Is It Possible To Split A Main Service - Electrical - Contractor Talk
Old 07-29-2020, 11:12 PM   #1
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,562
I know the title sucks,
This is what is like to know, I have 200 amp service to my property line.
From my meter I have a 100 amp line for the house. Originally I was going to trench from my house to the shop a sub panel at 50 amps.
Then I realized, it's about 80 yards closer to trench from the meter to the shop and skip the house. With the benefit of having 100 amp in the shop. (not that id ever need it).
Im not an electrician, but I imagine I can't run both services from the meter box. But I was wondering if I could install an exterior junction box on the other side of the pole and run 200 amp from the meter to the junction box, then 100 amps to the house, and 100 amps to the shop?
I'm not going to do this myself, but I'm just wanting to know if this is a legit way.
Thanks!
Sent from my SM-N960W using Tapatalk
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 07-30-2020, 12:20 AM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,978
Re: Is It Possible To Split A Main Service
Originally Posted by JT Wood View Post
....... But I was wondering if I could install an exterior junction box on the other side of the pole and run 200 amp from the meter to the junction box, then 100 amps to the house, and 100 amps to the shop?..........
Not without installing two 100a breakers to protect the two feeders.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
JT Wood (07-30-2020)
Old 08-01-2020, 03:45 PM   #3
DooWop's Avatar
Trade: Hvac
Rewards Points: 44
If your thinking of making a meter tap my understanding is it's OK but requires a meter that has this extra lug because each feed requires it's own lug. No stacking wires.
This is not necessarily current information.
When I did resi installs in the 70's-80's we often made meter taps because in a finished home access to the fuse box was sometimes difficult. But we just stacked the wires. Not allowed anymore but I think the meter box with the xtra lug is.
DooWop is offline
Old 08-01-2020, 04:09 PM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 596
My shop & house meter bases have lugs for 3 taps.
pinwheel is offline
