Wire Splice? - Page 2 - Electrical - Contractor Talk
Wire Splice?
Old 09-17-2016, 09:19 PM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Wire Splice?
Originally Posted by Philament View Post
There was an episode of This Old House where they toured Ted Benson's timber frame shop where they build all the walls modularly and they used these non-metalic sheathed connectors to prewire the whole house. Not sure if it's applicable in your area, but I had never seen/heard of them before.
It's at 18:44 of the following video
https://youtu.be/l8ePHc5oALU?t=1123
These is a CSA approved version, it's a IDC on both sides and then they click together.
Inner10 is offline
Old 09-22-2016, 03:26 PM   #22
MarkJames's Avatar
Rewards Points: 100
Re: Wire Splice?
So what happens when you find a concealed box on a job?
For example, you're adding a recessed light and when you remove the existing one, you discover an additional box up in the ceiling that's supplying your light? Pretend you don't see it and just continue?
Or you're replace a damaged ceiling and when you pull the old one down, same discovery....and you can't just move it to be flush with the ceiling...then what?
Or you're replacing a vent hood, and presto...there's a hidden metal box back there, too. Just wondering in general what you guys do.
MarkJames is online now
Old 09-22-2016, 03:38 PM   #23
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 14
Re: Wire Splice?
Put it in a proper box, leave an opening in the wall / ceiling and cover it with a return air register.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
MarkJames (09-22-2016), overanalyze (09-23-2016)
Old 09-22-2016, 06:10 PM   #24
Inner10's Avatar
Re: Wire Splice?
If it's behind a recessed light it's considered accessible here.
Inner10 is offline
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
gbruzze1 (09-22-2016), philcav7 (09-25-2016), RedAdobe (10-01-2016)
Old 09-22-2016, 06:16 PM   #25
rselectric1's Avatar
Rewards Points: 926
Re: Wire Splice?
Or something like this. http://www.oatey.com/products/rough-...l/access-panel
They come in many sizes. Just cut the drywall out to the dimensions and glue them in. You can get them at any box store.
rselectric1 is online now
Old 09-22-2016, 06:21 PM   #26
tjbnwi's Avatar
Rewards Points: 256
Re: Wire Splice?
Just went through this. Installing 2 new recessed lights. Was going to Greenfield into the existing ceiling junction box. Customer did not want the box in the ceiling with a cover. Ceiling removed, walls opened, EMT routed to the wall outlets, pulled new wire, drywall, tape, prime, paint.
Easy--peasy.
tjbnwi is online now
Old 09-22-2016, 06:30 PM   #27
Rewards Points: 926
Re: Wire Splice?
Easy--peasy.
Yep, happens on nearly every job for me. Once they get the price for pulling the ceiling and replacing it, you separate the men from the boys.
Most opt to have it pulled and do it right in my case. But at least there is an alternative to offer to save money. This is my go to blank up since it's really hard to spot unless you're looking for it. The metal LIPPED Mulberry blank up.
https://www.gexpro.com/ceiling-boxes...product/125852
The ones without the lip or the plastic ones look like dog crap.
Old 09-22-2016, 07:51 PM   #28
tjbnwi's Avatar
Rewards Points: 256
Re: Wire Splice?
Same cover I use. I put one in their laundry room, they did not one in their family room.
Old 09-22-2016, 08:58 PM   #29
MarkJames's Avatar
Rewards Points: 100
Re: Wire Splice?
You guys are giving easy examples. Sometimes you just can't reroute it without opening up a whole bunch of stuff they insist they won't pay extra to have you do. Then what?
Btw, is it still accessible if somebody down the road won't know where to find it?
How about a box tucked behind a medicine cabinet (removable with 4 screws)? Kosher or not?
Old 09-22-2016, 09:01 PM   #30
MarkJames's Avatar
Rewards Points: 100
Re: Wire Splice?
I always wish there were more sizes and they looked better. Ugly except for basements, closets and utility rooms. (paint doesn't cut it)
Old 09-23-2016, 08:55 AM   #31
tjbnwi's Avatar
Rewards Points: 256
Re: Wire Splice?
The job is permitted. If the inspector won't approve the install the customer has to pay to make it compliant.
They don't want to pay, I don't do the job.
Depends on how you interpret "Accessible". I believe if the medicine cabinet can be removed without damaging the structure you're good. If you have to damage the structure, not good.
http://nfpa.typepad.com/files/70-14article100.pdf
Old 09-23-2016, 12:17 PM   #32
hdavis's Avatar
Rewards Points: 432
Re: Wire Splice?
Yes.
IMO, no - the cabinet winds up being caulked in over time. You can replace the back panel so you can have access, though.
hdavis is online now
Old 09-23-2016, 12:42 PM   #33
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Re: Wire Splice?
Originally Posted by Agility View Post
My electrician recently showed me these. Passes code here. Blew my mind!
Not sure that is done per code.... You can't just use them anywhere. Here is the section in the NEC
334.30(C) Wiring Device Without a Separate Outlet Box. A
wiring device identified for the use, without a separate outlet
box, and incorporating an integral cable clamp shall be
permitted where the cable is secured in place at intervals
not exceeding 1.4 m (41⁄2 ft) and within 300 mm (12 in.)
from the wiring device wall opening, and there shall be at
least a 300 mm (12 in.) loop of unbroken cable or 150 mm
(6 in.) of a cable end available on the interior side of the
finished wall to permit replacement.
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
Agility (09-25-2016)
Old 09-23-2016, 12:57 PM   #34
tjbnwi's Avatar
Rewards Points: 256
Re: Wire Splice?
I've never seen or heard of a caulked in medicine cabinet.
Old 09-23-2016, 01:13 PM   #35
MarkJames's Avatar
Rewards Points: 100
Re: Wire Splice?
You've never removed one where someone had caulked where it meets the wall? Not too uncommon around here.
hdavis (09-23-2016)
Old 09-23-2016, 01:35 PM   #36
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Re: Wire Splice?
If the wall is plumb there should be no reason to caulk it in however I could see where that could be an issue on plaster walls and older homes
Old 09-23-2016, 01:39 PM   #37
480sparky's Avatar
Rewards Points: 14
Re: Wire Splice?
Plumb is one thing. Flat is something else.
The Following 4 Users Say Thank You to 480sparky For This Useful Post:
Big Shoe (10-16-2016), CasaKeepers (09-23-2016), hdavis (09-23-2016), Sisyphus (10-17-2016)
Old 09-23-2016, 01:47 PM   #38
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 4
Re: Wire Splice?
And installed into walls that are textured. Nearly every medicine cabinet I've seen around here/and installed gets caulked.
dsconstructs is offline
The Following User Says Thank You to dsconstructs For This Useful Post:
Old 09-23-2016, 02:04 PM   #39
tjbnwi's Avatar
Rewards Points: 256
Re: Wire Splice?
Not once---ever.
Old 09-23-2016, 02:13 PM   #40
Inner10's Avatar
Re: Wire Splice?
Not once---ever.
I've seen em caulked here, heck mine at home is caulked.
Inner10 is offline
Down Idle wire broke on Rigid pressure washer Jas2012 Pressure Washing 8 06-19-2013 05:31 PM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
