Wiring Old To New Phone Jack Coverplate - Electrical - Contractor Talk
Old 08-17-2019, 07:54 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 582
(new: Leviton R70)
Simple connect the four color code wires onto the new poles in their revised sequence (red/black one side and green/yellow on the other - (4) connections & I'm done? Forgetting jumpers?
artinall is offline
Old 08-17-2019, 10:18 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,010
Re: Wiring Old To New Phone Jack Coverplate
Shouldn't need jumpers anywhere.
You can get a Klein VDV Scout for a little more than a $100, and test your install. If something is backwards, it'll show what and where.
I'm not familiar with that particular model, but yes, it should just hook up the same as the other.
artinall (08-18-2019)
Old 08-17-2019, 10:57 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,316
You mean the new plate doesn't come with instructions?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
hdavis (08-18-2019)
Old 08-18-2019, 09:05 AM   #4
artinall's Avatar
Rewards Points: 582
Actually it did. But the paper was folded so tiny and the print so small I couldn't read it anyway with the glasses I misplaced...
I don't have an old chorded phone to test with and the unit unoccupied, going up for sale. So I'm tryin' to verify here.
Looks like the sides are each circuited together internally like they always should have been but who knows...
artinall is offline
Old 08-18-2019, 09:14 AM   #5
480sparky's Avatar
What's the model number of the plate? You can google that.
Old 08-18-2019, 09:29 AM   #6
480sparky's Avatar
There are four letters on the wiring block, R, G, Y and B. That indicates which color goes where.
Old 08-18-2019, 05:29 PM   #7
artinall's Avatar
Rewards Points: 582
Did it today. Now I'm on to a posted phone plate to hang a wall phone on that had turned putrid yellow.
Different design, I'll simply screw the doubled up lines onto the colored terminals.
The wall hangars are getting harder to come by. Assume due to smartphones.
artinall is offline
Old 08-18-2019, 09:37 PM   #8
480sparky's Avatar
You're welcome.
Old 08-19-2019, 07:26 AM   #9
artinall's Avatar
Rewards Points: 582
You're welcome.
I was on that (how would you know?) and mainly concerned about jumps. But do appreciate your point out. THX.
- There's no substitute for the way people treat one other.
artinall is offline
