Someone Went To A Lot Of Trouble.... - Page 2 - Electrical - Contractor Talk
Old 06-17-2012, 08:30 AM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Re: Someone Went To A Lot Of Trouble....
Originally Posted by txgencon View Post
The poco came out afterwards and installed the seal.
But it is not difficult to remove the seal and get it back on without it being detectable.
Doesn't make sense that they would put a new seal...if he removed the meter why would he put it back in? Now I've confused myself.
Inner10 is offline
Tom Struble (06-17-2012)
Old 06-17-2012, 08:42 AM   #22
txgencon's Avatar
Rewards Points: 450
Not sure what state the thief left the meter (plugged in, on the ground, whatever). The POCO sleeved the meter (little plastic boots on the two load side terminals) and sealed it. This is often done when service is disconnected (especially for non-payment or suspicion of theft).
I can't tell if that's a smart meter. If it is, the thief may have known that the POCO can tell if it's in place or not and didn't want to generate an outage event associated with its disconnection.
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
Inner10 (06-17-2012)
Old 06-17-2012, 09:24 AM   #23
Inner10's Avatar
Ahh gotcha, here they disconnect the service wires leaving them dangle and pull the meter head out of the box.
Inner10 is offline
Old 06-17-2012, 09:41 AM   #24
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
Shouldnt be to hard to re-wire house all the holes are done
pat c is offline
Old 06-17-2012, 10:18 AM   #25
txgencon's Avatar
Rewards Points: 450
That happens here, too, when the homeowner simply pulls the meter, removes the sleeves and plugs the meter back in.
Even then, some industrious homeowners will reconnect at the weatherhead.
So the next step (for the utility) is disconnecting at the pole (or handhole, pedestal or transformer).
As a former utility operations guy, I've pretty much seen it all.
I've even heard of flexible radiator hoses used to steal natural gas when the meter has been removed. As that doesn't provide a pressure regulator, that technique often ends poorly.
txgencon is offline
Old 06-17-2012, 10:37 AM   #26
Inner10's Avatar
Wow, people are ballsy.
If someone pulls a smart meter does it alert the utility company immediately?
Inner10 is offline
Old 06-17-2012, 10:38 AM   #27
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,234
.........If someone pulls a smart meter does it alert the utility company immediately?
Some, but not all.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 06-17-2012, 10:44 AM   #28
txgencon's Avatar
Rewards Points: 450
No, it doesn't work like that. The meters are "polled" periodically and are not in constant communication with the utility's computers. It could be as infrequently as once per month (to support billing) or as often as every 5 minutes. In periods of high demand, the polling is often suspended as it it takes quite a bit of energy demand for the polling process - as much as 300 kva per 10 megawatt feeder.
txgencon is offline
Old 06-17-2012, 11:02 AM   #29
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 280
Now that's interesting; never knew that. I always assumed they worked with something like low-power ELF.
Looks like I have today's Google project lined up.
Tinstaafl is offline
Old 06-17-2012, 11:11 AM   #30
txgencon's Avatar
Rewards Points: 450
I guess it depends on the communication system. Most (but not all )systems use a power line carrier system where signals are injected on the utility's distribution primary and have to pass through the distribution transformer to get to the meter. Supposedly, it has the most robust communications capability compared to cellular or radio and is more reliable (think of dropped calls or radio static). But it also has the limitation of not being able to communicate back to the host when the power is off as there is no pathway.
txgencon is offline
The Following 2 Users Say Thank You to txgencon For This Useful Post:
SemiRetiredEL (06-25-2012), Tinstaafl (06-17-2012)
Old 06-17-2012, 03:11 PM   #31
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Isant there a special key that's inserted into the meter for it to be able to be pulled?
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 06-17-2012, 03:15 PM   #32
480sparky's Avatar
Nope. Just cut the little wire lock and pull the meter by hand.
Old 06-17-2012, 03:16 PM   #33
Repair & Renovation
Rich D.'s Avatar
Interesting. By me there's a thing called a barrel lock key. Or is that just to get into the box?
Rich D. is offline
Old 06-17-2012, 03:28 PM   #34
480sparky's Avatar
Yes, you need a special key to undo a barrel lock. But after that, it's the same... pull the meter.
Old 06-17-2012, 04:53 PM   #35
txgencon's Avatar
Rewards Points: 450
The locking ring sparkles posted is for a ring style socket and is possibly the hardest to defeat as the meter usually has to be out to lift the latch hoding the cover to the base.
A ringless socket is less secure. The utility can use a barrell lock or a regular hasp style lock in the large hole on the latching mechanism.
What sparkles isn't saying is that neither is much of an obstacle to someone who knows what they're doing.
txgencon is offline
Old 06-17-2012, 05:33 PM   #36
480sparky's Avatar
.......What sparkles isn't saying is that neither is much of an obstacle to someone who knows what they're doing.
What I will say is it's a crime in many areas to mess with any of this stuff.
Old 06-17-2012, 05:37 PM   #37
txgencon's Avatar
Rewards Points: 450
For sure, unless you have been "deputized".
txgencon is offline
Old 06-17-2012, 08:51 PM   #38
Inner10's Avatar
You guys ever see the "Peerless Security" plastic lock rings? They used them when they started installing smart meters but stopped for some reason.
Inner10 is offline
Old 06-18-2012, 11:40 AM   #39
teamo's Avatar
Trade: Electrical apprentice
Just had a similar one recently. Someone went into the POCO transformer cabinet outside of a vacant business/warehouse. Cut the live primary side (13,900 volts) and stole all of the copper out of the cabinet. They missed the concentric ground braid by about 1/2" with their cutters. It must have arced because one of the cutouts on the pole was tripped. Most likely we would have found the charred remains had they hit the ground braid directly with their cutters.
teamo is offline
Old 06-24-2012, 01:14 PM   #40
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
The truly messed up thing about metal thieves is that it's not worth THAT much money. He caused probably 20K worth of damage for MAYBE $200 worth of scrap copper. He should do some time for that one imo.
Around here, bit rooftop A/C units are getting destroyed for the few hundred dollars worth of copper in them. Destroying a 50K unit for that little money is just beyond ridiculous...
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
Having trouble with my Paslode cordless framing nailer CJ21 Tools & Equipment 11 02-19-2012 07:25 PM
apprentice having trouble cutting accurately likeke34 Carpentry 193 12-21-2009 01:29 AM
Trouble Shoot Tripping Breaker DaVinciRemodel Electrical 29 10-27-2009 08:07 AM
Site Trouble eagleandbaby Off Topic (Non Trade) 15 10-03-2008 05:22 PM
