Stripping Scrap Wire - Electrical - Contractor Talk
Old 05-05-2014, 04:36 PM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,162
I've been selling my old scrap wire with insulation on but I'd like to find a decent, quick way to strip it and get the clean copper price. What's the best way? I'm planning on drilling a hole through a wood block and an intersecting slot for a razor, then pulling each wire through. Seems like it could work.
dielectricunion is offline
Old 05-05-2014, 04:38 PM   #2
hack of all trades
Trade: Electrician
Re: Stripping Scrap Wire
Stripping scrap wire-image-3776971648.jpg   Stripping scrap wire-image-2917318537.jpg
Old 05-05-2014, 06:26 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,599
When all is said and done, how much do you figure you'll make an hour doing it that way? I'd rather do something productive, like trimming my grass with nail clips.
Pro scrappers burn it off, if they can get away with producing all those noxious fumes.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
greg24k (05-09-2014), m1911 (05-05-2014), rustyjames (05-06-2014)
Old 05-05-2014, 07:11 PM   #4
20 and Out's Avatar
Trade: commercial and residential renovation
Rewards Points: 251
Pro scrappers who burn off insulation = homeless who burglarize buildings for copper
20 and Out is offline
Old 05-05-2014, 07:34 PM   #5
Capra aegagrus
Tinstaafl's Avatar
How do you suppose the pro recycling places remove the insulation?
Old 05-05-2014, 07:43 PM   #6
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I forgot what I was going to say...
https://www.youtube.com/watch?v=jcBDWyyExDQ
m1911 is offline
The Following 2 Users Say Thank You to m1911 For This Useful Post:
rselectric1 (05-05-2014), tgeb (05-05-2014)
Old 05-05-2014, 07:46 PM   #7
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Thumbs up
Thank you- logic is dominating currently,,,,...
B,
PrestigeR&D is offline
Old 05-05-2014, 08:07 PM   #8
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Typically scrap metal dealers will not take burnt wire because they do not want to be accused of encouraging their customers to poison the air. Also, when you burn wire, you lose nearly half of it unless it's #14 or thicker.
I am a member over at scrapmetalforum.com where they come up with all kinds of ideas for stripping the wire. There are actual wire stripping machines that you can get for a few hundred dollars. It's probably worth it if you scrap enough wire in a month to pay for it. Also, I've seen a technique where somoene stacked an empty oil barrel on top of another that was burning wood. The barrel on top had a hole on both sides and the person demonstrating the technique pulled the wire through both holes allowing it to heat up warm enough to soften the jacket where it could easily be pulled off by hand while wearing gloves.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
The Following User Says Thank You to tedanderson For This Useful Post:
Gaboy (06-29-2014)
Old 05-05-2014, 08:31 PM   #9
Crafty1's Avatar
Rewards Points: 78
A quick check of the net will produce quite a few devices that you can purchase to strip different types and gauges or check Youtube for tutorials on how to build your own...
Crafty1 is offline
Old 05-05-2014, 09:48 PM   #10
bruces's Avatar
Trade: renovator
Rewards Points: 35
A friend used to run the wire through three cast iron wheels that were very tight together basically squishing the plastic off of the wire .He is no longer with us or I would get you some pictures .It worked like an English wheel I guess if that helps .
bruces is offline
The Following User Says Thank You to bruces For This Useful Post:
roofermann (05-06-2014)
Old 05-05-2014, 09:52 PM   #11
Wood Craftsman
Arrow
Logic is now not present.......
It has moved elsewhere ......
Just saying.....
It's not worth the effort IMO.
Nothing personal...
B,
Old 05-05-2014, 10:08 PM   #12
hack of all trades
Trade: Electrician
Originally Posted by PrestigeR&D
Logic is now not present....... It has moved elsewhere ...... Just saying..... It's not worth the effort IMO. Nothing personal...
I hear you. I've always been really frugal and tried to max out my resources so I'm up to try something and when I realize it isn't worth it, I'll quit. In down time, when I'm just hanging out at home, why not strip it? That's how I feel.
The Following User Says Thank You to dielectricunion For This Useful Post:
PrestigeR&D (05-05-2014)
Old 05-05-2014, 10:33 PM   #13
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
+ YouTube Video
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 05-05-2014, 11:01 PM   #14
m1911's Avatar
that's what she said...
sorry, I've been dying to squeeze that into something all week.
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
QCCI (06-13-2014)
Old 05-08-2014, 11:04 PM   #15
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Scrap yards around here have no problem taking burnt copper but they pay less for it versus good clean copper. I used to lay the wire out and scrape a flooring knife down the side of it and rip off the sheathing in long pieces, now i just give it to my helper and he takes it like a reward.
woodchuck2 is offline
Old 05-08-2014, 11:56 PM   #16
Katatonic's Avatar
Rewards Points: 87
That's what HE said.
Katatonic is offline
Old 05-09-2014, 06:09 AM   #17
General Contractor
greg24k's Avatar
Rewards Points: 8,310
People on crack around here doing that... you got nothing better to do with your time?
With that said, scrap with insulation together, because like Tin said, the margin in price between stripped and none stripped cannot come close to what you lose by wasting your time on striping it.
greg24k is offline
Gaboy (06-29-2014)
Old 05-09-2014, 06:44 AM   #18
builditguy's Avatar
Rewards Points: 1,440
I also saw a homeade machine for stripping. Personally I don't think it is worth it. On the other hand, I save my aluminum. On December 1st, I load it up and turn it all in. Christmas is paid for.
I call it my Christmas club.
builditguy is offline
Old 05-09-2014, 06:54 AM   #19
Box Builder
Morning Wood's Avatar
Rewards Points: 9,788
Just toss it. It's the American way.
Morning Wood is offline
Old 05-09-2014, 10:09 AM   #20
Anti-wingnut's Avatar
Rewards Points: 3,414
Ship it to China, where women burn it off in woks without regard to rules, themselves or the environment.
Anti-wingnut is offline
Down Idle wire broke on Rigid pressure washer Jas2012 Pressure Washing 8 06-19-2013 05:31 PM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
