Walk-in Tub On Arc Fault Circuit - Electrical - Contractor Talk
Old 11-27-2018, 11:09 PM   #1
MarkJames's Avatar
Rewards Points: 20,159
I'm meeting with my electrician later in the week on this, but am curious now.
Home inspection says that the motor of a walk-in tub (as seen on tv) appears to be protected by an Arc fault breaker. They want Fit GFCI protected.
Would that be simply done by adding a GCI prior to the motor, or do I need a feed from a non-AFCI protected circuit?
Thanks.
MarkJames is offline
Old 11-27-2018, 11:36 PM   #2
tjbnwi's Avatar
Re: Walk-in Tub On Arc Fault Circuit
You can add a GFI, you can do a combo unit, if it's a 2 pole circuit you didn't need the AFI.
tjbnwi is online now
MarkJames (11-28-2018)
Old 11-28-2018, 11:43 AM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
If I recall all those jetted tubs etc need to have a GFI and the last one I installed had its own 10ft grounding rod per code.
Still "Shakin" the tree boss
sunkist is offline
Old 03-14-2019, 12:55 AM   #4
Shocking20's Avatar
Trade: Electricial
10ft? Seems kind of long yes if there is a ground fault you want it to get to ground fast!
Shocking20 is offline
Old 03-14-2019, 08:45 AM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 13,028
And ground rods are NOT for that purpose. Ground rods are TERRIBLE for clearing faults. So terrible, they're not allowed to be used as such.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 03-17-2019, 04:39 PM   #6
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Sounds like the unit is 120v so it would need gfci but afci is not required in a bathroom. I assume that is where it is being installed.
C'est Moi is offline
Excess recessed lights on same circuit MarkJames Electrical 42 02-09-2013 04:55 PM
Can You Convert Glass Fuses To Circuit Breakers tonytnt Electrical 18 07-11-2010 05:06 PM
Adding external controller and pump to water heater circuit? protechplumbing Electrical 5 05-12-2010 11:31 PM
Should I Shop At Circuit City For Deals Right Now??? Ed the Roofer General Discussion 13 02-05-2009 07:23 PM
New Basement Circuit dcapone Electrical Picture Post 16 09-30-2008 03:13 PM
