Sunday Afternoon Call,,,,,Chicago Guys Will Love This One.. - Electrical - Contractor Talk
Old 03-30-2014, 09:11 PM   #1
Electrical Punk...
HARRY304E's Avatar
Trade: Master Electrician
Rewards Points: 572
Client calls;
"My TV Buzzed out it was loud!, Then I heard a crackling sound and more Buzzing on the other side of the room next to the sliding door to the back porch, there is a switch-box there and the wall is burning hot with a melted plastic smell.....
Okay, go to your basement and shut off the main breaker and I'll be there in an hour.
So I look at the switch box, it looks fine and the wall is cool now, no smoke marks around the box are showing so I open it up to have a look it stunk of electrical burning,but nothing is showing in the box itself, but there is no power there either( I turned on all the breakers when I got there),,,Hmmm Okay so I open the receptacle below in, nothing showing there either, this box had 2 14/3's feed through red leg switched,that still had power from the red leg, but that's coming from a 4 way switch near the front door. So I open some of the other receptacles just to make sure they're ok, then I open the panel (ITE) everything checks out.
So there is only one thing left to do,,,,That's Right Cut open the wall around the switch, the last thing I want to do because now the grand total will jump big on the client, so I told him there really is no choice and your insurance will cover it, I started out with a 4" hole saw and sure enough the paper on the insulation was black from flames, so out to the truck for the sawzall, let the fun begin...
Here is the inside of the switch-box..
This is the inside of the wall....
As you can see on this one is that if the outside-wall was not so tight it would have had more oxygen and this four family condo would have gone up in flames, but I suspect that there was not enough oxygen to feed it so some of the paper burnt itself out.
All the wiring was good here, the problem was the siders were using long nails in their nail gun about 15 years ago when this place was built, these outside-walls are 2x6 construction so you would think that there would be enough room for the wires,,,,Nope...
"A Time For Choosing"
HARRY304E is offline
Old 03-30-2014, 09:12 PM   #2
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
Re: Sunday Afternoon Call,,,,,Chicago Guys Will Love This One..
This is the top of the switch-box...
So I pulled that off of the stud because the problem was behind the box, as I was doing so I got more sparks but the breaker held, so they are probably "NO-BLOW-BREAKERS"
These two are in love....
Gotta love those nail guns...
The Following User Says Thank You to HARRY304E For This Useful Post:
rselectric1 (03-31-2014)
Old 03-30-2014, 09:30 PM   #3
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
That's crazy! Someone got lucky.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 03-30-2014, 09:32 PM   #4
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Yikes!
Those are some seriously long nails for siding.
"Industry without art is brutality"
shanekw1 is offline
Old 03-30-2014, 09:34 PM   #5
mski's Avatar
Trade: home improvements
Rewards Points: 502
Wow. Great investigation work.
I'm sure the homeowner didnt balk at your bill after seeing everything he owned and then some could have been gone forever.
mski is offline
Old 03-30-2014, 09:51 PM   #6
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
Sure did, he's lucky that he did not pass out drunk last night on the couch watching that TV because that was the only load on the circuit
Old 03-30-2014, 09:57 PM   #7
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
Originally Posted by shanekw1 View Post
Yikes!
You mean they're not the normal size??
The scary part is that whole complex may have been done the same way.
Old 03-30-2014, 10:01 PM   #8
Kent Whitten's Avatar
Rewards Points: 2,040
That doesn't look like siding nails, that looks like framing nails. Just my opinion. I'm thinking maybe door remodel, had to re-size the opening and re-nail the ply.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
Tinstaafl (03-30-2014)
Old 03-30-2014, 10:18 PM   #9
Hair Splitter
Trade: General
Or got lazy and that's what was loaded in the gun. Probably figured what harm could it do.
Old 03-30-2014, 11:11 PM   #10
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
Three inches to the left is a sliding door for the back porch, so that may be what happened, however that door has been there for years.
Old 03-31-2014, 09:41 AM   #11
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
WOW.... seriously lucky there.
- John Williams
Complete Window and Door
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 03-31-2014, 10:13 AM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Nice one!
Inner10 is offline
Old 03-31-2014, 06:53 PM   #13
Jepody's Avatar
Trade: Electrical contractor
Nice work finding the problem. Why do siders use such long nails? I see this happen all the time.
www.industryelectricllc.com
Jepody is offline
Old 03-31-2014, 07:33 PM   #14
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
So, with that discovery, do you still think insurance will cover it?
supersealconstruction.com
superseal is offline
Old 03-31-2014, 08:50 PM   #15
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
They will, but the HO will have to pay the deductible probably.
Old 03-31-2014, 08:52 PM   #16
Electrical Punk...
HARRY304E's Avatar
Rewards Points: 572
They're probably not well trained, maybe the HO will go after the builder.
Old 04-01-2014, 09:34 AM   #17
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Very lucky and nice job for you. I worked for a friend of mine doing siding one summer and he was always using 2-3" nails for everything. I asked him one day if he ever thought about what might be inside the wall? Nope, never had a problem. I myself when doing siding i use the shortest nails i can, just enough to get through the siding, foam if there is any and whatever for sheathing.
woodchuck2 is offline
Old 04-01-2014, 09:46 AM   #18
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Geeze.... Take this thread down before the NEC sees it.....
or we will all be in RMC next cycle....
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
I love my helpers!!! mehtwo Plumbing 5 04-20-2013 09:59 PM
Website love - did a little tweaking around Kent Whitten Websites and SEO 16 03-11-2013 06:59 PM
New Website we love feed back poolcageman Websites and SEO 9 07-13-2012 02:05 AM
How do you guys do it? DaVinciRemodel General Discussion 39 01-16-2012 12:16 AM
Getting your guys to "work together". J-Peffer Roofing 20 11-11-2008 12:42 AM
