Tricky Conduits - Electrical - Contractor Talk
Tricky Conduits
Old 03-29-2015, 04:52 PM   #1
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,640
Tricky Conduits
Every once in a while I run into a conduit that is an absolute nightmare to fish, last Friday was no exception.
Any long runs of sealed conduit I find it's fastest to blow a dart through.
EMT's fittings are so leaky that blowing a line through really doesn't work well. Therefor I opt to use an Ideal vinyl coated steel cable fish.
If I can't get it through I put a loop of wire on the end of the fish tape, send it as far as it will go, then take another fish tape, put a hook on it and send it down the other end and hope to hook it when I pull it out.
This time I have about a 120 foot run of 1-1/4", in the middle I'm guessing there are two back to back 90s separated by probably 15 feet. I get hung up in both directions.
Any tricks out there?
Inner10 is offline
Old 03-29-2015, 05:08 PM   #2
Inner10's Avatar
Re: Tricky Conduits
Out of curiosity would it increase suction and CFM if I daisy chained three rigid shop vacs together in series?
Inner10 is offline
Old 03-29-2015, 05:36 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Tricky Conduits
Nothing you probably haven't tried. If the fish won't go, you're stuck with blowing things through. Darts: suck from one end, blow from the other. Send a second one it to try to jar the first one loose. Use extremely light line - a few times I've sent sewing thread through. All sorts of jiggling and teasing the line to get it to slip past the burrs and whatever other crap is in there.
I've gotten to appreciate one building we work in, where you simply shove the fish in until it bumps the other side of the box at the other end.
- Bob
CarpenterSFO is offline
Old 03-29-2015, 05:38 PM   #4
Inner10's Avatar
Re: Tricky Conduits
Sewing thread is a great idea....I may even try braided fishing line.
Inner10 is offline
CarpenterSFO (03-29-2015)
Old 03-29-2015, 05:52 PM   #5
tjbnwi's Avatar
Rewards Points: 392
Re: Tricky Conduits
I find sandwich bags without the zipper tied to the string work best for sucking a string through 1" or less. On your 1-1/4 I'd use a plastic grocery bag.
Best pulling lube---baby powder.
tjbnwi is offline
dkillianjr (03-29-2015)
Old 03-29-2015, 06:18 PM   #6
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Tricky Conduits
I'm betting rigid vacs would work better than flexible vacs...
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 03-29-2015, 06:38 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 86
Re: Tricky Conduits
If I'm installing the conduit and suspect it might be tough to fish when finished, I run at least one line as I'm assembling it. Makes assembly a bit slower, but pulling is pretty much a breeze after that.
Tinstaafl is offline
Old 03-29-2015, 06:40 PM   #8
Inner10's Avatar
Re: Tricky Conduits
That's really not going to help me this time...I didn't run the pipe the sparky did.
Inner10 is offline
m1911 (03-29-2015)
Old 03-29-2015, 06:42 PM   #9
m1911's Avatar
Re: Tricky Conduits
I'm guessing the last installer wasn't that considerate...
m1911 is offline
Old 03-29-2015, 06:50 PM   #10
Inner10's Avatar
Re: Tricky Conduits
He sure wasn't, and I'm pretty sure he used all pre-fab 90's...so there is probably 20 joiners that leak air like a bastard.
Inner10 is offline
Old 03-29-2015, 06:56 PM   #11
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Tricky Conduits
I think that would work if they were in parallel, not series...
-Steve
TimelessQuality is offline
Old 03-29-2015, 07:35 PM   #12
GettingBy's Avatar
Rewards Points: 6,486
Re: Tricky Conduits
With sucking you're limited to 14.7 PSI which is 18 lbs, abs. max with a perfect vacuum, pushing on a 1-1/4" dia. plug. With leaks you'll never get there.
Use compressed air at whatever PSI and CFM to overcome the leaks and push some kind of made or bought shuttlecock.
GettingBy is offline
The Following User Says Thank You to GettingBy For This Useful Post:
TimelessQuality (03-31-2015)
Old 03-29-2015, 07:45 PM   #13
Inner10's Avatar
Re: Tricky Conduits
Originally Posted by GettingBy View Post
With sucking you're limited to 14.7 PSI which is 1.2 lbs pushing on a 1-1/4" dia. plug.
Use compressed air to push some kind of made or bought shuttlecock?
I have darts just not for 1-1/4"
In general it's hard to blow through EMT because it's so leaky.
I think I'l try CarpenterSFO's idea of sucking and blowing.
Inner10 is offline
Old 03-29-2015, 07:49 PM   #14
m1911's Avatar
Re: Tricky Conduits
I think Bob's thin lightweight string idea is best.
m1911 is offline
Old 03-29-2015, 08:21 PM   #15
Home wood's Avatar
Trade: carpentry
Rewards Points: 386
Re: Tricky Conduits
Grocery bag to make a parachute, tie braided fishing line then push with air compressor.
No shop vac can compare to 90 psi pushing the bag through.
How long is the run?
I once had a buried line in a parking lot. We though for sure it was broken.
Had the vac on it and couldn't feel any suction at all.
In last ditch effort I tuck taped an air hose to it. We had 120psi on it wen it finally shot the grocery bag out the other end along with a 20' fountain of water.
I was soaked but still happy that we didn't have to cut new asphalt.
Home wood is offline
Old 03-31-2015, 07:05 AM   #16
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 218
Re: Tricky Conduits
A new fish tape can work wonders. A small amount of rust and a few small kinks in the tape can cause trouble.
On pipe larger than 1" I also put 2 -45* bends near the head to make the tape fill the conduit.
You may also want to try a 1/4 inch tape instead of the stock 1/8
TxElectrician is offline
Old 03-31-2015, 07:10 AM   #17
GettingBy's Avatar
Re: Tricky Conduits
That's what I thought but there is a system designed for this that advertises 3 PSI, 300 CFM and it takes 3 kw.
Old 03-31-2015, 02:33 PM   #18
Inner10's Avatar
Re: Tricky Conduits
I was using an Ideal Zoom which is the best fish tape I've ever used for conduits.
Bob wins, I attached fishing line to a dart and blew it through with a compressor in about 10 seconds. Only part that sucks is it was 20 dollar fishing line lol.
Inner10 is offline
CarpenterSFO (03-31-2015)
Old 03-31-2015, 06:53 PM   #19
Re: Tricky Conduits
Seems like a standard C.T.-style multi-contributor solution. Glad it worked. I'll trade $20 for an hour less cursing any time.
- Bob
The Following 2 Users Say Thank You to CarpenterSFO For This Useful Post:
TxElectrician (03-31-2015), Xtrememtnbiker (03-31-2015)
Old 03-31-2015, 07:09 PM   #20
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Tricky Conduits
I have zero knowledge in this area.
But a few months back, my sparky was talking about a similar issue.
H used the plug type sponges. put three in series , like 2 feet apart.
If one leaked the others would seal . ( suck and blow , sounds right )
Not sure if it makes and sense to somebody who has done it.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
CT wizard exam tricky true or false quest ssroofpros Roofing 74 05-06-2017 04:59 AM
Repairing Melamine Cabinets - Tricky Repair artinall Carpentry 5 03-05-2015 11:45 AM
Need Advice on low slope and tricky situation NCFHOME Roofing 9 02-25-2015 10:12 AM
Tricky wiring Milhaus Electrical 26 11-14-2012 06:33 PM
Tricky crown mitre cuts balbert Finish Carpentry 7 09-05-2008 12:20 PM
