RV Power Pedestal Conduit - Page 2 - Electrical - Contractor Talk
Old 02-07-2020, 05:10 PM   #21
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,645
Re: RV Power Pedestal Conduit
Chally, if you get a chance, check out RVtravel.com. There is an electrical guy on there, Mike Sokol, that has written many articles on what you are doing. In fact, the NEC actually quoted him, and his writings, on how pedestals at RV parks are installed, etc.
From the light reading I did, he was opposed to installing GFCI's on 50A circuits at RV hookups.
Take a look at that site, and see what you think.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
chally71 (02-08-2020)
Old 02-08-2020, 12:02 AM   #22
chally71's Avatar
Trade: general
Rewards Points: 24
Hey RE,
Appreciate the suggestion. I came across Mike during an earlier internet search, and it helped me get this kind of lined out!
chally71 is offline
Old 02-08-2020, 09:44 AM   #23
Mordekyle's Avatar
Rewards Points: 5,590
Related question:
I need to get power to my treehouse. About 210 feet away from the house/panel. I will bury the line.
Maybe a 50 amp load Max? A microwave, a radiant electric heater, Lights and outlets. No WH. Itís all wired 110.
Would 10 gauge wire be sufficient?
What are Advantages of conduit?
Mordekyle is offline
Old 02-08-2020, 10:37 AM   #24
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,008
Originally Posted by Mordekyle View Post
Related question:
Can't feed #10 with a 50A breaker.
Mordekyle (02-08-2020)
Old 02-08-2020, 10:53 AM   #25
Trade: Highwayman
You'll need a #4 probably, to cover voltage drop.
And a 50A sub-panel in the treehouse.
Old 02-08-2020, 02:18 PM   #26
Mordekyle's Avatar
Yes, I think I have 100 amp panel in the treehouse, everything electrical works.
I have a 12 gauge extension cord running to it from an exterior outlet 50 feet away. The outlet itself is probably 100 feet from the house.
Lots of line loss, and I havenít turned on everything at once, cause I know it wonít support it.
Old 02-08-2020, 02:18 PM   #27
Mordekyle's Avatar
So is there an advantage to direct bury versus conduit?
Old 02-08-2020, 03:10 PM   #28
Mike-B's Avatar
Rewards Points: 1,142
Protection and ease of replacement if ever needed
Sent from my SM-G970U using Tapatalk
Mike-B is offline
The Following User Says Thank You to Mike-B For This Useful Post:
TxElectrician (02-08-2020)
Old 02-08-2020, 03:53 PM   #29
Trade: Highwayman
Does the panel in the treehouse have a main breaker, or is it MLO (Main Lug Only)?
If it has a 100A main, you'll have to either replace that, or upgrade your feed and breaker at the main panel.
I usually use #2 for 100A panels (copper, it'll be larger if you want to use aluminum), but you'll probably have to go even larger than that to compensate for voltage drop.
On a long run like that, you might want to look into aluminum. It'll save you a buck or two.
And to clarify Mike-b's post above, that advantage he mentions is if it's in conduit, not direct burial.
Direct burial is easier and cheaper to install originally, but is more subject to damage, and it's not possible to upgrade/replace.
One idea is to put a conduit a size or two larger than you need, in case you ever want to put in a larger panel, plus a smaller one along side, for future data cables.
Not much more money, and you need a trench whether you're doing direct burial or conduit.
PVC conduit is cheap.
Old 02-08-2020, 03:55 PM   #30
Trade: Highwayman
That's dangerous.
Old 02-08-2020, 09:04 PM   #31
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 530
◊2
I refuse to dig a trench in the Texas hill country and not install conduit
Sent from my LG-LS993 using Tapatalk
TxElectrician is offline
Old 02-08-2020, 09:05 PM   #32
Trade: Highwayman
Originally Posted by TxElectrician View Post
◊2
Pretty rocky?
Old 02-09-2020, 06:13 AM   #33
Trade: Electrical
Rewards Points: 530
Pretty rocky?
Yes sir
The Following User Says Thank You to TxElectrician For This Useful Post:
Seven-Delta-FortyOne (02-10-2020)
Old 02-10-2020, 11:31 PM   #34
chally71's Avatar
Trade: general
Rewards Points: 24
What does everyone like for large dia cable strippers?
This one seems handy:
https://www.amazon.com/Jonard-CST-19.../dp/B0069627PA
chally71 is offline
