Building Deck Over Slab....? - Decks & Fencing - Contractor Talk
Old 12-16-2014, 08:45 AM   #1
SailingandSuch's Avatar
Rewards Points: 163
Went to look at a job yesterday where a lady wants a deck built over a slab. The slab is an outdoor patio that is actually about 8' high off the ground with block walls.
The pressure treated deck needs to sit as low as possible and I know putting PT wood on concrete is a no no as it will rot and also there will not be enough space under the decking to allow it to breathe.
My plan is to set posts just outside of the slab all the way into the ground. This will help with ventilation as the cavity between my joists will be open and no closed by the outside band.
As for the joists going over the slab I was thinking of using 2x4's with some sort of bracket to elevate them a bit off of the slab. All I can come up with is this elevated post bracket.
http://images.lowes.com/product/conv...42114079lg.jpg
Just taking these and spacing them about ever 3' or so under my 2x4 joists....
What do you guys think? Will this work?
I'd love to hear if anyone has a better idea as well.
Thank you gentlemen!
SailingandSuch is offline
Old 12-16-2014, 09:11 AM   #2
mako1's Avatar
Rewards Points: 1,094
Re: Building Deck Over Slab....?
If this slab is 8' off the ground ,I think the post going into the gronnd would look like crap.First thing I would do is check the slope of the slab and make sure it is away from the house.I would put posts off the slab using simpson brackets and drive anchors.
2X4's shimmed for joist are also a bad idea. Beef up your joist to keep them off the slab with no shims.
Knowing the size of the deck would help give a better answer.
mako1 is offline
Old 12-16-2014, 09:52 AM   #3
Rewards Points: 163
I agree, the post off the ground that high wouldn't look the best. But I haven't found a way to have sturdy handrails when the posts about as deep as the deck and not into the ground. I could be missing something though.
I will have to see if I can go up to a 2x6 joist but I'm not sure that will be an option or the deck will get to high.
Here is a quick image of the deck size. There is a slab under it every where except the grey area. There, the deck will be elevated 8' off the ground.
Old 12-16-2014, 10:37 AM   #4
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 192
I could not get past the slab being 8 feet off the grade.
I have a better idea but I get paid for that ****.
Andy.
ScipioAfricanus is online now
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
BlueRidgeGreen (12-16-2014), Calidecks (12-16-2014)
Old 12-16-2014, 10:48 AM   #5
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
pressure treated is designed to be applicable in this situation. It can sit on concrete, you just don't want debris (organic matter) piling up around it and retaining moisture. As far as venting... run your joists 3 1/2" past slab, run posts thru and red head into wall. Timberlocks in your rim to reinforce posts and HD2's if necessary.
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following 4 Users Say Thank You to parkers5150 For This Useful Post:
Calidecks (12-16-2014), ghhartmann (12-17-2014), Lugnut1968 (12-16-2014), Tom M (12-16-2014)
Old 12-16-2014, 11:16 AM   #6
Tom M's Avatar
Rewards Points: 8,098
Why would treated lumber not be allowed to contact concrete?
Tom M is online now
Old 12-16-2014, 12:01 PM   #7
hdavis's Avatar
Rewards Points: 2,156
It isn't a question of whether you can or can't, it's a question of treatment level needed for the application.
hdavis is online now
Old 12-16-2014, 12:36 PM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,048
I put this framing on a support every 4' but this slab has many drains. Also I used composite that doesn't behave anything like real wood.
Composite would be my recommendation.
That was predictable.
Building Deck over Slab....?-1418751424999.jpg   Building Deck over Slab....?-1418751445031.jpg   Building Deck over Slab....?-1418751460237.jpg
Calidecks is online now
BlueRidgeGreen (12-16-2014), hdavis (12-16-2014), ScipioAfricanus (12-16-2014)
Old 12-16-2014, 02:44 PM   #9
mako1's Avatar
Andy.
Me too? They get the down and dirty idea for free.Then they have to pay.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
ScipioAfricanus (12-17-2014)
Old 12-16-2014, 06:04 PM   #10
GC/carpenter
Calidecks's Avatar
Andy.
I can personally attest to this.
Old 12-16-2014, 07:13 PM   #11
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 3,636
Two words... basket weave.
Deckhead is offline
Old 12-16-2014, 07:30 PM   #12
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 316
Ground Contact PT....
(see your two words....and raise you an acronym)
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is online now
The Following 3 Users Say Thank You to BlueRidgeGreen For This Useful Post:
Deckhead (12-16-2014), John Hyatt (12-17-2014), ScipioAfricanus (12-17-2014)
Old 12-16-2014, 09:06 PM   #13
Talking Head
EthanB's Avatar
Rewards Points: 392
If you absolutely have to use 2x4 joists then I'd probably skip the standoffs you linked and use the plastic standoffs and block the bays a bit more, unless the BO is requiring the other standoffs for uplift reasons. You're going to want to use a LOT of those standoffs as any point loads are going to be a real problem on 2x4's.
Have you looked at using a steel frame?
Consider skipping the posts going to the ground and limit your cantilever so you can drop the posts a bit below the framing and then attach them to the block wall. I think a sleeved threaded rod would work well.
Planer.....
EthanB is online now
Old 12-16-2014, 09:16 PM   #14
Rewards Points: 163
Thank you for all the suggestions. I think I have a few more options now for the joists.
My handrails are another story. I'm not able to easily attach the posts to the block wall do to a "overhang" of the top slab similar to a row lock of brick but just with concrete. It probably hanges over 1 1/2" or so.
In order to run the posts down a bit and fasten to the block wall I would need to put some blocking between the post and the wall in order to keep the postplumb.
An option that would be a major pain would be to just cut off the overhang, but I don't think it's feasible.....
Old 12-16-2014, 09:36 PM   #15
Talking Head
EthanB's Avatar
Rewards Points: 392
That's what I was talking about for the threaded rod. Run the rod through the post and into the block wall with epoxy in the wall and a nut and washer on either side of the post. You could sleeve pipe onto the rod when you put it in to hide the threads between the post and the wall. Stainless or copper would look cool.
Planer.....
The Following 2 Users Say Thank You to EthanB For This Useful Post:
BlueRidgeGreen (12-17-2014), John Hyatt (12-17-2014)
Old 12-17-2014, 06:32 AM   #16
3rd Generation
Nick R's Avatar
Rewards Points: 391
Is this a composite rail? Look into timbertech secure post mount. I picked one up the other day, but haven't installed yet. Seems very sturdy.
http://timbertech.com/files/files/Se...ost_7_2014.pdf
I'll be installing directly to concrete.
Nick R is offline
Old 12-17-2014, 07:06 AM   #17
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 82
Why would it be a "major pain" to cut the concrete? I think I'd rather do that then mess around with blocking or any other half @$$ attachment you can think of. I have a diamond blade for one of my old circular saws and it would make quick work of that 1.5" overhang
NJGC is offline
The Following User Says Thank You to NJGC For This Useful Post:
parkers5150 (12-17-2014)
Old 12-17-2014, 07:36 AM   #18
Tom M's Avatar
I would only be installing structural surface mounted posts in this application.
Tom M is online now
Old 12-17-2014, 12:30 PM   #19
ArtisticDecks-Bob's Avatar
Trade: Decks
Rewards Points: 232
If you use Moisture Shield composite or Azek cellular PVC you don't have to worry about ventilation underneath your decking.
I would use sleepers underneath the deck surface because Tap Cons through the decking is a bit un-slightly. ha
Bob
ArtisticDecks-Bob is offline
Estimating with Excel for the Small Contractor YouTube cargin2 Business 127 12-09-2019 12:06 PM
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
Building a trellis on a roof deck plumbthis Carpentry 4 01-15-2013 03:51 PM
Building Deck Bobswan79 General Discussion 2 03-09-2010 07:50 PM
