Wiring A Heating Element - Electrical - Contractor Talk
Old 08-29-2012, 04:17 PM   #1
Upstate Excavating
Upstate Carp's Avatar
Trade: Road Construction
Rewards Points: 27
Is it possible to wire a heating element to a plug so I can control it with a switched outlet?
I am trying to boil water with a heating element.
Thanks
Upstate Carp is offline
Old 08-29-2012, 04:47 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,594
Re: Wiring A Heating Element
Like a water-heater element?
And you're going to stick it into pan, with a cord run to an outlet.
Say it ain't so.
Old 08-29-2012, 05:02 PM   #3
Upstate Excavating
Rewards Points: 27
Kinda something like that... I am trying to mount the element inside a large aluminum pot with the cord on the outside of the pot
Old 08-29-2012, 06:46 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 980
Tinstaafl is offline
Old 08-29-2012, 06:49 PM   #5
Upstate Excavating
Rewards Points: 27
That's 120 though... I need 220
Old 08-29-2012, 06:51 PM   #6
Upstate Excavating
Rewards Points: 27
Or.... Am I wrong? I'm not an electrician... I need some type of seal also to go between the element and the plug
Old 08-29-2012, 06:54 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 980
Why don't you tell us exactly what you're trying to do? It's quite simple to wire up a switched circuit, but doing so in a safe and practical manner can be a different story.
Maybe you're trying to re-invent the wheel.
Old 08-29-2012, 07:03 PM   #8
Upstate Excavating
Rewards Points: 27
I'm trying to put a heating element inside a large pot to boil water... I want to turn the heating element on and off by plugging it in and unplugging it (or an outlet that has a switch)
Old 08-29-2012, 07:07 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 980
You can't use an electric hotplate?
Old 08-29-2012, 07:08 PM   #10
Upstate Excavating
Rewards Points: 27
Now that I look more closely ... I can just take two wires and put a plug on the end (in simple terms) correct?
Old 08-29-2012, 07:10 PM   #11
Upstate Excavating
Rewards Points: 27
You can't submerge a hot plate ... If I'm correct
Old 08-29-2012, 07:12 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 980
You set your pot on top of the hotplate. Fill it with water. Turn the hotplate on and it will boil the water.
UALocal1Plumber (09-12-2012)
Old 08-29-2012, 07:12 PM   #13
mrmike's Avatar
Trade: Electrical & Carpentry
anything is possible- I have seen some that were made for just the application your talking about.....an element with a cord to put in a cup...to heat the water
mrmike is offline
Old 08-29-2012, 07:16 PM   #14
Upstate Excavating
Rewards Points: 27
I appreciate the hot plate idea buy I'm an pretty set on the element.. And where are you located in e adirondacks? I'm in Moriah
Old 08-31-2012, 01:24 PM   #15
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
How bout a stove????
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 08-31-2012, 01:57 PM   #16
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Most heating element's don't take kindly to being dunked in water.
First you'll need to know how many amps it will draw.
-Dennis
WarriorWithWood is offline
Old 08-31-2012, 02:51 PM   #17
aptpupil's Avatar
Rewards Points: 1,894
what is the purpose of doing this? what's wrong with a hot water heater element? you really need it to be boiling hot?
aptpupil is offline
Old 08-31-2012, 03:00 PM   #18
DavidC
DavidC's Avatar
Rewards Points: 2,006
If you are using a 110v element, I don't see why not wire it to a cord and plug it in. You could cut up a small water heater tank leaving the thermostat and element in place, stick on a handle, add a cord and there is your pot.
Are you building a new appliance for the wife?
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 08-31-2012, 03:44 PM   #19
Ink Slinger
Timo's Avatar
Trade: Retired Builder. Now graphics vendor to the trades
Rewards Points: 150
I've done it with motor oil. Not water though.
Took water heater element, wired old saw cord onto it, dropped it into barrel of oil, plugged it into 110v wall outlet and unplugged it when the barrel was warm to the touch. It makes used motor oil flow through filters very nicely.
I use a different thinning agent now.
Timo is offline
Old 08-31-2012, 04:42 PM   #20
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Would finding a secondhand electric water heater accomplish what you want? My "thinking" is that you could cut off the top of the water heater and proceed from there.
http://www.37flash.com/
flashheatingand is offline
Access Heating & Air accessheating New Member Introductions 3 03-22-2012 10:07 AM
Electric Baseboard -vs- Electric In Floor Heating Keeyter General Discussion 13 03-09-2011 02:37 PM
Old house and electrical wiring ARTSBEST Electrical 3 09-25-2010 08:35 AM
Trailer power wiring Zayas_Const Tools & Equipment 2 03-21-2010 02:19 PM
Disconnecting Wiring Question AlSmith Electrical 6 05-20-2009 09:06 AM
