Switch Won't Turn Off - Page 3 - Electrical - Contractor Talk
Old 08-27-2014, 12:02 PM   #41
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Switch Won't Turn Off
Originally Posted by jb4211 View Post
It's funny you said that. That panel in the picture was done by someone from Canada: the previous HO. To be honest, in my 25 yrs, I've never come across a shared neutral until now.
Amatuer or not, I don't like it
What's not to like?
Inner10 is offline
Old 08-27-2014, 01:51 PM   #42
jb4211's Avatar
Rewards Points: 2,306
I'm not an engineer, but if you have two 12gauge hot leads, hit can you have only one 12 gauge neutral?
Jon
jb4211 is offline
Old 08-27-2014, 02:55 PM   #43
Inner10's Avatar
If they are on a different end of the phase yes you can.
Inner10 is offline
woodchuck2 (08-27-2014)
Old 08-27-2014, 04:34 PM   #44
tjbnwi's Avatar
Rewards Points: 3,970
Neutrals carry over current. A properly balanced 110 volt system will run without a neutral.
tjbnwi is offline
Old 08-27-2014, 06:27 PM   #45
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,196
Originally Posted by tjbnwi
Until 2011 tying the breakers together was not required. If the AHJ has not adopted the 2011 NEC, it still would not be required. Tom
It is required in the 2008 nec that multi wire branch circuits must have simultaneous disconnect for ungrounded conductors. I think you mean 2005. Are there still any areas that still go by the 2005?
dielectricunion is online now
Old 08-27-2014, 06:47 PM   #46
tjbnwi's Avatar
You're correct, 08. I know it was proposed for it, did not realize it made it in.
Could be, one of the local AHJ websites still list the '99 NEC as the adopted code. For some reason it gets missed in the website updates.
tjbnwi is offline
Old 08-27-2014, 11:04 PM   #47
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Originally Posted by rselectric1 View Post
My first question as well. Did this by chance get changed too? If so, there is a small tab that needs to be taken out.
Yep spit wired recepticle ......didn't they change the code on those?
Irishslave is offline
Old 08-27-2014, 11:08 PM   #48
Irishslave's Avatar
Originally Posted by TxElectrician View Post
I live in the county and most of my work is done outside of city jurisdictions. A good bit of the work I run across was installed or repaired by someone other than an electrician. First rule I learned when I moved here was to never assume anything was wired correctly.
I understand you were talking about the neutral load getting you in trouble, but I have seen jobs out here where all the white wires were connected to breakers and the blacks to the neutral buss
But hey - the lights came on so it must have been right
yeah I've seen it too.....then they wonder why they end up with reverse polarity
Old 08-27-2014, 11:20 PM   #49
Head Grunt
woodchuck2's Avatar
Originally Posted by Inner10 View Post
Saves money, less work less wire. On a big job it can really help your bottom line.
I think not taking advantage of shared neutrals is amateurish.
I agree Inner10. To those who disagree you will find when fishing home runs from lets say a basement to an attic for new circuits 3 wire will be more cost and time effective. Especially if your charging by the box instead of T/M. You may not always have the room for multiple runs either. If sharing a neutral bothers that much have you requested your POCO to run an extra neutral off the transformer?
woodchuck2 is offline
Old 08-28-2014, 03:26 AM   #50
jb4211's Avatar
In this particular case, it was done to save money on materials. It was the installers own home and room to run the wires was not an issue.
But he failed to tie the two breakers together leaving the neutral energized when the HO shut down half the circuit, thinking he shut down the whole circuit.
That was one issue. There were several including having 12/3 being fed by 20a breakers, then stepping down to 14/2 in a junction box.
Jon
jb4211 is offline
Old 08-28-2014, 04:20 AM   #51
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
think before you bid
pappagor is offline
Old 08-28-2014, 05:04 PM   #52
AmeliaP's Avatar
Trade: Masonry
Rewards Points: 1,624
It works! Thanks for the help! http://youtu.be/YtKk97G5Q3I
www.BillPearnMasonry.com
AmeliaP is offline
The Following 5 Users Say Thank You to AmeliaP For This Useful Post:
CarpenterSFO (08-28-2014), jb4211 (08-28-2014), mikeswoods (08-28-2014), Red Adobe (08-28-2014), rselectric1 (08-28-2014)
What's your turn down rate? Chris G Business 29 03-25-2013 10:27 PM
Door jamb light switch Jer Electrical 19 08-29-2011 07:48 PM
Dimmer switch question MwCar Electrical 34 01-14-2009 05:27 PM
3-way switch with 14/2 wire wadswob Electrical 2 09-23-2008 07:33 AM
Powermatic Switch Joe Wood Electrical 4 08-19-2008 06:28 PM
