Switched Light On Always-on Branch - Electrical - Contractor Talk
Old 11-18-2014, 09:41 PM   #1
CarpenterSFO's Avatar
Rewards Points: 2,044
I need to switch a light on and off, on an always-on branch. Magical switch/transmitter in switch box plus receiver/relay/switch in ceiling box, I suppose. Surely this exists. Yes/no? Recommendations?
- Bob
CarpenterSFO is offline
Old 11-18-2014, 09:46 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 14
Re: Switched Light On Always-on Branch
Ceiling fan remote control.
Tinstaafl is offline
CarpenterSFO (11-18-2014)
Old 11-18-2014, 11:02 PM   #3
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,526
huh? Can you give a different explanation of what you're trying to do? (I'd say better explanation, but I could just be sleepy and it'd make more sense in the morning!)
mstrat is offline
Old 11-18-2014, 11:21 PM   #4
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 292
Umm......Run a switch leg, if power goes to the box.
Or...
Cut the hot, add switch, if power comes from below.
I must not be understanding the dilemma.
Delta
superseal (11-18-2014)
Old 11-18-2014, 11:24 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 36
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
CarpenterSFO (11-19-2014), Seven-Delta-FortyOne (11-19-2014), slowsol (11-19-2014)
Old 11-18-2014, 11:31 PM   #6
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
http://www.1800doorbell.com/remote-c...FSIV7AodgF4AbQ
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
Old 11-18-2014, 11:31 PM   #7
Customer has 2 receptacles and 1 ceiling light on a single circuit, controlled by a switch. She would like the receptacles not to be switched. There are no other conductors in the boxes.
- Bob
Old 11-18-2014, 11:33 PM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 102
Sounds to me like your opening drywall.
Calidecks is online now
Old 11-18-2014, 11:38 PM   #9
Or...
Delta
Not going to run a switch leg. She'd rather leave it as is than pay for running new wires, texture wall repairs. This isn't a priority for her, but I told her I'd look at options.
Cutting the hot won't work because the switch location would be unacceptable.
Tin's idea of the ceiling fan remote may work.
- Bob
Old 11-18-2014, 11:42 PM   #10
stacker of sticks
Rewards Points: 590
Then you need one of these
http://www.affordablequalitylighting...FW8V7AodDwQAHQ
Old 11-18-2014, 11:44 PM   #11
It's just a "while you're at it" item. I'll crawl around below the house and see if there are any other options. It's knob and tube plus some 1980's remodeling - maybe I can find some spare juice.
- Bob
Old 11-18-2014, 11:51 PM   #12
Trade: Highwayman
Rewards Points: 292
With a little attic crawling, and/or crawlspace crawling, and a remodel bit, it could prooly be done, without drywall repairs, if you've done this sort of thing before.
I done dozens of situations like this, but like you said, if she's not interested in spending the money, well......
Delta
Old 11-19-2014, 12:30 AM   #13
Originally Posted by jlsconstruction View Post
That looks like a winner to me. It's a significant advantage that it's a simple switch.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
jlsconstruction (11-19-2014)
Old 11-19-2014, 12:31 AM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 36
Would an occupancy sensor work?
griz is online now
Old 11-19-2014, 12:33 AM   #15
Delta
I'll see what's in the crawlspace. I have other business down there with the stray cats and spiders anyway.
- Bob
Old 11-19-2014, 06:52 AM   #16
mstrat's Avatar
Gotcha...yeah, sounds like you may need another wire run to the switch, or as suggested, some sort of wireless switch...They are far better now than when I first got some...and you're dealing with Knob/Tube...have fun with that too
mstrat is offline
The Following User Says Thank You to mstrat For This Useful Post:
Old 11-19-2014, 09:19 AM   #17
Good question. I don't think so, because it's the main living room lights. It's a funny place - it's like a Hollywood bungalow compound, on a hill in S.F.. Construction was done in 1942. I think I've mentioned the place in another thread - the plank sheathing is old packing crates from military suppliers in San Francisco. They were scrounging whatever they could during the war.
- Bob
Old 11-19-2014, 10:48 AM   #18
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Have you looked in the ceiling box? Around here the ceiling box is often the J box , to have what you describe they would have had to ran power to SW first then to rec and light. Sounds like a sw leg is wired wrong
I have on several ocasions seen where someone mixed up wires and made for what you describe. In old work wires often look the same and are not colored anymore and connections looked bad so people redo them and there you go a mix up.
Red Adobe is offline
Old 11-19-2014, 01:23 PM   #19
It was originally switched receptacles. Sometime (80s?) they ran new conductor up to the ceiling, which is exposed rafters/T&G sheathing in that room and ran surface raceway over to the light fixture. Yeah, most knob and tube runs in ceilings, but with the exposed ceilings here it's all in the walls.
- Bob
Old 11-20-2014, 11:09 PM   #20
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Bob....
I have no idea of your aesthetic configuration/restraints, but you can get a battery powered remote swithch- to- plug in receptical at any X-mas display for $10.
Could that work???? I did it once but had to hide the recepical part in a recessed (but accesable Jbox)...
Best
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Sizing a Pole Light Base 5.4Lariat Architecture & Design 0 05-31-2012 01:45 PM
Door jamb light switch Jer Electrical 19 08-29-2011 07:48 PM
NM cable-degradation from UV light? bach Electrical 16 06-11-2010 08:05 PM
Recessed light cans, heat and attic insulation im4snow Insulation 3 09-30-2008 02:02 PM
