Azek Sheet/raised Panel Wainscoat - Decks & Fencing - Contractor Talk
Old 02-07-2012, 09:35 PM   #1
Bone Saw's Avatar
Trade: decks
Rewards Points: 2,076
upcoming project has me questioning the stability of creating faux raised panel with azek sheet with basecap trim vs creating raised panels.
full southern exposure, wondering if the sheet will be stable or get silly in the sun
thoughts?
Bone Saw is offline
Old 02-07-2012, 09:38 PM   #2
jb4211's Avatar
Rewards Points: 2,306
Re: Azek Sheet/raised Panel Wainscoat
Have you contacted the manufacturer?
I've used Azek and really liked it, but I've only used decking and fascia coverings applications.
Jon
jb4211 is offline
Old 02-07-2012, 09:39 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I think they will be fine. I am pretty sure thats what they are rated for. I have never seen a raised panel in full sun expose but I have seen many window and door trim outs with detailed trim work last along time in the sun.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
thomasjmarino (02-08-2012)
Old 02-07-2012, 09:49 PM   #4
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
It depends on if you're leaving it white or painting a darker color, but I've done quite a bit of Panel work like that with good results. It might be best to build in some room for expansion between the posts using some form of slip joint.
azek sheet/raised panel wainscoat-019.jpg   azek sheet/raised panel wainscoat-018-1.jpg   azek sheet/raised panel wainscoat-001-11-1.jpg
loneframer is offline
The Following 6 Users Say Thank You to loneframer For This Useful Post:
Bone Saw (02-07-2012), DeckPros (02-09-2012), John Hyatt (02-08-2012), moorewarner (02-09-2012), thomasjmarino (02-08-2012), Tom Struble (02-07-2012)
Old 02-07-2012, 09:50 PM   #5
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,534
If you use a full panel, give it room to move.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 02-08-2012, 07:52 PM   #6
Thomas J Marino, Inc
thomasjmarino's Avatar
Trade: Custom Home Builder/General Contractor
About to do a porch enclosure thats approx. 10'x21' and approx. 4' off the ground.
Going to do it all in PVC with raised panels including along the sides of the staircase.
If I ever figure out how to post photos, I will put them up when it's completed.
thomasjmarino is offline
Old 02-08-2012, 08:53 PM   #7
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
space balls!!
world llc is offline
Old 02-08-2012, 08:55 PM   #8
Bone Saw's Avatar
Trade: decks
I'd like to see that when it's done
Bone Saw is offline
Old 02-08-2012, 08:55 PM   #9
Bone Saw's Avatar
Trade: decks
Originally Posted by world llc View Post
space balls!!
wtf???
Bone Saw is offline
Old 02-08-2012, 08:58 PM   #10
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i think they are balls that keep the panels centered in the stile
Tom Struble is offline
world llc (02-08-2012)
Old 02-08-2012, 09:00 PM   #11
world llc's Avatar
They keep the panel centered and expand and contract for movement. We use them for wood panels
The Following User Says Thank You to world llc For This Useful Post:
Bone Saw (02-08-2012)
Old 02-08-2012, 09:13 PM   #12
GRB's Avatar
Trade: Carpentry Contractor
Same here.
http://www.spaceballs.com/
GRB is offline
The Following User Says Thank You to GRB For This Useful Post:
Old 02-08-2012, 09:16 PM   #13
world llc's Avatar
were you thinking
azek sheet/raised panel wainscoat-dark-helmet.jpg
BreyerConstruct (02-09-2012)
Old 02-09-2012, 08:14 AM   #14
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Rewards Points: 1,000
My .02...
If the panels are all Azek, then build each as a single unit, with room to slip/move.
But I also know your creativity... this could be an interesting place for copper panels, or something a bit off-the-wall.
~Matt
BreyerConstruct is offline
Combination Panel Install thom Electrical 8 07-04-2011 12:40 PM
sub panel placement jkfox624 NEC Discussion 18 12-21-2010 10:14 AM
New service panel from ex.panel galixy250 Electrical 1 12-20-2010 10:29 PM
Romex in PVC into panel Carpetony Electrical 3 07-31-2009 04:56 PM
Upgrading Main Panel DecksEtc Electrical 7 01-23-2006 07:54 PM
