Wired My First House...... - Page 2 - Electrical - Contractor Talk
Old 01-21-2014, 06:36 PM   #21
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Wired My First House......
I've been using these Ideal strippers for resi work with NM and UF cables for the last few years. I wish I'd had them decades ago. There small enough to reach all the way to the back of a 1-gang box and lightweight with nonconductive handles and the blades are replaceable. They can remove any length of the outer jacket on 14/2 UF and 12/2 UF, 14/2 NM and flat 14/3 NM and 12/2 NM. I've even used them on 10/2 NM a few times without issue, even though they're not really rated for it. These can also strip the individual conductors as well. I've seen these same strippers sold under a German brand name, which makes sense since they there imported from the land that gave us sauerkraut and Ideal just puts their name on them.
http://www.tequipment.net/Ideal45-235.asp
DuMass is offline
Old 01-21-2014, 06:50 PM   #22
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Originally Posted by Xtrememtnbiker View Post
Oh I always bring my strippers...
But for stripping 14/2 or 12/2 how do you do it that's fast than strippers? Pencil style, or ringing it as you called it?
You can't ring solid wire, it really comprises the wire. Pinch twist pull.
Inner10 is offline
Old 01-21-2014, 06:54 PM   #23
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 348
So is ringing it taking your knife and cutting a circle around it then sliding off the jacketing? Always wanting to learn, how does that damage the wire? I've never done it that way btw.
Pinch twist pull with what tool? If it's your fingers... Dang. Haha
Xtrememtnbiker is offline
Old 01-21-2014, 07:01 PM   #24
Inner10's Avatar
If you ring solid copper and your blade scores it all the way around it will snap off very easily...no bueno.
I'll have to make a video to explain.
Solid core:
Dykes: Pinch twist pull or pinch snip both sides then pull.
Knife: sink in the bottom pull straight off, then sink in the top pull straight off...Or pencil.
Linesmans: pinch rotate then grab the insulation and twist off.
Inner10 is offline
Xtrememtnbiker (01-21-2014)
Old 01-21-2014, 07:06 PM   #25
Rewards Points: 348
If you ring solid copper and your blade scores it all the way around it will snap off very easily...no bueno. I'll have to make a video to explain. Solid core: Dykes: Pinch twist pull or pinch snip both sides then pull. Knife: sink in the bottom pull straight off, then sink in the top pull straight off...Or pencil. Linesmans: pinch rotate then grab the insulation and twist off.
A video would be cool. I'm all about what's faster and using less tools to do the job which saves time instead of switching. I just wired my garage today and used strippers and just to rough in a box you have to keep switching tools.
Old 01-23-2014, 11:20 PM   #26
EcHoMaN's Avatar
Trade: Electrical Apprentice
Only takes 2 seconds to switch a tool from a pouch You can always do things in a certain order, like pre stripping the romex sheathing, then stripping the wires with wire strippers, making your curls or leaving straight, shove in your 1104 box, then all you need is your red/green robbie....or
http://www.milwaukeetool.com/hand-to...ves/48-22-1902
EcHoMaN is offline
Old 01-23-2014, 11:32 PM   #27
tyb525's Avatar
Trade: Remodeling and Carpentry
Cut off jacket with knife, use strippers to bare ends in one pull, make the curls, put away strippers and get out the screwdriver.
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 01-24-2014, 12:06 PM   #28
aptpupil's Avatar
Rewards Points: 1,894
All this talk about strippers and not one joke yet. Shame on you guys.
aptpupil is offline
Old 01-25-2014, 12:25 AM   #29
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Yep this is no joke. More than once I had to do a little troubleshooting behind some guy that said..."yeah I can run that. All it takes is twist that wire nut a little too tight and......snap. Luckily it was usually on a neutral and nothing worked caused it was snapped off, but for safety sake I check everything and always find exactly what you are talking about...conductor scored right at the insulation
Irishslave is offline
Old 01-25-2014, 02:48 AM   #30
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
Uhmm.......It actually did go there, and the next day they were all gone. Moderated out of existance.
no wires to house...how can this be done... Pennyroyal's Technology 25 11-28-2011 10:28 AM
Pipes to Attic? Old House Mystery. JRSeifert General Discussion 20 10-15-2011 05:15 PM
Working on a house that's for sale? PierceIdaho General Discussion 10 07-28-2011 04:46 PM
Extreme Makeover House Bergstrom Finish Carpentry 6 10-10-2009 10:49 AM
The coolest house ever? HusqyPro General Discussion 24 08-14-2009 08:45 PM
