Butting Trex Boards To Picture Border Have A Lip - Decks & Fencing - Contractor Talk
Old 11-27-2018, 02:37 PM   #1
pathbuilder's Avatar
Rewards Points: 418
Is it just me, why do the ends of Trex boards that are butted up to a picture border (or parting board or anything for that matter) tend to have a lip bending up? Is it because the Trex boards naturally curl up for the last 6" or so of each board? Any tips to circumvent this issue? How do you keep them perfectly level?
pathbuilder is offline
Old 11-27-2018, 09:45 PM   #2
rblakes1's Avatar
Rewards Points: 3,202
Re: Butting Trex Boards To Picture Border Have A Lip
Calidecks has a thread going about a deck over a steep grade. In there he shows how he leaves his blocking a hair high to account for the face screws pulling the border boards down tighter
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
pathbuilder (11-27-2018)
Old 11-27-2018, 09:48 PM   #3
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,150
I just put clips on the ends and it sucks it down pretty close. But I can't stand working with Trex clips...I like their boards better, but AZEK is a better fastner system in my limited experience.
I will also say that their infill kit in their rail system is a pain in the arse and the AZEK rails are so much better in regards to installation. Too many pieces and they are too tight.
Tried & True on Facebook
Tried & True Website
TNTRenovate is online now
Old 11-27-2018, 10:44 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 19,968
If you are having issues with a bend on the end of deck boards, it's usually due to either your supplier or your suppliers supplier.
It has everything to do with how they stack them. My guess is the ends are catching on each other when stacked side by side. The stuff likes to keep its shape if left a certain way in the heat and cold.
Having visited the Trex plant, I can tell you how it comes out of the factory and how it gets stored, moved and removed are two different things.
Mike.
_______________
Calidecks is online now
The Following 6 Users Say Thank You to Calidecks For This Useful Post:
Caleb1989 (12-05-2018), cedarboarder (04-17-2019), greg24k (03-15-2019), Jaws (01-10-2019), pathbuilder (11-27-2018), Patrickstew (04-17-2019)
Old 11-27-2018, 10:46 PM   #5
GC/carpenter
Calidecks's Avatar
And not sure of your climate, but a few hours in the sun causes that stuff to soften quite a bit.
Mike.
_______________
Old 11-28-2018, 07:43 AM   #6
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,882
You could Cortex screw down the ends of the boards instead of using clips.
Sent from my SM-G930W8 using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
TNTRenovate (11-28-2018)
Old 01-08-2019, 09:29 PM   #7
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,968
went back to a trex deck I built .The buts all have a small raised area just at the edge .I had put dominos /sipo at some joints for alignment .
called trex ,he says the ends do not raise or such .he did not know what a domino .felt my issue had to be due to the domino .I was good for that till i thought it through .If domino caused it to expand it would be more likely were the domino is placed ,not evenly across the whole edge .On further inspection I have this happening at every joint not just the few with domino's.Most of my joints the boards were cut or trimmed so wouldn't that nix the "how it had been stacked idea" .It looks more like swelling to me .
also if I recall my joints were all butted tight .within a couple weeks or less space started showing up between buts .I believe they are all gapped less then an 1/8" .deck is not in direct sun .some of it never sees sun .
JFM constr is online now
Old 01-08-2019, 11:30 PM   #8
GC/carpenter
Calidecks's Avatar
Don't use butt joints. Problem solved.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
greg24k (03-15-2019), Patrickstew (04-17-2019)
Old 01-08-2019, 11:30 PM   #9
GC/carpenter
Calidecks's Avatar
Thousands of trex deck boards. Never seen one with an end swollen. Not once heard of it either.
Mike.
_______________
Old 01-08-2019, 11:32 PM   #10
GC/carpenter
Calidecks's Avatar
Sun isn't what causes gaps. Cold weather does. Especially in the shade. You should know that if your building with composite.
Mike.
_______________
Old 01-08-2019, 11:34 PM   #11
JFM constr's Avatar
Mike.
_______________
far as i can tell ever end has this happening .some of those end up on an edge .all are have this little curl .
Old 01-08-2019, 11:36 PM   #12
JFM constr's Avatar
Mike.
_______________
interesting .you do realize i am in north bay area .though we do get down in the 30ts .
Old 01-08-2019, 11:50 PM   #13
GC/carpenter
Calidecks's Avatar
Only on your deck. That's what's interesting.
Mike.
_______________
Old 01-08-2019, 11:51 PM   #14
GC/carpenter
Calidecks's Avatar
But you claimed it shouldn't have opened up because it's never in the sun. I agreed. It shouldn't open up because of the sun.
Mike.
_______________
Old 01-08-2019, 11:52 PM   #15
GC/carpenter
Calidecks's Avatar
here
Mike.
_______________
Old 01-08-2019, 11:54 PM   #16
GC/carpenter
Calidecks's Avatar
Gaps happen even here. Depending on the temperature at the install.
Mike.
_______________
Old 01-08-2019, 11:55 PM   #17
GC/carpenter
Calidecks's Avatar
Please send pictures.
Mike.
_______________
Old 01-09-2019, 06:10 AM   #18
Rewards Points: 418
Here's a pic of a deck about a month after install. Ends butted to parting board. At install, everything was flush. I attribute the PT moving. Cortex on these ends helped. We now install ladder framing slightly proud, thanks Mike to your suggestion in your steep slope post.
Sent from my Pixel 3 XL using Tapatalk
The Following User Says Thank You to pathbuilder For This Useful Post:
Calidecks (01-09-2019)
Old 01-09-2019, 01:19 PM   #19
GC/carpenter
Calidecks's Avatar
Need to run a planer down the edges of the ladders before you start because the perpendicular boards can be high when they are over the top of the blocks. It takes literally 20 second.
Mike.
_______________
greg24k (03-15-2019), Mordekyle (01-09-2019), pathbuilder (01-09-2019)
Old 01-09-2019, 01:20 PM   #20
GC/carpenter
Calidecks's Avatar
The pressure treated is a huge problem when it comes to shrinkage. Need to keep it in mind on every application.
Mike.
_______________
Food for thought about a few peeling boards....exterior Derek1157 Painting & Finish Work 17 07-31-2015 11:41 PM
triple post of picture astor Site Feedback and Suggestions 5 11-23-2012 01:05 PM
made crown molding out of plaster of paris Spike7 Finish Carpentry 19 10-28-2012 07:15 AM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
