Any Solution For Sonotubes Getting Wet And Caving In Waiting For Inspection? - Decks & Fencing - Contractor Talk
Old 07-13-2010, 04:36 PM   #1
MikeGC's Avatar
Trade: All construction, remodeling, home improvements
Location: Rochester, NY Elmira, NY, WNY, Finger Lakes, Southern Tier
Rewards Points: 510
I recently installed 3 sonutubes in holes the night before a heavy rain. The holes filled up with water which then destroyed the sonotubes over night.
We had an inspection scheduled for that morning arriving to the site to find all the holes totally caved in from the soaking wet worthless sonotubes
We had to redig the holes, pump out the water, put in new tubes and backfill in time for the inspection.
I dont use sonotubes much.
Does anyone have a suggestion what I could use instead of sonotubes that will hold up to quite aa bit of moisture until the inspector stops by and we can place the concrete and backfill the post holes?
Thank you in advance for your suggestions.
MikeGC is offline
Old 07-13-2010, 04:39 PM   #2
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Re: Any Solution For Sonotubes Getting Wet And Caving In Waiting For Inspection?
I don't use them for the entire hole. I just place a short section at the top of the hole. I've had it happen to me before by an unexpected thunderstorm and I stopped putting them in the hole to the bottom.
I don't think there is a way to stop them from getting wet and caving in.
ApgarNJ is offline
Old 07-13-2010, 04:55 PM   #3
Remodeling Professionals
buildenterprise's Avatar
Trade: New Construction and Remodeling Contractor
Rewards Points: 502
I just square off my holes and use plywood forms until inspection is complete.
buildenterprise is offline
Old 07-13-2010, 04:59 PM   #4
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
I’m at the same cross road, Started a deck today but with rain expected today & tomorrow there’s no sense taking a chance destroying $400. In sono tubs. So we staked it out and now are waiting.
I have considered coating the tubs with epoxy of some sort, maybe sacrifice 8 tubes. Then swap out the epoxy coated tubes on inspection day.
I have a few extra floating around, I’ll give it a shot and post results
festerized is offline
Old 07-13-2010, 05:05 PM   #5
Hofmann's Avatar
Trade: carpenter
Rewards Points: 150
you could try those round cardboard post forms they use in highrise. I don't think they're cheap though and you would still want the sonotubes above grade or you'll have to strip them. The easiest way is to just cover the holes with ply if you think it's gonna rain and the soil looks dodgy.
Hofmann is offline
Old 07-13-2010, 05:14 PM   #6
Dan
ApgarNJ's Avatar
buy 12" thinwall PVC pipe. keep it in there overnight, then stick real tubes in there for the inspection. keep the pipe for the next job. that's another option but expensive.
I think making a form for the top of the hole is the best solution and saves you a lot in sonotubes.
the concrete gets a better grab on the walls of the hole and easier to bell the bottom.
ApgarNJ is offline
Old 07-13-2010, 05:25 PM   #7
jb4211's Avatar
Rewards Points: 2,306
I know it sounds simple, but a small piece of plywood, a plastic trash can lid, etc. all work great and keep most of the water out of the hole. I've used in the past with great results.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
knucklehead (07-13-2010)
Old 07-13-2010, 05:51 PM   #8
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I'm surprised that sonotubes are not coated with wax or something similar, for their cost.
Where my footings are not highly visable, I often use a thin cardboard form that is waxed. I buy them by the box (probably a 100 to the box @ less then a dollar each. They are 12" round and 9" high. They are segmented and are flat in the box. Often times they are reusable as well. Downside of them is that you have to go easy placing the concrete in them, they can blow out. They are also harder to plumb up, since they are so flexible.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 07-13-2010, 06:24 PM   #9
mics_54's Avatar
Trade: contractor
I saw some one using galv metal duct in place of sono.
mics_54 is offline
Old 07-13-2010, 06:34 PM   #10
Dan
ApgarNJ's Avatar
sonotubes are coated with something just not enough to keep them from soaking up water. the plywood works if it's not a ground water issue. if you are digging where the ground water can be a problem during a rain, then plywood is not going to help. don't let the sonotube touch the bottom of the hole.
ApgarNJ is offline
Old 07-13-2010, 06:55 PM   #11
DeckPros's Avatar
Trade: Outdoor Construction
Rewards Points: 250
The soil mostly clay around here, so, like Apgar, I don't use full tubes very often. But when I need to, I double-bag them with contractor bags. Put one bag over the outside of the tube, put it in the hole. Put the other bag inside the tube (like it's a garbage can). Then put a few inches of gravel in the bottom of the bag. This keeps any ground water from raising the inside bag out of the hole.
I did have one inspector bitch about not being able to see the dirt at the bottom of the hole. But all the other ones were fine with it.
http://www.thedeckpros.com
DeckPros is offline
The Following User Says Thank You to DeckPros For This Useful Post:
MikeGC (07-14-2010)
Old 07-13-2010, 07:13 PM   #12
The Deck Guy
Greg Di's Avatar
The better sonotubes are wax coated and will take a fair amount of water before they get ruined. One rain storm won't kill them.
The HD tubes are regular cardboard and suck. We don't use them unless it's an emergency, plus they are more per LF than the WAXED 12' tubes we get at a real supplier.
All our holes get plywood over the top until the concrete comes.
We used to use full height tubes on all jobs. Now, not so much. We only use a 1' piece to form the top. You get a larger footing that is much easier to make look "good" at the end of the day. Not using a tube generally means more concrete and with the 15" auger we use use, it means the real size of the footing goes up to 16" while the HO can only see 12" from the top due to tube form.
I cannot figure out the inspectors on this. We routinely pass footing inspection with no tubes set for the inspection, then the adjacent town's inspector will fail for not having tubes. It's like "HELLO...it's a friggin' hole...how much more complicated must you make this?"
Greg Di is offline
The Following 3 Users Say Thank You to Greg Di For This Useful Post:
DJ9222 (07-13-2010), MikeGC (07-14-2010), neolitic (07-13-2010)
Old 07-13-2010, 07:43 PM   #13
Dan
ApgarNJ's Avatar
have you failed for not belling out the bottom? I've yet to see a deck ripped out of the ground with non-belled footings.
to me, there is no need for tubes the whole way. I think it's a better and stronger footing if the concrete forms to the ground, greg does it just like I do, 1' at the top.
Deck pros, where are you in NJ. We have all CLAY and ROCK where I live in kingwood township, NJ
ApgarNJ is offline
Old 07-13-2010, 07:52 PM   #14
If they say "Sonotube" you
don't have that problem.
Greg's got it.
neolitic is offline
Old 07-13-2010, 08:17 PM   #15
DeckPros's Avatar
Rewards Points: 250
I mostly work in Morris, Somerset and Hunterdon counties. All shale, rock and clay. Gas powered augers? Forget it. Not a chance.
Smaller jobs (10 footings or less) we usually use a few jack hammers and shale bars. On larger jobs, I'll rent or borrow a big machine.
I've used my buddy's L45 Kubota. As far as "compact" backhoes go, that's a pretty big one (45 HP). And I've broken the pin on his 3-point post hole digger more than once (it's designed to shear when too much force is placed on the auger). And I'm CAREFUL with it. Sometimes I just have to put the backhoe back on, dig a large hole, put in the tubes and backfill...
DeckPros is offline
Old 07-13-2010, 08:25 PM   #16
David Festa
festerized's Avatar
I don’t know for sure why townships require sonotubes but I have a theory.
UP lift: if the concrete is poured in a hole and the sides are gagged or uneven the footing my lift when the ground area around it rises in the winter?
The Following 2 Users Say Thank You to festerized For This Useful Post:
tcleve4911 (07-15-2010), Wayfarer Doors (07-14-2010)
Old 07-13-2010, 08:58 PM   #17
The Deck Guy
Greg Di's Avatar
We dig to 36". The actual frost only gets about 12" deep in the WORST circumstances in nature.
If you have even the slightest bell at the base of the footing it's a non-issue. Even without a bell, it's a non-issue.
So much of code is interpretive and common sense, yet the amount of overkill designed into the codes that eliminate the application of common sense baffles me.
I've seen 30 year old decks with NO footings (4x4s buried in 3" of dirt) that have lasted just fine!!!
Greg Di is offline
Old 07-13-2010, 09:02 PM   #18
Dan
ApgarNJ's Avatar
12" of frost in NJ may be max but not other locations. I've dug in winter before here and on occasion have seen more than 12" of frost, not common but happens.
36-42 is great.
ApgarNJ is offline
Old 07-13-2010, 09:14 PM   #19
Box Builder
Morning Wood's Avatar
Rewards Points: 9,818
I've used the black plastic culvert pipe. smooth walled on the interior. I think it was 16" stuff. But it was free to me and I didn't have to buy it. stuff was sweet. Could back fill and then cut the top exactly level where i wanted it. I think I used a sawzall to cut off whatever was sticking above rough grade. It probably isn't a good alternative. But, the stuff is not going to cave in ever.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
MikeGC (07-14-2010)
Old 07-13-2010, 09:54 PM   #20
Project Superintendent
mudpad's Avatar
We use sonotube for light pole bases. We auger the hole, usually 2' diameter, then just use tube for the 2' above grade. Drop in rebar cage, add plywood template for pole anchor bolts with 3" hole in the middle, bring conduit in and up thru the hole in the template, ground rod, then call the electrical inspector, and hope he gets there before too many rains, one shower doesnt hurt, as long as there is no water in the hole.
Steve
mudpad is offline
