Is Schedule 40 PVC Conduit A Good Choice (& To CA Code) For Electrical In Workshop? - Electrical - Contractor Talk
Old 09-13-2015, 02:00 PM   #1
67Mustang's Avatar
Trade: General Building
Rewards Points: 58
I need to redo the electrical in my workshop. It is about 1400 sq ft and I am wanting to redo all of the conduit that serves the lights and plugs, etc. Currently all of the conduit is 1/2 EMT exposed metal pipe that is in poor shape.
I would like to use white schedule 40 PVC conduit (all exposed outside of the walls). I like the fact that the pipe is white and not metal for a cleaner look. Also may be easier to work with then bending metal pipe?
I'm in CA. Is this pipe OK to use and up to current code? All of the pipe would be inside the workshop and not in areas where it could be easliy damaged. Thanks for any advice!
67Mustang is offline
Old 09-13-2015, 03:57 PM   #2
aptpupil's Avatar
Rewards Points: 1,894
Re: Is Schedule 40 PVC Conduit A Good Choice (& To CA Code) For Electrical In Workshop?
I believe it has to be 80
aptpupil is offline
Old 09-13-2015, 06:02 PM   #3
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Isn't electrical conduit gray?
And white schedule 40 pvc is for PLUMBING?
Morning Wood is offline
The Following 2 Users Say Thank You to Morning Wood For This Useful Post:
Big Shoe (09-14-2015), C'est Moi (09-13-2015)
Old 09-13-2015, 07:20 PM   #4
aptpupil's Avatar
80 is gray
aptpupil is offline
Old 09-13-2015, 07:23 PM   #5
tjbnwi's Avatar
Rewards Points: 296
40 is gray.
http://www.cantexinc.com/Products/Sc...duit/index.php
So is 80
tjbnwi is offline
TxElectrician (09-14-2015)
Old 09-13-2015, 07:34 PM   #6
World's Tallest Midget
Mort's Avatar
Trade: Concrete
Rewards Points: 1,580
We used some white pipe to sleeve a water line in stubbing up into a foundation. The inspector almost had a cow, so now we paint the exposed pipe blue. They somehow don't have a problem with that.
All the electrical pipe around here is schedule 40 but I'm in Washington, not the Soviet Republic of California.
I hate signatures.
Mort is offline
Old 09-13-2015, 07:44 PM   #7
Box Builder
Rewards Points: 6
I have my primary electrical line buried under my driveway. I didn't want to use metal, so I had to use schedule 80 pvc. All fittings and couplings are still same as schedule 40
Old 09-13-2015, 07:45 PM   #8
aptpupil's Avatar
Looked at my code check book and it doesn't even mention sch40. Can you show where it's allowed to be used?
Personally I don't see the point. Just use the 80. Not like it's more difficult to work with our much more money.
aptpupil is offline
Old 09-13-2015, 08:00 PM   #9
Mort's Avatar
Trade: Concrete
No idea, just a dirt guy. It's what the sparkies use after we dig them a hole.
I hate signatures.
Mort is offline
Old 09-13-2015, 08:02 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
You can get both up here but all you see stocked is 40.
Inner10 is offline
Old 09-13-2015, 08:19 PM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
They sell white schedule 40 for plumbing because it is liquid pressure and potability rated.
They sell schedule 40/80 for electrical because it is UL rated for line voltages/current leakage.
After its installed and inspected, you can paint it tiddy pink, if that is what gets you all jiggly.
EDIT: "because it is UL/NEMA/NEC rated.."
SmallTownGuy is offline
Old 09-13-2015, 08:21 PM   #12
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
There is white schedule 40 which is for plumbing and not approved for electrical. The gray schedule 40 is what you need. Not sure of the difference...
Schedule 80 would only be required if installed where the PVC is subject to damage, ie, in a yard where a weed wacker may get to it. I have never seen it required indoors but that does not mean the local inspector would allow it. I would call them but personally I would use emt. I think it would look better and hold up better.
C'est Moi is offline
Old 09-13-2015, 08:29 PM   #13
Inner10's Avatar
There is also low smoke PVC for plumbing that is grey, and orange for electrical.
Colour is not significant, rating is.
Inner10 is offline
Old 09-13-2015, 10:00 PM   #14
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
I think the gray is a little more sunlight resistant if exposed
Calidecks is offline
Rio (09-14-2015)
Old 09-13-2015, 10:08 PM   #15
tjbnwi's Avatar
Rewards Points: 296
Smaller I.D. few wires can be run in the raceway.
Same temp rating for 40 & 80.
tjbnwi is offline
Old 09-13-2015, 10:23 PM   #16
aptpupil's Avatar
Eh, I always go a size or two bigger anyway. Same with j boxes. Never liked trying to pull wires through tiny conduit or cram them in small boxes.
aptpupil is offline
Old 09-13-2015, 11:03 PM   #17
Inner10's Avatar
Here all electrical conduit has the same ID.
Inner10 is offline
Old 09-14-2015, 04:03 AM   #18
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I always wondered why they made the I.D. of conduit different sizes depending on the type. Here 1/2" emt has a different I.D. then 1/2" Pvc etc.
Old 09-14-2015, 04:31 AM   #19
Big Shoe's Avatar
Rewards Points: 2,264
Are you going to buy white 90's and boxes too?
Expect the Unexpected
Big Shoe is online now
Old 09-14-2015, 06:48 AM   #20
tjbnwi's Avatar
Rewards Points: 296
The OD of 40 & 80 are the same, the wall of 80 is thicker than the wall of 40. How can the ID be the same?
In the NEC, Chapter 1, Table 9 lists the ID of 1/2" Sch 80 as 13.4mm/0.526", Sch 40 1/2" is listed as 15.3mm/0.602.
1/2" EMT is 15.8mm/0.622 ID, 1/2" IMC is 16.8/0.660. 1/2" RMC is 16.1/0.632
I see them as all different, not the same.
tjbnwi is offline
Good people looking for employment with good construction company in North Jersey MelissaV Help Wanted or Looking For Work 6 05-27-2014 05:11 PM
Anyone know a good storm chaser in Indianapolis? KBerry Help Wanted or Looking For Work 15 06-07-2013 07:22 PM
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
Any one have a good choice on a good Planer? Houston's Tools & Equipment 22 02-24-2011 10:40 PM
Any good code seminars or classes in Chicago land sossecureda Plumbing 0 03-07-2010 10:44 AM
