Angle Decking Lf - Decks & Fencing - Contractor Talk
Angle Decking Lf
Old 04-19-2015, 06:34 PM   #1
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
Angle Decking Lf
Hey all. I can't believe after 400+ decks I finally have my 1st request for angled deck pattern.
how do I determine lf?
19wx17L
323 sf
picture frame:yes.
single around perimiter and dbl on center. or single in middle.
Thank you all in advance for your time.
CITY DECKS INC is offline
Old 04-19-2015, 06:48 PM   #2
Talking Head
EthanB's Avatar
Rewards Points: 310
Re: Angle Decking Lf
19wx17L
323 sf
picture frame:yes.
We just had a thread on this and Killer and at least one other guy had good techniques for this. A search might turn it up for you.
Since it's you, I'll lay it out in Sketchup and post it tonight.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
CITY DECKS INC (04-19-2015)
Old 04-19-2015, 06:54 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 3,094
check these threads out.
http://www.contractortalk.com/f50/me...boards-183418/
http://www.contractortalk.com/f50/us...install-93135/
http://www.contractortalk.com/f50/es...or-deck-19573/
griz is online now
Old 04-19-2015, 07:08 PM   #4
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
just happened to be working on a layout in SU.....is this what you're working with?? I never use LF, always SF and it works out just fine for me.
11'9 3/4" would be the length of your longest boards, order all 12's and you should be good to go - I would order 253sf + 10% = 275ish SF in all 12' boards.
James
www.selectdecks.com
SelectDecks is offline
Old 04-19-2015, 07:10 PM   #5
pretty much except the upper left corner is 4x4 sleeper step up/down.
the lower right will a a 3x3x tree pit.
and the bottom 15ft will flower box(18" x12h x 15L)
Old 04-19-2015, 07:14 PM   #6
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Since I am drawing the plans in sketchup I usually do a group or component of decking and just count the boards.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
John Hyatt (04-20-2015)
Old 04-19-2015, 07:18 PM   #7
deck aficionado
Rewards Points: 973
Don't forget 12" OC when going on the diagonal
James
www.selectdecks.com
Old 04-19-2015, 07:21 PM   #8
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
we frame everything 12" oc even for 2x6 treated decking
you need 60 12'ers
killerdecks is offline
Old 04-19-2015, 07:21 PM   #9
deck aficionado
Rewards Points: 973
Yep, then you don't have to order any extra. This way you would know exactly what you need. But if you're not a SU user might be best just to order a little extra.
James
www.selectdecks.com
Old 04-19-2015, 07:23 PM   #10
deck aficionado
Rewards Points: 973
2x10 joists?
James
www.selectdecks.com
Old 04-19-2015, 07:32 PM   #11
Talking Head
EthanB's Avatar
Rewards Points: 310
It depends on if you're using hardwood or manmade but I usually figure that the offcuts from the shorter boards are used in the corner. So if your full length diagonals are 11-6 you use 12 footers and, as they get shorter, a 12 footer will provide you with two of the pieces for the corner.
In this case you would need 46 14' boards, if that were possible. Total lineal footage is 684 plus overage.
Planer.....
EthanB is offline
Old 04-19-2015, 08:37 PM   #12
E.. thank you so much. Greatly appreciate it.
Old 04-19-2015, 10:06 PM   #13
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
you cant do single in the middle because you have a miter in both directions so you need a full board for left and right... unless you dont miter but i feel thats not "picture frame"
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 04-19-2015, 10:09 PM   #14
Talking Head
EthanB's Avatar
Rewards Points: 310
Yanni doesn't usually miter his picture frame. He's the one that showed me that skipping that hassle entirely was cool. That's part of the reason I spent 10 minutes helping figure out his cut list.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
parkers5150 (04-19-2015), Xtrememtnbiker (04-19-2015)
Old 04-19-2015, 10:10 PM   #15
always building
round these parts...nobody makes anything in 14'ers... materials go from12' to 16'
www.RDPontheWeb.com
The Following User Says Thank You to parkers5150 For This Useful Post:
Tom M (04-20-2015)
Old 04-19-2015, 10:25 PM   #16
Talking Head
EthanB's Avatar
Rewards Points: 310
Depends on materials, but same here. I couldn't get a full load of any particular size in hardwood without paying a serious premium. I try to figure out a few sizes that will be optimal and go handpick my own load on a deck as small as this. For manmade though it would have to be mostly 20'ers. You can still do it with minimal waste though. I think something like 24 - 20's, 3 - 16's and 16 - 12's would handle the deck without joints.
Planer.....
EthanB is offline
Old 04-19-2015, 10:41 PM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 21,440
Now I don't feel so bad asking this same question in another thread.
At the end of that job had only one peice left over
Calidecks is online now
Old 04-20-2015, 06:31 AM   #18
Parker..relax.its just quick sketch and kind act. I can manage in the field.
Old 04-20-2015, 06:38 AM   #19
Hey Cali. Nothing to feel bad about. I've never done an angled deck...ever. The other day I met with customer to review final details. And she's rambling on I said hold lady I gotta write it all down cause im a moron and can't nor do I want too remember. She gave me the nicest compliment and held my hand said I know now why you were higher then the rest and feel completely confident that I hired the right guy to do the job. Never stupid questions. Only stupid if not asked.
The Following User Says Thank You to CITY DECKS INC For This Useful Post:
Calidecks (04-20-2015)
Old 04-20-2015, 09:25 AM   #20
Tom M's Avatar
Rewards Points: 4,348
My estimating books say multiply SF x 1.33 for waste.
So 19w 19x12= 228" - 22" (4 deck boards 2 ends double center)= 206"
17w 17x12=204"-5.5 (single outside picture frame)198.5"
206"x198.5"=4,089.10"/144= 283.97
283.97 x 1.33= 377.67 SF purchase + stairs+ picture frame
5.5" .458 x 12= 5.496 sf / 12ft board
377.67 / 5.5sf = 68.66........69 12' boards +stairs+picture frame
Tom M is offline
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
right angle drill/driver Rich D. Tools & Equipment 16 06-29-2012 03:06 PM
A Job With A View Timuhler Framing 117 03-02-2011 09:30 PM
Decking and Mosquitos Morning Wood Decks & Fencing 23 01-09-2010 12:31 AM
Decking mishap starttofinish Decks & Fencing 37 12-20-2009 11:32 AM
