Those "8-32" Screws That Come With Light Fixtures - Electrical - Contractor Talk
Old 09-04-2015, 05:43 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,367
Just wondering....
...are the screws that come with light fixtures really supposed to be 8-32's or are they something else? They are such wobbly [email protected], being a hair narrower. What's the story? Are they really intended for the screwing the crosspiece into the jbox? I always use my own screws that are more snug, but just wondering why they supply that junk.
MarkJames is online now
Old 09-04-2015, 05:50 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 860
Re: Those "8-32" Screws That Come With Light Fixtures
cuz the DIY'ers don't have their own screws like most of us do....
griz is online now
Old 09-04-2015, 05:52 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 548
Wow, you get screws for that?
If supplied, the screws usually work well for metal boxes. With plastic boxes, I usually wind up using short deck screws.
Tinstaafl is online now
Old 09-04-2015, 05:56 PM   #4
MarkJames's Avatar
I'd have to disagree. They're too loose for metal boxes most, if not all of the time. More peace of mind to spend $10 box of 8-32's in the electrical aisle.
Old 09-04-2015, 06:00 PM   #5
MarkJames's Avatar
On the plus side, I think it adds to DIY uncertainty. Just like the lousy wall anchors in TP holder packs.
Rio (09-05-2015)
Old 09-04-2015, 06:07 PM   #6
CarpenterSFO's Avatar
Rewards Points: 2,044
Pure economics - they save $10 on every 3 billion boxes, by supplying crappy screws.
- Bob
CarpenterSFO is offline
The Following 3 Users Say Thank You to CarpenterSFO For This Useful Post:
cwatbay (09-05-2015), MarkJames (09-04-2015), Rio (09-05-2015)
Old 09-04-2015, 06:29 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Fixture boxes come with their own screws.
Inner10 is offline
Old 09-04-2015, 06:49 PM   #8
MarkJames's Avatar
Old 09-04-2015, 06:51 PM   #9
MarkJames's Avatar
Yes, of course. And I use them if they're still there. But in old houses, after years of lighting swaps, you see everything else, too. Today I replaced a hunter ceiling fan who's mounting plate was lagged into plaster and barely into wood. It came loose as soon as started to unscrew it.
Old 09-04-2015, 07:02 PM   #10
Tom M's Avatar
Rewards Points: 8,664
I thought outlets and devices used 8/32 , covers use 6's and fixture bracket are 10
Tom M is online now
Old 09-04-2015, 07:10 PM   #11
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
the problem may be in the old boxes...........or your buying junk fixtures.
I dont run into often but sometimes some jackhole cross threads.
Buy long 8-32 and you can always cut them down......theres always a handfull in my toolbags just incase.
Red Adobe is offline
The Following User Says Thank You to Red Adobe For This Useful Post:
mikeswoods (09-06-2015)
Old 09-04-2015, 07:12 PM   #12
Inner10's Avatar
No, single gang device boxes are 6-32, octagonal fixture boxes, 4" and 4-11/16 are 8-32.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Speedy Petey (09-05-2015), Tom M (09-05-2015)
Old 09-04-2015, 08:15 PM   #13
MarkJames's Avatar
It's definitely the cheap screws that come with these fixtures, like typical bix box stuff and lots of online stuff, too. It's not from cross-threading ( or hardly ever, anyway) because better screws work perfectly. Yes, I cut them if necessary, really like my Kleins.
Old 09-05-2015, 08:05 AM   #14
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Probably 99.5% of cheap light fixtures are made in China or some other third-world Asian country. Quality is usually nonexistent.
The "steel" those screws are made of is only slightly tougher than aluminum.
I would imagine the tooling used to make the screws is what you'd call accurate. They are nearly all undersized and can be infuriating to use.
Speedy Petey is offline
The Following User Says Thank You to Speedy Petey For This Useful Post:
MarkJames (09-05-2015)
Old 09-05-2015, 10:52 AM   #15
rrk's Avatar
Rewards Points: 3,588
A friend of mine owns a manufacturing co. , they sometimes change dies every day depending on production. The China co.s change them monthly if that. When the dies are worn and the screw is off sized sometimes you are nearly stripping the box the first time you put the screw in.
rrk is online now
Old 09-05-2015, 11:43 AM   #16
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,562
I have a couple compartment boxes of electrical screws for fixtures, outlets, switches, boxes, etc. of various lengths. They always go in with me on those types of jobs. And, about half the time, I need to cut to length.
cwatbay is offline
Old 09-05-2015, 01:01 PM   #17
Tom M's Avatar
So where are the 10's used? I know I have acquired some from exterior flood lights and maybe inside the box? those screws for wire clamps.
Tom M is online now
Old 09-05-2015, 01:50 PM   #18
MarkJames's Avatar
I clipped this from elsewhere:
6-32 screws will generally be used to screw receptacles and switches into plastic boxes and steel mud rings, they are also used to attach cover plates to miscillaneous devices (receptacles and switches).
8-32 screws will commonly be used in steel electrical boxes (4" square and larger)
10-32 screws will commonly be found in light fixtures and most ground screws have 10-32 threads
1/4-20 and 3/8-16 are more bolts than screws....they will generally be used to bolt equipment to walls, floors, etc...
Tom M (09-05-2015)
Old 09-05-2015, 03:23 PM   #19
Trade: Electrical
Sort of.
6-32 - Device mounting and plates
8-32 - Fixture and general junction box screws; 4"sq, 4" oct, 4-11/16"sq
10-32 - Ground screws, clamp screws on metal gem boxes, fan box screws (NOT generally found in light fixtures)
10-24 - Fixture mounting screws on most round weatherproof boxes
Tom M (09-05-2015)
Old 09-05-2015, 11:08 PM   #20
avenge's Avatar
Rewards Points: 226
But they are usually gone by the time I get to it, that's why I carry them with me because the lighting company figures they'll be there also and they don't supply them either.
avenge is online now
Panasonic bathroom fan light ballast troubles dale rex Electrical 3 02-15-2014 11:37 AM
Best 12V cordless drill LIGHT ??? lewisthepilgrim Tools & Equipment 10 12-19-2013 10:11 PM
Light activated exterior lighting wallmaxx Electrical 9 05-10-2013 04:50 PM
Home owners supplying their own fixtures 3 T,s Plumbing Plumbing 47 02-04-2011 04:54 PM
