Quick Connects Vs Wire Nuts - Electrical - Contractor Talk
Thread Tools
Old 05-19-2019, 03:09 PM
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 618
This pic: a Halo H71CT can (LED going in).
Does it really matter if using the quick connects or the wires are clipped and nutted?
If I do us them - how far to strip before inserting. And, once they are in, how does a person get them back out if needed?
artinall is online now
Old 05-19-2019, 03:15 PM
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,318
Re: Quick Connects Vs Wire Nuts
It's not a quick-connect. It's a push-in wire splice. The only reason you really need to cut them off and use wire nuts is if you need to splice more wires than they have ports on them for.
There's a strip gauge on the piece itself. Hard to see, but it'll be there.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
artinall (05-19-2019)
Old 05-19-2019, 04:50 PM
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,822
Those things are a huge timesaver. I'm sure when wire nuts came out that there were people who refused to switch to them as well.
Home Designer Series Software
B.Johnson is online now
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 05-19-2019, 06:01 PM
tjbnwi's Avatar
Rewards Points: 1,972
Not allowed to use them in Chicago r most of the AHJ's around Chicago.
tjbnwi is offline
Old 05-19-2019, 06:06 PM
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 478
They're a timesaver, no doubt about it. So's backstabbing.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Calidecks (05-20-2019), TxElectrician (05-20-2019)
Old 05-19-2019, 06:26 PM
B.Johnson's Avatar
Trade: Builder
Do you have a point?
Old 05-19-2019, 06:43 PM
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,291
some are good some are crap.
When I was an apprentice sparky I was told to never use them.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 05-19-2019, 06:54 PM
480sparky's Avatar
When they first came out, they were all crappy. I had serious, time-consuming/money-costing issues with them. I didn't use them for years. But they've gotten better now.
I still prefer wire nuts even today, but I will use these on occasion.
Seven-Delta-FortyOne (05-20-2019)
Old 05-19-2019, 07:05 PM
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
I use the ones in the Halo cans and wafer LEDs but I don't buy loose ones to use as a wire nut. I was taught to use the screws on switches and outlets and still do. My mind tells me that a can light doesn't have internal parts that move or get wear due to use like switches and outlets.
overanalyze is offline
Old 05-19-2019, 07:19 PM
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 478
Sure, right at the top of my little head.
Point is, just like backstabbing, those connectors rely on spring pressure to make the connection. Long term, springs lose force much sooner than a properly torqued threaded connection.
I prefer my work to last well beyond the taillight warranty.
The Following 5 Users Say Thank You to Tinstaafl For This Useful Post:
artinall (05-20-2019), B.Johnson (05-20-2019), Rio (05-19-2019), rrk (05-19-2019), TxElectrician (05-20-2019)
Old 05-20-2019, 05:22 AM
artinall's Avatar
Rewards Points: 618
Something to consider.
Cooper's calling them quick-connect;
http://www.cooperindustries.com/cont...s/_269408.html
Old 05-20-2019, 09:04 AM
480sparky's Avatar
Originally Posted by artinall View Post
.........Cooper's calling them quick-connect;
I don't own Cooper, so I'm not responsible for their ignorance.
Old 05-20-2019, 11:14 AM
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,040
But they do connect quickly.
I agree with 480, when they first came out they universally sucked.
They're a little better now. I still don't use them, except for where they come already installed, like can lights.
Old 05-21-2019, 10:31 AM
VinylHanger's Avatar
Rewards Points: 11,716
Just replaced a light in the kitchen with them. If I hadn't seen this thread I would have been looking for the white nuts I must have lost.
I like them in this case. Put up light fixture, push wire in and turn it on.
This was a LED strip light. Not sure I would want them on a high wattage ceiling fan or fixture.
VinylHanger is offline
Old 05-21-2019, 11:43 AM
artinall's Avatar
Rewards Points: 618
Up in the attic I see the newer Halo won't work. This is the old Capri that I pulled. Cheap guy (QL 75ICX).
I see where I could replace the socket and rewire but the fixture lost its bulb housing mount and falls through onto the light cover. Then there is the interrupt to replace...
Open hole nearest the left is just under 1" away (edited). While inner to inner span is 22 1/2" and I'm not going to block for this. Can barely reach as it is with connections on the far side and with knees extended through truss chords, hurdling a vent pipe, wiring, etc .
Also, specs that I have found on the Capri have been scant and nowhere has it listed as moisture rated. (where trusses take a change to a right angle)
Old 05-21-2019, 01:55 PM
Trade: Highwayman
Had trouble following that post.
Are you saying the new Halo won't fit right next to the truss chord? (Most wont).
If so, use a remodel can. You can even wire it from below, so no more crawling into the attic.
Old 05-21-2019, 03:07 PM
480sparky's Avatar
Yeah............ if the original install left a couple feet of extra NM for ya..........
Seven-Delta-FortyOne (05-23-2019)
Old 05-21-2019, 03:35 PM
artinall's Avatar
Rewards Points: 618
Did a Halo remodel can, clipped in easily from below. Was about $18 with the standard can around $10.
Did have to crawl the attic however to detach for some slack on the romex so it could be pulled down through.
Used the stock connectors.
The Following 2 Users Say Thank You to artinall For This Useful Post:
overanalyze (05-21-2019), Seven-Delta-FortyOne (05-21-2019)
Old 05-23-2019, 01:34 PM
test
Trade: General
retrofit cans I don't mind the quick connects. Not much space in the box and they seem to save room.
Thread Tools
Rate This Thread
Quick Plank Replacement Tip PrecisionFloors Flooring 5 05-23-2013 07:20 PM
No Grounding Wire on Remodel Kastoria Electrical 29 03-06-2013 06:19 PM
Ground wire problem jhcontracting Electrical 24 02-18-2013 08:43 PM
welded wire fence medusa Decks & Fencing 23 10-21-2011 01:00 PM
Push In Wire Nuts Capt Electrical 12 02-22-2008 09:07 AM
