Thermostat For Electric Floor Heat - Electrical - Contractor Talk
Old 11-09-2018, 09:16 AM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 232
We installed an electric radiant floor heat system (20 years ago). I got a call from the customer earlier this week saying the floor was cold. I went and checked, and the thermostat says itís heating (set for 82 degrees) but the floor temp was 63.
There has been no work done in or around the bathroom (no indication that anything could have damaged the wire Ė the floor tile is all intact).
Is this probably a thermostat that just gave up? Other than 120 vs. 240, is there any other consideration I should be cautious of when ordering a replacement?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 11-09-2018, 09:36 AM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,438
Re: Thermostat For Electric Floor Heat
Time to check the leads to the floor with a multimeter. Many thermostats are both 120 and 240.
Half of all people are below average.
Golden view is offline
DaVinciRemodel (11-09-2018)
Old 11-09-2018, 10:18 AM   #3
hdavis's Avatar
Rewards Points: 1,882
Jump the thermostat so you know it's calling for heat. Zone valves and circulators can easily go in 20 years.
hdavis is offline
Old 11-09-2018, 12:16 PM   #4
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 634
Think it might be the temp sensor in the floor? Those things go and then the thermostat doesn't know what temp the floor really is. We always put a second sensor in the floor when we do these for just this reason. Having a second sensor already in saves tearing up any tile, and having a little wire taped up in the back of the box isn't much hassle.
Hope it's not the sensor!
SPG is offline
The Following 3 Users Say Thank You to SPG For This Useful Post:
Anderson (11-10-2018), overanalyze (11-09-2018), tang (11-09-2018)
Old 11-09-2018, 05:37 PM   #5
edward trowelhands
Trade: Diplomat
If it's the sensor, there are thermostats that can also just air source for heat call. Not as good, but at least gets the heat on.
Old 11-09-2018, 08:09 PM   #6
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,186
They won't work. As soon as the air temp satisfies the stat, it turns off. Then the floor gets cold.
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is online now
Old 11-09-2018, 09:08 PM   #7
Rewards Points: 232
I can jump the thermostat, I just hope the homeowner doesnít walk into the room while Iím doing it. That would be embarrassing...
Not sure how many zone valves and circulators we have in an electrically heated room of 140 SF.
The Following 3 Users Say Thank You to DaVinciRemodel For This Useful Post:
Anderson (11-10-2018), overanalyze (11-09-2018), rrk (11-10-2018)
Old 11-09-2018, 09:10 PM   #8
Rewards Points: 232
The thermostat says the floor is 63 so I think the sensor is fine.
Old 11-09-2018, 09:18 PM   #9
Rewards Points: 232
I have three small rooms in my house with electric floor heat and I only monitor the room (air) temp. Been working just fine for years. Regardless, I think the sensor is fine (see above).
I took the thermostat apart today. Hooked up my Loud Mouth. The wire seems to be fine.
I just ordered a new thermostat today, hope this fixes the problem.
https://www.amazon.com/Honeywell-TH1...ube+thermostat
Old 11-09-2018, 09:21 PM   #10
hdavis's Avatar
LOL, I was thinking hydronic - brain fart.
Carry on.
hdavis is offline
Old 11-09-2018, 11:49 PM   #11
edward trowelhands
Trade: Diplomat
They work better than you'd think. At a given floor temp, the air will be a given temp. And visa versa.
I build a half dozen structures with radiant heat as the sole heat source, and an air thermostat as the only thermostat. No temperature swing issues at all.
Old 11-10-2018, 08:01 AM   #12
480sparky's Avatar
There's a difference between floor heat that is designed to heat the room and floor heat that's designed to warm just the floor.
Old 11-10-2018, 09:49 AM   #13
edward trowelhands
Trade: Diplomat
Either way, when you warm the floor, you heat the room.
People often want their floors at 80-86 degrees, but then the room is too warm, so they fiddle with it until the room is right. In some cases they'd rather just use the air temp.
Old 11-10-2018, 09:51 AM   #14
480sparky's Avatar
Either way, when you warm the floor, you heat the room.........
You will not heat the room, but simply add a bit of heat to it. Floor heat designed to take the chill off a tile floor will never heat the room enough to satisfy a traditional room-temp stat.
If there's a sensor in the floor, then the heat system was never intended to heat the room.
Old 11-10-2018, 10:12 AM   #15
edward trowelhands
Trade: Diplomat
Except in 100% of the installations I've completed.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
DaVinciRemodel (11-10-2018), rrk (11-10-2018)
Old 11-10-2018, 10:14 AM   #16
480sparky's Avatar
Then you don't comprehend the difference between the two.
Old 11-10-2018, 10:22 AM   #17
edward trowelhands
Trade: Diplomat
I think I do. I do software based heat load calculations or entire thermal envelopes and room by room. Granted, the 18 or 25 BTU per square foot that I'm getting out of my floors isn't much by old standards, it does satisfy the coldest day heat load of most modern homes in most environments.
Lots of windows, high ceilings, frequent fenestration openings (foyer, public space, etc) would change the requirements. But for a bathroom in a house, a floor is generally a suitable sole source of heat.
Now, one may prefer to save a few bucks a year by splitting the heat load between a gas furnace and the electric resistive floor heat running at 3x the cost. But you have to balance the desire for the floor to be in the 80s to actually feel warm (remember what your body temperature is) and the fact that once it's that warm it pretty much heats the room already.
Old 11-10-2018, 10:28 AM   #18
edward trowelhands
Trade: Diplomat
I will admit that I don't think it's good practice to only do electric floor heat. I'd rather give the control and option of using the house's heating system, plus the redundancy gives peace of mind. Electric floor heat is harder to repair when it fails, if the failure is a corroded wire from nicked insulation under the tile.
Old 11-10-2018, 06:26 PM   #19
tjbnwi's Avatar
Rewards Points: 644
Laticrete makes a system that is for full room heating. The t-stat gives you the option of air or floor sensor.
I install 2 sensors, had one client request 4 sensors with his install.
tjbnwi is online now
Thermostat sensor wire crosses heat cable freshlyd Tiling 4 04-20-2018 08:27 PM
Nest thermostat BCConstruction Technology 0 06-13-2012 11:17 AM
Weird thermostat problem Leo G HVAC 51 02-24-2012 10:37 PM
Thermostat question kbsparky HVAC 7 03-08-2009 11:31 AM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
