Recessed Can Question - Page 2 - Electrical - Contractor Talk
Old 03-20-2014, 10:52 PM   #21
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Recessed Can Question
I put 2700K in every fixture. I can't stand the cold or daylight temps.
m1911 is offline
Old 03-20-2014, 10:55 PM   #22
CarpenterSFO's Avatar
Rewards Points: 2,044
Originally Posted by MTN REMODEL LLC View Post
You might have to bend the end of the spring a little to get it hooked on the smaller drilled hole. Needle nose pliers are necessary unless you happen to have the dexterity of a brain surgeon.. eye glasses are necessary also for me.
EDIT: CAUTION.... Falling off ladders and sticking your finger in a hot light socket have been known to cause cancer in California.... pretty sure it's allright in CT.
Bob... I had to add that for my Cali friends.... had a couple of drinks/relaxing/goofy.
Every time I mess around in a recessed light can I remind myself to get a pair of upside-down bifocals. That and every time I'm working under a sink. Never happens, though.
Yes, the cancer warnings have become background noise here. Every store, from the corner market to the big box store to the pro supply house, has the sign at the front door, warning about the stuff inside. It no longer means anything.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
MTN REMODEL LLC (03-21-2014)
Old 03-20-2014, 10:57 PM   #23
I've been swapping in LEDs in the shop as the CFLs fail. They sure better last a long time. The CFLs haven't lasted any longer than the old incandescents.
- Bob
Old 03-20-2014, 10:59 PM   #24
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,156
The 2700k LEDs from Costco advertise 22 years.
Calidecks is offline
CarpenterSFO (03-20-2014)
Old 03-22-2014, 05:01 PM   #25
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Sorry got busy for a while, He had the home energy audit guys there from the local power company and he had alot of air leaking around the high hats, they recommended he use a LED replacment with the bezel attached as this would help to seal the air leaking through the can. The only model they had has the spring clips attached which need to go into those clips.
Prior to the energy audit I was doing some work in the attic and had noticed all the insulation had been pulled back from around the cans. I told him to call an electrician and have him come and see if they were IC rated or not, as I was not sure how you would know this.
Thats is what got him started on the CL and P energy audit. I guess we should just pull the cans and put in new ones air tight IC rated ones and be done with the whole thing. Not to big a deal as have good access in teh attic to the two bed rooms affected
Anderson is offline
Old 03-22-2014, 06:29 PM   #26
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
At least in Colorado today..... they were 9.99 (13.99 less a 4 manu rebate)
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 03-22-2014, 06:42 PM   #27
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
But much like CFLs fixtures that cause them to build up heat will drastically shorten their lives.
Inner10 is offline
Survey Question: Would you rent your equipment out to others? TheAgent11 Business 17 05-23-2013 03:44 AM
Recessed Lighting Cans - Remodel vs. New Construction We Fix Houses Electrical 46 04-13-2013 08:27 PM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
California Question!! MTN REMODEL LLC Electrical 10 11-20-2010 12:10 AM
recessed storm door installation question nj handyman Finish Carpentry 6 12-29-2008 11:24 PM
