Recessed Can Help - Electrical - Contractor Talk
Recessed Can Help
Old 04-11-2016, 09:22 PM   #1
mnhusker's Avatar
Trade: Custom Homes
Rewards Points: 12
Recessed Can Help
Hi,
Im looking to see if someone has a solution for me. I have a light at the stair landing on my project that has a surface mounted fixture. Plaster ceiling with a cut in box and only about 3.5 in of depth from finished face to a duct above. Client wants the look of a recessed light, but I haven't been able to find a fixture that works with the depth constraint. Anyone have any ideas?
Thanks!
Barry
mnhusker is offline
Old 04-11-2016, 09:28 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 14
Re: Recessed Can Help
The newer LED "can" lights can make that clearance with no problem.
Tinstaafl is online now
mikeswoods (04-13-2016)
Old 04-11-2016, 09:35 PM   #3
tjbnwi's Avatar
Rewards Points: 262
I use the 6" in closets.
http://www.junolightinggroup.com/Wha...e=newsArticle4
tjbnwi is online now
Defenestrate (04-11-2016), mnhusker (04-11-2016)
Old 04-11-2016, 09:35 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 44
My electrician likes these for closets. Could do what you need. They look real nice.
http://www.kichler.com/products/prod...-wh-43846.aspx
overanalyze is online now
Old 04-11-2016, 09:39 PM   #5
mnhusker's Avatar
Trade: Custom Homes
Rewards Points: 12
Perfect thanks for the quick responses. I knew there had to be a solution. Those surface mounts are slick. Much appreciated!
mnhusker is offline
Old 04-13-2016, 05:10 PM   #6
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Be careful as the Halo ones need at least a 2 1/2" deep box for the driver to fit in.
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
mnhusker (04-13-2016)
Old 04-13-2016, 07:09 PM   #7
CPMKW's Avatar
Trade: GC PM
Rewards Points: 372
http://www.lotusledlights.com/recess.../9w-super-thin
CPMKW is offline
The Following 2 Users Say Thank You to CPMKW For This Useful Post:
mnhusker (04-13-2016), Ohmy (04-15-2016)
Old 04-13-2016, 07:23 PM   #8
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Originally Posted by CPMKW View Post
Nice setup but that is a 4" fixture. Wonder why they don't make a 6" unit
Old 04-13-2016, 08:03 PM   #9
rselectric1's Avatar
Rewards Points: 926
Thanks for this info. I haven't used one of them yet but have been tempted.
rselectric1 is offline
Old 04-13-2016, 08:13 PM   #10
mnhusker's Avatar
Trade: Custom Homes
Rewards Points: 12
Thanks for the help everyone! Ended up going with a halo from the depot. Here's a couple finished pics. Used a 3 1\2 round box as it was existing. Don't recommend. Barely fit. Appreciate the input.
mnhusker is offline
The Following User Says Thank You to mnhusker For This Useful Post:
rselectric1 (04-13-2016)
Old 04-14-2016, 05:40 AM   #11
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
You got it in a 1 5/8" deep box? If so then they changed the setup. It was actually in the instruction to use a 2 1/2" box
Old 04-14-2016, 05:43 AM   #12
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
This is from the installation instructions.... http://www.homedepot.com/catalog/pdf...0d02af754f.pdf
I guess it was 2 1/8" deep not 2 1/2" -- sorry
ELECTRICAL JUNCTION BOXES
Mounting to recessed mounted standard
junction boxes
NOTE: The module installs onto many standard
recessed ceiling and wall mounted junction boxes
(Fig. 1).
- 4 octagon; 2 1/8 Deep
- 4 square; 2 1/8 Deep
- 4 round; 2 1/8 Deep
(Box types and site condition vary. Installer to ensure
compatibility at fit, wiring and proper mounting.)
The junction box must be a minimum 2 1/8 inch in depth
for proper installation. Recommended boxes shown in
Fig 1
Old 04-14-2016, 06:47 AM   #13
builditguy's Avatar
Rewards Points: 2,190
We use the Halo ones above. We use them quite a bit and they work out great.
Sylvania also makes one. It is a little more rounded than the Halo. I think the Sylvania fits in a smaller box. Also easier to install. The Halo ones can be a little tricky at times. They need to twist into a metal bracket. The Sylvania ones screw right to the holes in the box.
Customers just seem to like the look of the Halo better.
I think this is the Halo one. Same as above, I'm pretty sure.
http://www.homedepot.com/p/Halo-5-in...0WHR/204732243
Here is an article about the Sylvania. Talks more about energy efficiency, but gives alot of info about them.
http://energyconservationhowto.blogs...isk-light.html
I believe this is the right one.
http://www.amazon.com/Sylvania-70732.../dp/B00KB9G57C
builditguy is offline
Old 04-14-2016, 07:29 PM   #14
tjbnwi's Avatar
Rewards Points: 262
I install them in an 1-1/2" box, never needed a 2-1/8" box.
Thinking about it, 1.5" box-5/8" round mud ring.
Old 04-15-2016, 12:44 PM   #15
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
Yep 1.5" + 5/8 = 2 1/8" .
It may well fit in a smaller box but there is no room for the driver to breathe. They recommend that 2 1/8" for a reason
Old 04-15-2016, 05:05 PM   #16
Ohmy's Avatar
Trade: Electrical Contractor
Rewards Points: 89
Those Lotus lights are sweet. These are perfect for built-ins.
Ohmy is offline
Old 04-15-2016, 08:18 PM   #17
Rewards Points: 926
I have a service call scheduled for Monday where a HO stuffed one of these into a packed box and shorted things out.
If these things truly take up as much room in the box as it sounds like, I'll bet we'll have this addressed in the next NEC edition.
I'll bet the box fill for these things destroys the normal 1 count for...and 2 count for ....etc when figuring out if its legal to install them.
This should be interesting.
Old 04-17-2016, 02:08 PM   #18
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Same problem occurs when a guy buys a bunch of big fat dimmers and replaces all his switches in shallow boxes.
Inner10 is offline
Recessed Lighting Cans - Remodel vs. New Construction We Fix Houses Electrical 46 04-13-2013 08:27 PM
Recessed lights and thicker ceilings Morning Wood Electrical 8 01-16-2013 08:02 PM
I need LV LED recessed outdoor lights Santa's Helpers Outdoor Lighting 3 09-05-2011 08:43 PM
commercial/metal grade recessed boxes? Laketahoedan Electrical 12 04-28-2010 07:38 PM
Recessed light cans, heat and attic insulation im4snow Insulation 3 09-30-2008 02:02 PM
