Worst Things Seen In Electrical.... - Electrical - Contractor Talk
Old 09-10-2008, 07:56 PM   #1
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
just for fun wats the worst thing u ppl saw in electrical done from a previous electrician... i have so many its not even funny... from the squeeze part of a bx conector use to join the main of a service entrance of a house, to an upside down 75 kva transformer YA UPSIDE DOWN the reason why i think it was put upside down is cause the wires of the load werent long enough
pat c is offline
Old 09-10-2008, 08:08 PM   #2
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
Re: Worst Things Seen In Electrical....
I found a #2 GEC bonded and jumpered at the water meter and a # 2 at the CT can going through the wall but the hundred feet of #2 from the h2o meter was coiled up in the ceiling and went nowhere....We were having our own problems that day and the boss could care less.
K2 is offline
Old 09-10-2008, 08:19 PM   #3
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Everyone know you can't do this. All the electrons will fall out.
Speedy Petey is offline
Old 09-10-2008, 08:42 PM   #4
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
They must've had a bucket sitting below with a ground rod driven through the center of it.
Sparky Joe is offline
Old 09-10-2008, 08:48 PM   #5
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
im telling it like i saw it
pat c is offline
Old 09-10-2008, 08:51 PM   #6
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
a few years back i had to repair a light at one of my customers house outside, it was right ontop of the door on the aluminium suffit. has im unscrewing it i get zaped. they use the aluminium going around the house as a nutral when i started to remove the screw taped on the aluminium it became all red...
pat c is offline
Old 09-10-2008, 08:55 PM   #7
listen twice talk once!
Bkessler's Avatar
Trade: electrician
How about an old panel where every breaker was a 2 pole 50. Yes 2 pole 50 for #12 &#14.
Bkessler is offline
Old 09-10-2008, 09:02 PM   #8
Union Electrician
Sparky Joe's Avatar
Just teasing,
Once saw a pair of 75kVA's installed in parallel.
I assume they needed 150kVA and used what they had?
I don't know if it was legal, but it must've worked. We were there doing the demo after we finished the occupant's new building.
Old 09-12-2008, 07:53 PM   #9
220/221's Avatar
Trade: electrician Phoenix AZ
Like this?
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 09-13-2008, 10:10 AM   #10
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
thats exacly how the joint were done with the conectors lolll
I think the emt/fuses is the big winner....i cant believe it thats realy bad
pat c is offline
Old 09-13-2008, 03:42 PM   #11
mdshunk's Avatar
Rewards Points: 2,002
It has been fairly traditional to temp in a new service all over the country with squeeze connectors instead of taps when the PoCo is expected to shortly put the real one's on. Sometimes they get missed, and last for years.
mdshunk is offline
Old 09-13-2008, 03:53 PM   #12
How about the guy who changed
out Mom's fuse box?
The stranded range cable wasn't
long enough so he just twisted it
(tinned copper stranded) around
some #8 aluminum and taped it.
No wire nut, fell apart when I
took the tape off.
neolitic is offline
Old 09-15-2008, 03:50 PM   #13
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
i rewired a comercial local few weeks ago, building is 50 years old. Junction box over junction box a real mess. Cleaning that out ,while locating all the mains i started to open the 4*4box's all the joints were done with copper burndys. i must of collected 50 of them
pat c is offline
Old 09-15-2008, 04:02 PM   #14
Professional Instigator
rbsremodeling's Avatar
Today.
Feed to a water heater, Ran up the wall INSIDE the HVAC duct about 10 feet into a junction box screwed to the side of the duct work up into the ceiling and down the wall the water heater
rbsremodeling is offline
Old 09-15-2008, 08:30 PM   #15
mattsilkwood's Avatar
Trade: electrician
ive seen alot of scary stuff around here, old farmers have got to be the worst imo. old k&t with romex spliced in just strip back about a foot of the romex and wrap it around the k&t no tape no nothing. or went to an apartment, had one circuit for each unit, microwaves didnt work very well
mattsilkwood is offline
Old 09-23-2008, 03:33 PM   #16
Home Improvement Contract
Apex McGann's Avatar
Trade: Handyman
Rewards Points: 25
Holy Cow Batman!!
My main client in florida was an Prop. Mngt firm and I pulled out harry home renter lamp cord runs from exterior fixtures for party lights or from outlets thur walls into closets and up into the attic to power lights and fans. some times done by the previous tenant sometimes from the prop owner 'doing the tenant a favor', but the pictures above boxes take the cake.
Apex McGann is offline
What do you do different, let's here the little things that you do that set you apart Mike Finley General Discussion 63 06-14-2010 01:43 PM
fire marshal requires electrical survey AustinDB Electrical 1 02-21-2007 12:07 PM
Electrical Riser Diagram nehal101083 Electrical 9 02-09-2007 06:30 PM
On discouraging DIY electrical work... mdshunk Electrical 52 02-18-2006 12:58 AM
