Trade: Builder
Rewards Points: 8
Advice For UK Builder Doing Deck In US
Hi there,
Back in the UK I am a builder and I now spend a lot of time in the US in Pennsylvania as my wife is American. I've started to do a few projects out here and my latest one is a new wrap around deck. From what I've seen and read the designs are a little different to how we may do in the UK, so was after some advice to make sure I comply with US best practice. Key dimensions: - Overall Size - 27' x 20' Deck width - 8' Deck overhang - 1' Deck height - 3' Deck beams - 2x10 Deck joists - 2x10 Joists spacing - 16" Deck posts - 4x4 Post spacing - 6-7' Decking boards - 1x6 PT board My main questions: - 1. Does design look ok? 2. Any key dimensions should i change? i.e should posts be 6x6 or deck beams be 2x12? 3. In UK the posts would always be submerged and concreted in. Is this a big no for the US. I do prefer this look to resting on a concrete padstone. 4. Again in the US it seems typical to rest beams on top of posts? In UK we would sandwich and bolt beams either side of post. Am I correct best practise is beams on top of post? 5. Does the detail of the angle beams look ok? I think i've seen 45 degree hangers I can use? Only issue with the overhang is it creates issues with the last small joists... Thanks in advance |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Rewards Points: 5,304
Re: Advice For UK Builder Doing Deck In US
Simpson makes hangers for just about every imaginable use. Check out their catalog on line.
This deck is in PA? How is the soil, lots of rock in your area? Advertisement
Trump-The "Con Man's" Con Man. |
Trade: Builder
Rewards Points: 8
Yeah it's in PA. Soil is pretty good, but it is rocky!
I did a pergola in the summer which required 4 posts. A bit of hard labour digging the holes for that - but manageable. |
Sponsored Links | |||
Advertisement |
Capra aegagrus
![]() ![]() Trade: Remodeler
Rewards Points: 76
Re: Advice For UK Builder Doing Deck In US |
The Following User Says Thank You to Tinstaafl For This Useful Post: |
Calidecks (11-26-2019)
Trade: Builder
Rewards Points: 8
Ok thanks. It would be great to get some advice on my specific questions and design if possible?
thanks |
Rewards Points: 958
6X6 posts, beams are incised into them and through bolted. This detail is in the PDF already linked.
Best practice is usually considered to be concrete footers with a base bracket the post gets attached to. Some areas customers may have a preference for concrete encased posts. |
#7 | |
Rewards Points: 2,744
Re: Advice For UK Builder Doing Deck In USQuote:
![]() Definitely 6x6. No bolting beams to the sides of posts. Where in PA are you? The DCA 6 is a great source of info. Your local building department may also have a packet available for what they expect. |
The Following User Says Thank You to Dan_Watson For This Useful Post: |
SmallTownGuy (11-26-2019)
#8 | |
How do those piers react in rocky conditions?
#9 | |
John the Builder
Rewards Points: 5,898
Make it much easier to avoid 2nd guessing what will be accepted. ![]()
All my Life loving Hippie friends turned into soul-sucking Conservatives - or died. Same difference. "Mornin' ladies, my goodness don't you look happy. Must be cuttin' somebody up pretty good." - Andy Griffiths |
The Following User Says Thank You to SmallTownGuy For This Useful Post: |
Dan_Watson (11-26-2019)
What do you mean by rocky? Gravel, basketballs, volvos? There are a lot of variables and we have ways of dealing with most of them.
#11 | |
Got me thinking if the machine behind the piers would just power right through all that crap.
#12 | |
TimNJ (11-27-2019)
Trade: Builder
Rewards Points: 8
Location is about 10 miles from State college in PA
#14 | |
Trade: Pole Barns, Residential Framing
Rewards Points: 68
Sent from my SM-G930V using Tapatalk |
Depends on depths and loads required. Sometimes we have to loosen up the rocky soil just to get through it and find better soil below.
TimNJ (11-27-2019)
Display Modes | Rate This Thread |
Go to Page... |
