PVC Box With Steel Extender Added ? - Electrical - Contractor Talk
Old 11-14-2018, 06:33 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,196
Ran some LED lights in a garage attic, switch leg and gable vent fan.
Used 3 pvc octagon boxes for the LED's. Center box that has the above mentioned "made up" was a bit over capacity...20 cu in. needed addl space I'd say also.
I added a steel octagon 1.5" extension to the pvc box. Didn't see any pvc ext boxes.
Not sure if this is kosher or what ? I was going to tap a ground screw to the extender run a ground wire to it...?
Never have run across this so some input would be helpful.
Steve
We Fix Houses is offline
Old 11-14-2018, 08:55 PM   #2
tjbnwi's Avatar
Rewards Points: 3,062
Re: PVC Box With Steel Extender Added ?
As long as you ground the metal box you're fine.
tjbnwi is online now
Old 11-14-2018, 08:57 PM   #3
Thanks Tom
Steve
Anchoring square steel bracing to 3' steel vertical pole. ConceptCreation Construction 8 05-29-2018 06:58 PM
Has anyone used Dakota Steel? Donohue Const Roofing 31 04-13-2013 11:05 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
