What The Worst Electrical Safety Issue You Have Seen? - Page 2 - Electrical - Contractor Talk
Old 06-16-2007, 11:32 PM   #21
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Re: What The Worst Electrical Safety Issue You Have Seen?
Originally Posted by pulpfiction32 View Post
anyone used those new in wall splices i saw them in the supply house the other day how can they be legal
Are you referring to a flying splice ?
skyhook is offline
Old 06-16-2007, 11:39 PM   #22
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
Not exactly...
http://www.smarthome.com/7104.html
Something like that item.
Celtic is offline
Old 06-17-2007, 02:59 PM   #23
w6ire's Avatar
Trade: Data Cabling - Fire Alarms
Rewards Points: 25
Originally Posted by mdshunk View Post
Thanks for that tidbit. Surely you know that electricians are prima donnas? Consequently, if you want to puch me or something "unexpected" like that, PM me and I'll give you my home address. I'm a real man too. I'm not as much wound up as I simply don't tolerate incorrect information very kindly, particilarly from someone who operates in California.
The switch location in the photo is NOT a wet area, or many other building code matters related to wet areas would have come into play.
I don't know what "puch" means, but here in California no electrical inspector would approve that installation. Go to iccsafe.org and post the pic there and see what real electrical inspectors would do.
I do know that electricians are prima donnas, and as a prima donna I can't tolerate you having an opinion contrary to mine.
w6ire is offline
Old 06-17-2007, 03:39 PM   #24
JamesNLA's Avatar
Trade: Plumbing & Electrical
Rewards Points: 516
Wire6.....Relax guy.
Don't take being incorrect as a personal attack. MD is probably one of the most knowledgeable electricians you will ever have the privlidge of communicating with. And deep down he does like guys from CA!!!LOL
As for your topic, it will pass. I have seen worse pass. If it didn't pass, a code site would be requested and the inspector would be wrong. That switch is clearly out of the "wet" area. It's a crap install, but a legal one.
Myself and many others have challanged MD on a number of issues related to electrical (and other trades) and he is almost always correct. Yeah, it gets annoying after a while but his info is sound.
If you really want to make this site work for you, ask him in detail to explain why it's legal, and how it would have needed to be to not be legal.
Just my .02
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 06-17-2007, 03:56 PM   #25
Remodeler Extraordinare
A.W.Davis's Avatar
Rewards Points: 510
MD is somebody you want on your side unless your an idiot!
maybe you are!
A.W. Davis Construction Co.
http://www.awdavisremodel.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 06-17-2007, 08:43 PM   #26
Fentoozler
Celtic's Avatar
... here in California no electrical inspector would approve that installation. Go to iccsafe.org and post the pic there and see what real electrical inspectors would do.
Unless these inspectors you speak of are using some other set of rules not contained within the NEC, the install is 100% legitimate and passes NEC code with flying colors.
Celtic is offline
Old 06-20-2007, 08:00 PM   #27
bobelectric's Avatar
Trade: Electrician
My neighbor is a nuclear electrician. On his home, he had a breaker weld itself to the bus bar. He was standing in a puddle of water trying to remove it from the live 100 amp panel with a pair of pliers......
Is a nuclear electrician superior to any other elecrtician?
bobelectric is offline
Old 06-20-2007, 09:18 PM   #28
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
"Is a nuclear electrician superior to any other elecrtician?"
Probably not, but he would apparently be less conductive.
reveivl is offline
Old 06-20-2007, 10:56 PM   #29
JCardoza's Avatar
Trade: Drywall/Texture
Rewards Points: 25
I was doing the drywall on a job once and the power CO came out and switched the house over from the temp to the main panel... Without any breakers in the panel (except for the main) without any cover etc... (But that's all normal for our area for some dumb reason.) Any way I carry a spare breaker for reasons such as this and so I went to snap it into the panel and bumped the main ground wire before I turned off the main breaker. Well apparently the main ground wire had never been connected and was just hanging loose in the panel because it swung over and hit the hot terminals. Good thing I was wearing a full spray suit mask and gloves, because I got showered in molten metal! Melted all into my hat and suit... I'm sure they had to replace something. Several of the terminals were toast. Maybe the electrician will be more carefull next time... Maybe.
JCardoza is offline
Old 06-21-2007, 12:01 AM   #30
Fentoozler
Celtic's Avatar
LMAO..sure...blame the electrician.
You're lucky you're not dead.
See quote below VVV
Celtic is offline
Old 06-21-2007, 04:59 PM   #31
SmithBuilt's Avatar
Trade: Commercial/Residental Construction
Rewards Points: 75
Someone had install gas installed at a house I worked on today. The electrician had to install a new outlet for the logs. He had run it outside the house along the wall about 50' of uf wire. Maybe secured it in 5 places, and 4 of those were zip ties to a gas line for the logs. Obviously no permit.
I ask the homeowner about it she, had us redo all of it.
SmithBuilt is offline
Old 06-22-2007, 01:47 PM   #32
mickeyco's Avatar
Trade: Squirrel Handler
I'd like to think they are, but from skyhook's post it would appear they might be a little dumber.
mickeyco is offline
Old 06-22-2007, 01:51 PM   #33
Old Guy
househelper's Avatar
Trade: Electrician (semi-retired)
Rewards Points: 25
Yes. They glow in the dark.
househelper is offline
Old 06-22-2007, 06:46 PM   #34
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
See quote below VVV
Why am I not suprised that this guys a sheetrocker?
By the way, whats up with the power company juicing up a panel without a final service inspection (or did the inspector not see that the neutral conductor wasn't tied in)? Whenever I do a service in new construction I almost always leave one circuit breaker controlling one GFCI receptacle beneath the panel so the sheetrockers don't have happen what happened to this guy.
Magnettica is offline
Old 06-22-2007, 06:48 PM   #35
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Today I saw a white "positive" tied into a breaker, and the black "negative" tied into the neutral buss.
Old 06-22-2007, 07:01 PM   #36
Celtic's #1 Fan
mahlere's Avatar
Trade: electrical
maybe you are!
yeah! if we're gonna rumble, he's got your back... wtf is this? high school?
No offense to MD, he's a smart guy who either knows alot, or is good with google, but if wasn't here....then what?
FTR...I like marc's answers...i especially like when he misses his meds and gets mean...then it's funny.
mahlere is offline
Old 06-22-2007, 09:45 PM   #37
skeeter's Avatar
Trade: electrician
To many scary instances to list them all, but heres 3 1) Grandma gets shocked in the nursery visiting here new grandchild because the supposed licensed electrician didn't think to bond to building steel on a 480 to 208VAC transformer.
2) I found all sub panels in a new building bonded to neutral.
3) Same job I opened a gutter with neutrals all tied together for 2 to 3 circuits for each phase.
skeeter is offline
Old 06-22-2007, 09:59 PM   #38
skeeter's Avatar
Trade: electrician
you prove the point that drywallers have no business in an electrical panel. And shame on the electrician who left a panel wide open to get turned on like that.
skeeter is offline
Old 06-23-2007, 04:58 AM   #39
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Rewards Points: 720
well I don't know if this is scary or not- but we are currently buying a house, 19 yrs old. We hired a house inspector- he found a 60 amp breaker on the "main" and a 100 amp breaker on the "sub" this seems backwards to me somehow- we are hiring an electrician to fix this-
also what do you guys think of "trane" (spelling might be wrong) we have to replace the furnace (gas) and we were thinking of a heat pump type of thing, one of our friends recommended a "trane" brand.
thanks
Mac.
Mrmac204 is offline
Old 06-23-2007, 06:52 AM   #40
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
POCO here will not install the meter without a panel cover. A temp outlet is also required for service inspection. (residential)
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Electrical License in PA ABLE1 Low Voltage 29 10-25-2010 11:20 AM
New OSHA standard OsNap Health & Safety 8 01-08-2010 09:19 PM
Safety Certification... theworx General Discussion 5 07-05-2008 12:03 AM
Electrical safety quiz mickeyco Electrical 35 12-29-2006 01:11 PM
On discouraging DIY electrical work... mdshunk Electrical 52 02-18-2006 12:58 AM
