Replacing Failing Shower Can To LED - Electrical - Contractor Talk
Old 05-13-2019, 10:27 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 618
- Fixing this for father who has dementia...would appreciate help as the rest of the shower has safety treads, non-slip floor mat (outside) and chorded shower head.
Guessing that moisture has gotten in this fixture and there hasn't been much fan circulation over the nook shower.
Put in a new typical bulb that blew right out.
- What type of LED might be adapted to where I won't have to replace the whole can from the topside?
- Does LED need to be moisture rated?
- I see where the riveted contacts appear rusted but is the two pair yellow/black comparable to the newer orange/black? That existing black takes a jog off to the right up in there and I'm not sure why.
Replacing Failing Shower Can to LED-1shower-can-overall-5.15.19.jpg   Replacing Failing Shower Can to LED-2shower-can-inner-5.15.19.jpg   Replacing Failing Shower Can to LED-34shower-can-outer-inner-contact-5.15.19.jpg
artinall is offline
Old 05-13-2019, 12:55 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 7,968
Re: Replacing Failing Shower Can To LED
They make and I've used an LED replacement that fits into the existing can...and has a threaded male fitting like a light bulb that screws into the existing socket.
But that probably won't be of any help if a regular bulb burns out immediately. Sounds like the problem is further up the line.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 05-13-2019, 01:03 PM   #3
hdavis's Avatar
Rewards Points: 2,252
If that's over a shower, get a wet location rated fixture and trim. Even better, get an LED puck rated for it.
The black lead takes a jog over to a thermal interrupt switch, I believe.
hdavis is online now
overanalyze (05-13-2019)
Old 05-13-2019, 01:07 PM   #4
Robie's Avatar
https://www.amazon.com/TORCHSTAR-Loc...gateway&sr=8-5
Mark Twain
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
artinall (05-13-2019), TxElectrician (05-14-2019)
Old 05-13-2019, 01:32 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,025
Or something like this, with what you have. Make sure the bulb can be fully enclosed in the fixture.
https://www.homedepot.com/p/EcoSmart...SD04/300377366
MarkJames is online now
Old 05-13-2019, 01:32 PM   #6
artinall's Avatar
Rewards Points: 618
Originally Posted by Robie View Post
... Sounds like the problem is further up the line.
How to determine this...
Could rusty/degrading contacts cause bulb burnout?
Could a faulty interrupt burn out a bulb?
Wondering if an LED like the Torchstar could be clipped into the yellow/black direct - if I can find a way to crimp those from both sides.
artinall is offline
Old 05-14-2019, 02:03 PM   #7
artinall's Avatar
Rewards Points: 618
Lots of Q's;
Might this do the trick?
https://www.homedepot.com/p/Halo-RL-5-in-and-6-in-White-Integrated-LED-Recessed-Ceiling-Light-Fixture-Retrofit-Downlight-at-90-CRI-3000K-Soft-White-RL560WH6930R/204347762
Do LED retro's/cans even need to be IC rated?
Do the retro's normally come with the other "unconnected" half? if not, can I simply clip and apply my own double half connector (pic)? Plus + whether to connect prior to or after the thermal interrupt?
Although it would by nice to know what is cause of bulb blowout before doing.
Hiking up in the attic to do a whole LED wouldn't be easy - the shower is near the outer wall/scrunched eve area.
artinall is offline
Old 05-22-2019, 05:00 PM   #8
artinall's Avatar
Rewards Points: 618
Installed a 3000k, 700 lumen Juno (10 watt) that was far too bright (dementia person)
Tried a 2700 - 3000 k 700 lumen Commercial Electric also too bright.
Only other wet location retrofit I can find that is less is the Halo RL56, at 610 lumen 8 watt.
Is there such a thing as a 6 watt wet location retrofit? I think we need about 500 lumens to make it not too harsh for this person. Who cannot deal with a dimmer switch or we'd do one.
I think the only other alternative is to find a wet location trim kit and put in a 40 watt or 6o watt bulb. Unless I'm missing something.
artinall is offline
Old 05-22-2019, 05:18 PM   #9
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 206
Can you put a dimmer switch in, adjust to the correct brightness for them and fix the switch so it can't move?
Don't know if that's possible, but just a thought I had.....
mrcat is online now
Old 05-22-2019, 06:18 PM   #10
artinall's Avatar
Rewards Points: 618
Don't know if that can be done either but, to give you an idea, he's counting the number of lights over the vanity. Too much. If it wasn't it would've been too few
Everything must be translated to the simplest form possible. Is about the only way I can put it. He's been in advanced stages...many minute things are a potential source of bother that is obsessed over constantly.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
mrcat (05-22-2019)
Old 05-22-2019, 06:22 PM   #11
MarkJames's Avatar
Then try using the original trim and cover with a LED 40 watt equivalent bulb (soft white, 2700k)..or even a 25watt equivalent if it's still too bright.
Old 05-22-2019, 06:24 PM   #12
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 842
That right there. Dimmer switch with the little slide dimmer. Once it's adjusted it's simple on and off for them.
dsconstructs is online now
The Following User Says Thank You to dsconstructs For This Useful Post:
mrcat (05-22-2019)
Old 05-22-2019, 06:45 PM   #13
artinall's Avatar
Rewards Points: 618
Original trim is marginal at best.
Loose glass in a metal circle, stuck with foam pad.
artinall is offline
Am I crazy? Shower door shesbros General Discussion 22 08-31-2017 05:12 AM
Weird Pressure change in shower when flushing toilet Morning Wood Plumbing 10 03-30-2016 08:16 AM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
