Whole House Wired - Electrical - Contractor Talk
Whole House Wired
Old 01-20-2014, 06:23 AM   #1
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Whole House Wired
going back to a new home today that the whole house is wired with 12 2 with ground nm. all switches and outlets are on 20 amp breaker. the sparky said that this builder has been doing it for some time now.have you seen or did it. sparky did say that the light fixtures were rated at 20 amp.
pappagor is offline
Old 01-20-2014, 07:57 AM   #2
tyb525's Avatar
Trade: Remodeling and Carpentry
Re: Whole House Wired
We always use 12-2 or bigger, never 14.
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 01-20-2014, 08:26 AM   #3
txgencon's Avatar
Rewards Points: 432
Me, too. One city in my area (Waxahachie) requires it (minimum #12).
I call BS on the 20 amp rated light fixtures. Perhaps he meant light switches.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 01-20-2014, 09:10 AM   #4
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
#12 is the norm here as well.
Makes for less wire carried on the truck so I like it
Red Adobe is offline
Old 01-20-2014, 09:14 AM   #5
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 758
If its what your area requires then great. Our electrician does the lighting circuits and bedrooms on 14g on 15 amp breakers. Everything else is 12g with 20 amp. If your house is split up nicely, 14g will never be a problem. Really it comes down to what your sparky wants to do.
overanalyze is offline
Old 01-20-2014, 09:14 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,152
12 commercial 14 residential here.
Inner10 is offline
Old 01-20-2014, 09:26 AM   #7
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,772
Originally Posted by pappagor View Post
.......... sparky did say that the light fixtures were rated at 20 amp.
Hilarious. Have some fun and ask for proof.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 01-20-2014, 10:29 AM   #8
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,470
For what little residential we do, I use 12awg for everything, based on load that will use a 20amp breaker. So lighting and circuits (other than stoves, dryers, etc that use higher loads) we use 20amp breakers.
Exceptions are when we work on existing circuits that already have 15amp breakers and 14awg wiring, then we keep all those the same.
cwatbay is offline
Old 01-20-2014, 10:40 AM   #9
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
You electricians are a lazy bunch
jlsconstruction is offline
Old 01-20-2014, 11:16 AM   #10
480sparky's Avatar
Originally Posted by jlsconstruction View Post
you electricians are a wildly efficient bunch
fify.
The Following User Says Thank You to 480sparky For This Useful Post:
jlsconstruction (01-20-2014)
Old 01-20-2014, 11:25 AM   #11
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
I used 12/2 on everything as well, sure it's harder to bend but atleast it won't break when you do it!
FRAME2FINISH is offline
Old 01-20-2014, 11:34 AM   #12
480sparky's Avatar
Anyone who routinely breaks either 12 or 14 when wiring a house is doing something terribly wrong.
The Following 6 Users Say Thank You to 480sparky For This Useful Post:
Dustincoc (01-23-2014), Eric K (01-20-2014), JumboJack (01-21-2014), Mac13 (01-29-2014), slowsol (01-20-2014), woodchuck2 (01-21-2014)
Old 01-20-2014, 11:34 AM   #13
CarpenterSFO's Avatar
Rewards Points: 2,044
Pappagor:
Do you mention that because you had a question about the potential legality/code compliance? If you are, then no, there's not a problem wiring a lower amp lighting fixture into a 20-amp branch. Your sparky might have said that in order to assure you that they were legal, and couldn't think of a better way to express it, so he BS'd some.
- Bob
CarpenterSFO is offline
Old 01-20-2014, 12:29 PM   #14
pcijohn's Avatar
Trade: electrician, plumber
Rewards Points: 18
Here in Western NC, We usually see #12 and #14, but the 14 is usually just for lighting circuits.
pcijohn is offline
Old 01-20-2014, 02:46 PM   #15
Thom
thom's Avatar
Rewards Points: 4,748
Though we may use a 15A breaker if we choose, all circuits with receptacles must be #12 minimum. We use #12 throughout with the exception of the smoke detector circuit which is #14 on a 15A breaker.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 01-20-2014, 03:26 PM   #16
480sparky's Avatar
Originally Posted by thom View Post
......all circuits with receptacles must be #12 minimum. .......
Local code?
Old 01-20-2014, 03:47 PM   #17
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
I had a BI who used to argue/discuss that receptical circuts should be limited to 15A.....
His argument was that why do you want to pump 20A to a lamp cord that could short to a person with 20A rather than 15A or would not trip untill 20+ amp.
I guess his best argument would be #12 on a 15 breaker as far as safety is concerned.
(He did not dispute code or anything, just would argue that way.)
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 01-20-2014, 03:51 PM   #18
480sparky's Avatar
Eh.
15 amps.
20 amps.
You're dead just the same.
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
CarpenterSFO (01-20-2014), MTN REMODEL LLC (01-20-2014)
Old 01-20-2014, 03:57 PM   #19
Originally Posted by 480sparky View Post
Eh.
15 amps.
20 amps.
Yep, it only takes fraction of an amp to kill you. A GFI is more likely to save your life than an overcurrent breaker.
- Bob
Old 01-20-2014, 04:02 PM   #20
480sparky's Avatar
Only difference is 15 or 20 amps may cook you, depending on how long you "stay on the grill". You'll smell like a BBQ at your (closed casket) funeral.
no wires to house...how can this be done... Pennyroyal's Technology 25 11-28-2011 10:28 AM
Pipes to Attic? Old House Mystery. JRSeifert General Discussion 20 10-15-2011 05:15 PM
Working on a house that's for sale? PierceIdaho General Discussion 10 07-28-2011 04:46 PM
Extreme Makeover House Bergstrom Finish Carpentry 6 10-10-2009 10:49 AM
The coolest house ever? HusqyPro General Discussion 24 08-14-2009 08:45 PM
