Why Do Sparkies Have To Know Algebra? - Electrical - Contractor Talk
Old 07-08-2015, 05:59 PM   #1
back doors to hell put in
Irishslave's Avatar
Rewards Points: 506
I've met sparkies I know don't know a hypotenuse from a rhombus....so give me some examples
Irishslave is offline
Old 07-08-2015, 06:17 PM   #2
GettingBy's Avatar
Rewards Points: 6,486
Re: Why Do Sparkies Have To Know Algebra?
With intelligence built into test equipment, they don't.
GettingBy is offline
Old 07-08-2015, 07:09 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 506
You can't be serious. Heck, Ohm's Law is an algebraic statement.
Tinstaafl is offline
hdavis (07-10-2015)
Old 07-09-2015, 09:29 AM   #4
Lanya LaPunta's Avatar
Rewards Points: 565
Last I checked (which was probably around 40 to 50 years ago) "hypotenuse" and "rhombus" were terms from Euclidean geometry not algebra.
Lanya LaPunta is offline
The Following User Says Thank You to Lanya LaPunta For This Useful Post:
maninthesea (07-11-2015)
Old 07-09-2015, 11:08 AM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Sparkies have to know Ugly's. That is all.
Carry on.
SmallTownGuy is offline
Old 07-09-2015, 12:45 PM   #6
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Knowing algerbra is the engineer's job.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 07-09-2015, 01:15 PM   #7
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
We did a job that had a 22' sloped ceiling. We had to find the center of the island below but the fixture was held off the ceiling by 2 or 3 inches. (The fixture had a stem coming out of the canopy). I found the roof pitch and did some math to find out how far off I needed to be at the ceiling so that the fixture was hanging dead center.... Made me mad when the builder did it in one tenth the time with his framing square.. LOL
C'est Moi is offline
Old 07-09-2015, 01:32 PM   #8
GettingBy's Avatar
But if he had to do it your way it might take him longer than you took.
These aids can make someone mentally lazy.
When you have the chance, push yourself to beat his time.
And think of situations where his square cannot help him. You may find threads on this forum that ask for help for this very reason.
Old 07-09-2015, 01:37 PM   #9
kiteman's Avatar
Rewards Points: 16
If you had the width and the height at the low and high end you could do it on a calculator in 60 seconds or less
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 07-09-2015, 02:22 PM   #10
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,040
Algebra is a mathematical language.
Geometry is the equations and formulas, expressed using algebra.
Sorry, that's the best I can do on that.
As for why Electrigicians need it?:
Conduit bending
Ohms law
Combination R-L-C circuits, where voltage and current are out of phase with each other
Wire size calculations
Conduit size calculations
Motor load calculations
General load calcs
Transformer calcs and sizing
Circuit testing
I could go on, but I'm getting bored.
Delta
Old 07-10-2015, 01:26 AM   #11
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
what sucks in this field is when our a wiz at the calculations ( my math is sound no fingers or toes needed) but you cant remember the more advanced formula's ! Then you have to go to the book
Red Adobe is offline
Old 07-10-2015, 06:30 AM   #12
Rewards Points: 565
Most geometry, used in the field, is Euclidean Geometry. Euclid's estimated birth was in the fourth century, BC and his death is placed in the third centrury.
Algebra was brought into geometry (assumed), by Rene Descartes. He was born in almost the sixteenth century, AD.
So, electricians do need to know algebra, but their command of geometry could be almost nil.
So, that's why many electricians may not know the difference between a hypotenuse and a rhombus.
Old 07-10-2015, 06:51 AM   #13
Joasis's Avatar
Rewards Points: 904
When I taught aviation maintenance technology, part of the syllabi required teaching the formulas for mass air flow through turbine engines, mass air to fuel weight in consumption....lots of stuff like that....even lift equations on various wing airfoil sections, and then, as now, I am still convinced you can teach whatever math is needed for any application without going into the deep theories behind it.
I know machinists that can get out Machinery's Handbook and calculate how to cut spiral helix gears....some awesome trig at work, and these same guys could not pass algebra 1 in high school.
The math used in flying (as a pilot) can be challenging, but again, you can learn some pretty advanced stuff and never learn the basics behind it. It has worked well for years.
Once electricians use delta formulas, like ohms law, and the P*I*E stuff, then the rest can all be covered by tables and experience.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 3 Users Say Thank You to Joasis For This Useful Post:
hdavis (07-10-2015), Railman (07-10-2015), Rio (08-16-2015)
Old 07-10-2015, 05:54 PM   #14
GettingBy's Avatar
You don't need to know everything, you just need to know where to look it up and how to apply it.
And derive the formulas yourself, if you can.
Old 07-18-2015, 11:22 AM   #15
Tiger's Avatar
Trade: Electrical Contractor
Rewards Points: 718
My new favorite response when fixing the electrical installations of handymen and carpenters applies here:
This is something an apprentice learns in the first year.
In this area you can't enter the program without passing an algebra test. Many of the guys on sites are laborers. They know how to set boxes, drill holes and pull wires, but not much else.
www.TigerElectrical.com
Tiger is offline
Old 07-18-2015, 12:19 PM   #16
cwatbay's Avatar
Rewards Points: 2,562
That is true around here too. Most of the guys running wire, conduit and mounting boxes don't know algebra and barely know simple arithmetic. The foreman knows how to measure, subtract, add and divide, but that's about it too. Back at the office or headquarters they have an engineer that figures all the tough stuff out like algebra, trigonometry and geometry....he's the one that writes out the scope of work and procedures for everyone else.
As for me, I have to know all this stuff (algebra, geometry and trigonometry), plus physics, engineering, accounting, management and so forth.
cwatbay is offline
Old 07-18-2015, 12:41 PM   #17
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
For the most part we do not use algebra very often except perhaps for ohms law. Geometry a bit but really depending on your job you don't need it. We do residential wiring and there is seldom a need for any of that.
You can still be a good electrician and not know geometry or complex algebra. Myself, I took calc 3, linear algebra, differential equation and I quit my math major when I was supposed to take abstract algebra. Linear algebra and differential equations was abstract enough for me. Never needed it.
Old 08-14-2015, 07:13 PM   #18
saynever's Avatar
Trade: electrical
Rewards Points: 229
Voltage drop?
Pipe work (concentric bends, segmented bends, basic offsets etc).
Lighting layout
Ohms law equations
The ability to build things (electric room installs, switch yards, etc) that are plumb level and square.
I dunno. Numerous tasks. If we didn't have math we would all be pushing a broom, no offense.
Most basic tasks required math in construction. Most formulas use algebra. I like my wires cool and pipes looking good.
saynever is offline
Old 08-14-2015, 07:26 PM   #19
jb4211's Avatar
Rewards Points: 2,306
Algebra example:
Tommy has two apples
He gives one apple to Bob
How many peaches does Susan have?
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
BeenAround (09-10-2015)
Old 08-14-2015, 07:44 PM   #20
saynever's Avatar
Trade: electrical
Rewards Points: 229
How old is Susan?
saynever is offline
The Following 3 Users Say Thank You to saynever For This Useful Post:
digiconsoo (08-14-2015), jb4211 (08-14-2015), Rio (08-16-2015)
How many sparkies are conduit bending experts? Irishslave Electrical 29 10-16-2015 08:06 AM
Help me sparkies. dayexco Electrical 13 06-04-2015 03:59 PM
Question for the Sparkies on Garage doors SDC Electrical 3 09-18-2010 11:04 AM
need help with algebra Gus Dering Carpentry 69 03-28-2010 11:55 AM
Craigslist rates for plumbers & sparkies tcleve4911 General Discussion 10 03-17-2010 09:32 AM
