Stalled Deep Freeze = Rotten Meat - Electrical - Contractor Talk
Old 09-11-2011, 08:14 PM   #1
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
A neighbor wants me to look at a deep freeze for an insurance claim. He lost a freezer full of meat, cleaned up the mess and plugged the freezer back in and it works fine.
There was a small electrical storm a few days before he noticed the freezer had stopped working.
What do you call this, when appliances stop working and need to just be unplugged and then they work again?
cleveman is offline
Old 09-11-2011, 08:21 PM   #2
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Stalled Deep Freeze = Rotten Meat
I call it exotic animal food...
Not sure what the insurance company calls it. It probably tried to restart when there was still high head pressure.
Intermittent failure?
-Steve
TimelessQuality is offline
Old 09-11-2011, 08:27 PM   #3
cleveman's Avatar
Animal food is exactly what he did with the meat. If you see a bunch of raccoons and coyotes running around with the hershey squirts, you'll know where they got it.
I like intermittent failure due to power interruption.
Thanks for the input.
cleveman is offline
Old 09-11-2011, 08:34 PM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
The electrical storm may be a red herring, could be a doggy start relay and the problem may not be fixed.
I'd call it an equipment failure.
Inner10 is offline
Old 09-11-2011, 08:47 PM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,236
I'd call it a reason to buy freezers with temp alarms.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 09-11-2011, 09:12 PM   #6
The Flooring Guy
cork-guy's Avatar
Trade: Flooring
Rewards Points: 250
I'd agree, if you plan on storing a large amount of meat it's worth the investment. The question is if the insurance would even cover such a claim. Best of luck!
Cork Flooring - Educational information on cork flooring for consumers
Cork Flooring Twitter | Cork Flooring Facebook | Ventless Fireplace
cork-guy is offline
Old 09-11-2011, 09:38 PM   #7
cleveman's Avatar
Good tip about the temperature alarm.
I found a freezer alert alarm for $9. Surprising I haven't seen one of these at an appliance store.
cleveman is offline
Old 09-13-2011, 08:01 AM   #8
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I would not even think about putting food back in that freezer. Even if it worked fine for 5 or more days why would someone chance loosing more food down the road. I would replace the freezer and sell the old one. Let some other smuck worry about it operating properly. Buy a new freezer and put an alarm on it.
woodchuck2 is offline
Old 09-13-2011, 09:12 PM   #9
cleveman's Avatar
We filled out the paperwork the other night.
The damage was attributed to "intermittent equipment failure due to power interruption caused by an electrical storm".
This is covered under the homeowners policy up to $500 and the deductible does not apply.
I recommended they put an alarm on the freezer if they want to continue using it.
After seeing the antique, I'm not sure why they don't throw it out. It must cost $50/month to run.
Oh well. Matter closed.
cleveman is offline
Old 09-14-2011, 06:16 PM   #10
SemiRetiredEL's Avatar
Trade: Electrial Contractor (master)
Rewards Points: 75
Cleveman, was the freezer on a AFCI or GFCI?
Since a GFCI is now required on all receptacles in an unfinished basement I raised the question about GFCI's tripping in a basement during a storm and going undetected at a IAEI (Intenational Electrical Inspectors Association) meeting.
I (and about 100 others) were assured by the instructor that new freezers had much lower leakage and this would no longer be a problem.
BTW, where can I buy the temp. alarms, sounds great!
Good Luck from Columbiana, Alabama
Maurice Turgeon, http://thesemi-retiredelectrician.com
SemiRetiredEL is offline
Old 09-14-2011, 10:56 PM   #11
cleveman's Avatar
Sorry, Maurice, I didn't check. The thought didn't cross my mind because the home was built in 1970. I'm sure it was on a normal breaker.
But that is a good point. Lots of important stuff in the basement, such as the sump pump for example.
I just googled something like "freezer temperature alarm" and found a bunch of them.
cleveman is offline
grout underpinning and deep excavation ch0mpie Excavation & Site Work Picture Post 10 01-06-2010 04:49 PM
replacing rotten ribbon. ?? woodworkbykirk Framing 5 06-07-2009 07:28 PM
Sump Pump - Burying the Line Deeper - How Deep? AboveAndBeyond Remodeling 4 02-11-2009 12:22 PM
Wet saw anti freeze EASTSIDE Tiling 5 11-21-2008 06:26 AM
deep plunge with a router rokosz Finish Carpentry 9 11-13-2008 08:29 PM
