Small Voltage In Green Wire - Electrical - Contractor Talk
Old 06-14-2012, 10:35 PM   #1
VAviaCo's Avatar
Rewards Points: 250
Was over building a garden shed for a friend and we had to use his neighbor's outlet but couldn't find the switch for it so I had my multi meter out to see when they found the right switch and just for hahas, I checked the hot vs ground (third prong) and had about 90 volts (after they found the switch).
But it was 120 black to white ( couldn't see the wires, just the outlet) and 14 volts between green and white.
We just used it and went away when we were done. It worked fine.
Is this something he ought to tell his neighbor to have checked out?
What could cause that small voltage reading in the ground?
VAviaCo is offline
Old 06-14-2012, 10:38 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,682
Re: Small Voltage In Green Wire
Not a Sparky....
but probably going to have something to do with a neutral & ground having too close of a relationship ..
griz is online now
Old 06-17-2012, 09:48 AM   #3
pat c's Avatar
Trade: ELECTRICAL
Rewards Points: 75
loose or disconnected neutral that is either part of a multi wire branch circuit, a feeder or the service.
pat c is offline
Old 06-17-2012, 10:38 AM   #4
txgencon's Avatar
Rewards Points: 468
Cheap multimeter. "Phantom" reading.
txgencon is offline
Old 06-21-2012, 07:21 AM   #5
VAviaCo's Avatar
Rewards Points: 250
Sperry DM-350A
Definitely didn't break the bank on it.
http://www.byramlabs.com/images/hi-res/SPE-dm-350a.gif
VAviaCo is offline
Old 06-21-2012, 07:27 AM   #6
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,976
Get a meter with Lo-Z capability.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
VAviaCo (06-21-2012)
Old 07-03-2012, 07:07 PM   #7
Satman40's Avatar
Trade: low voltage electronics
Rewards Points: 75
This dry weather maybe ground rod dry.....needs moisture to work...
Satman40 is offline
Old 07-03-2012, 07:20 PM   #8
txgencon's Avatar
Rewards Points: 468
Got nothing to do with it.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
The Following 2 Users Say Thank You to txgencon For This Useful Post:
Satman40 (07-03-2012), Speedy Petey (07-06-2012)
Old 07-06-2012, 08:33 PM   #9
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
Agree with TX. ABSOLUTELY nothing to do with it.
Speedy Petey is offline
Low Voltage Hardwiring sbebuilders Electrical 5 10-10-2011 11:04 PM
Low Voltage in the outer Chicago Area dgregait Low Voltage 5 09-09-2011 08:12 AM
Ontario/Canada..low voltage, datacom requirements? mdo11 Electrical 9 07-18-2011 11:30 PM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
low wire voltage mehranalmasi General Discussion 0 06-20-2007 04:11 PM
