Seal Tight/Connection Punchlist - Electrical - Contractor Talk
Old Yesterday, 12:48 PM   #1
boileredup's Avatar
Rewards Points: 20
Hi all,
I'm a bit stumped on this one. I'm not an electrician and working on a punchout for a job I've inherited. The comment made on this particular item is that the seal tight is not necessary for a proper installation and is not even connected properly. I think it's been connected properly and have no issue in regards to compliance with code. Thoughts?
Seal Tight/Connection Punchlist-img_0476.jpg
boileredup is offline
Old Yesterday, 01:04 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,050
Re: Seal Tight/Connection Punchlist
Well, there's a liquid-tight fitting, with liquid-tight flex, terminating into box rated for dry locations.
That might be what they are referring to.
griz (Yesterday)
Old Today, 06:56 PM   #3
Half-fast Eddie's Avatar
Trade: Commercial project management
Rewards Points: 100
And if you zoom in, the flex is attached to a piece of emt. I’m thinking they needed a section of flexible conduit and all they had was liquitight.
Half-fast Eddie is online now
Old Today, 08:20 PM   #4
tjbnwi's Avatar
Rewards Points: 5,852
Is it LT with the metal core or PVC through?
If it is the second, you need a ground wire.
tjbnwi is online now
Old Today, 08:25 PM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 13,016
That would be what I'd check first.... whether the flex is approved for grounding and whether there's a ground wire if it isn't.
It looks like there's a gasket on the 90, so I'd say it's not an approved ground path.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
