i will do the 2 degree off the bottom this next time .
oh i ran a knife between the joint and it is open all the way through,not touching on the bottom
Old Yesterday, 11:55 PM   #37
GC/carpenter
So you dominoed just some?
Mike.
_______________
Old Yesterday, 11:55 PM   #38
GC/carpenter
Do you have the same problem on ends that aren't butted?
Mike.
_______________
Old Yesterday, 11:57 PM   #39
JFM constr's Avatar
yes ,just a couple .they are no different nor are the end cuts .
no one is complaining ,i was just not wanting to repeat it on the one i am starting now .
Old Today, 09:18 AM   #40
JFM constr's Avatar
Mike.
_______________
yes -end cuts are doing the same thing .
Food for thought about a few peeling boards....exterior Derek1157 Painting & Finish Work 17 07-31-2015 11:41 PM
triple post of picture astor Site Feedback and Suggestions 5 11-23-2012 01:05 PM
made crown molding out of plaster of paris Spike7 Finish Carpentry 19 10-28-2012 07:15 AM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
