Pool Bonding / Grounding - Electrical - Contractor Talk
Old 04-27-2019, 11:50 PM   #1
arudam's Avatar
Trade: Paving stone
Hey all, looking for some advice on grounding / bonding my new build pool. I appoligize if im using the terms incorrect but to my knowledge grounding is say electrical appliances where as bonding is to things like the pool ladders ect?
First, i definately plan to have a qualified electrician look over everything after just trying to do as much myself as possible.
So im building a pool, built with insulated concrete forums (styrofoam concrete styrofoam) , the walls have a 6" concrete with rebar core, and the floor has a 6" concrete slab with rebar and hydronic pex floor heat lines. unfortuanetly i feel i screwed up and should have tied in some copper to the floor rebar grid to run to a ground rod (ill chissel some up if need be) I do have some rebar that protrudes out of the walls but it isnt necessarily all tied together. Im running low voltage 12v lighting, pvc water lines, and im planning on putting aluminum sheets on the inside of the pool walls for strength between the liner and styrofoam. My pump house will be about 10ft from the pool.
What would be the best way to bond / ground the setup here?
should i pound a ground rod and run seperate 8 guage copper to each electrical appliance like my pump, salt water generator, electric boiler? Where would be the best place to put this ground rod? close or far as possible ect.
The aluminum panelling i plan to place behind the liner, should each piece be tied to the next and also grounded?
I currently have a 50amp gfi breaker from my old hottub ill be using, would it be a good idea to install a seperate sub panel after this, inside my pump house and maybe run a individual GFI breaker for each appliance, pump ect?
I appreciate any advice, id rather go overboard then not enough!!
arudam is offline
Old 04-27-2019, 11:53 PM   #2
arudam's Avatar
Trade: Paving stone
Re: Pool Bonding / Grounding
few photos
Pool bonding / grounding-screenshot_20190427-235140_gallery_1556427161448.jpg   Pool bonding / grounding-screenshot_20190427-235150_gallery_1556427187233.jpg
arudam is offline
Old 04-28-2019, 08:01 AM   #3
TimNJ's Avatar
Rewards Points: 5,696
Why put the aluminum on the walls?
My walls were plastic and when I had a new liner installed I had them put thin foam layer on the walls before they put the liner in.
TimNJ is offline
Old 04-28-2019, 08:37 AM   #4
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,651
My suggestion would to get a qualified sparky in there BEFORE you do anything else. Not only will it be done the best (cost effective) way, but more importantly the correct and SAFE way. My $.02
rescraft is offline
The Following 2 Users Say Thank You to rescraft For This Useful Post:
Fouthgeneration (04-28-2019), TxElectrician (04-29-2019)
Old 04-28-2019, 09:20 AM   #5
arudam's Avatar
Trade: Paving stone
The aluminum panels are to protect the styrofoam as well as the liner from certain spots of exposed concrete, as well as to attach my return jets and lights to, plus it will give a much better feel by touching the liner rather than someone poking it and it leaving a forever imprint
arudam is offline
Old 04-28-2019, 09:34 AM   #6
arudam's Avatar
Trade: Paving stone
I can accept that opinion and i likely will. But it would still be nice to have more opinions and suggestions i could bring up to bounce of the guy rather than just listening to him, some guys can bull**** alot just to get your money!
arudam is offline
Old 04-28-2019, 10:40 AM   #7
hdavis's Avatar
Rewards Points: 2,362
The very first thing to do is find out what the manufacturer's installation requirements are.
The NEC requirements are generally pretty straight forward.
hdavis is offline
Old 04-28-2019, 10:55 AM   #8
arudam's Avatar
Trade: Paving stone
Im the manufacturer lol its not a standard pool there isnt any recommendations on it that i found prior ( main reason i havnt taken care of this prior)
The equipment pumps, salt generator ect simply requires a ground rod
arudam is offline
Old 04-28-2019, 02:38 PM   #9
TimNJ's Avatar
Your jets, skimmers, lights, and any pipe should have already been set prior to your pour. Then when you put the liner in you fasten the trims to the other half of the jet, skimmer, light. That's what holds them in place.
How do you plan on fastening the metal to the ICF?
TimNJ is offline
Old 04-28-2019, 02:42 PM   #10
TimNJ's Avatar
When I did my pool in '06 all metal had to have one continuous ground. Ladders, hand rails, rebar.
TimNJ is offline
Old 04-28-2019, 02:55 PM   #11
arudam's Avatar
Trade: Paving stone
The metal would fasten mostly at the top rim and then a few random spots on the drywall strips in the icf (water pressure would hold the bottom later). When i poured the concrete i notched out the upper 2" on the inside for the purpose of a secure mount point for both the liner track and the metal sheeting. I built large 8" pipe pockets so i could easily get my hands in to mount lights and returns afterwards. if i skip the metal liner i can still just put caps on my pockets to mount return jets/lights. the skimmer i installed before the pour, but the others i didnt so it would be easier to waterproof the exterior and a few different reasons (photos attached)
Pool bonding / grounding-screenshot_20190428-144811_gallery_1556481294343.jpg   Pool bonding / grounding-screenshot_20190428-144801_gallery_1556481313789.jpg
arudam is offline
Old 04-28-2019, 02:59 PM   #12
arudam's Avatar
Trade: Paving stone
Thats my issue, i know although most rebar should be, not every piece will be connected. Big mistake on my behalf trusting what i thought was a good electricians advice, and then not seeing any detail about bonding on any other persons ICF builds. i totally wasnt concerned about it prior, but now i am
arudam is offline
Old 04-28-2019, 06:57 PM   #13
hdavis's Avatar
I'm not talking about the pools, I'm talking about the pumps, salt generator, etc.
Electric and grounding requirements per manufacturer.
hdavis is offline
Old 04-28-2019, 07:31 PM   #14
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 454
This is not something you're going to get a valid definitive answer to on an internet forum.
You need someone on-site with a good understanding of the relevant NEC regulations, the devices that will be installed, and perhaps most of all well acquainted with what the local AHJ wants to see. That last one can vary widely, even though technically it shouldn't.
Bite the bullet and hire an electrician who is familiar with this sort of work, and can come up with ways to make what you have in place acceptable. Which is what you should have done before the shovel hit the dirt. Not intending to be offensive, but that's the cold truth.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Caleb1989 (04-30-2019), rescraft (04-30-2019), tgeb (04-29-2019)
Old 05-04-2019, 12:20 PM   #15
manchesterspark's Avatar
Trade: Electrical
I will second what Tinstaafl said:
Hire an electrician who is well versed in Pool Bonding!
Pool bonding is nothing to skimp on and it must be done correctly. You and your families , (not mention who ever else uses this pool) Safety is the reason for a properly bonded pool AND SURROUNDING DECK AREA
I saw a post about pumps and such only needing a ground rod ! THIS IS 100 % INCORRECT. That statement is why I am being blunt by saying hire someone who knows.
manchesterspark is offline
The Following User Says Thank You to manchesterspark For This Useful Post:
rescraft (05-04-2019)
Old 05-04-2019, 12:41 PM   #16
arudam's Avatar
Trade: Paving stone
Well I did hire a electrician to come out, a guy who had built a pool exact to mine using ICF, he said he didnt bond his and i need not worry being that it will also have a vinyl liner , low voltage lighting and gfi protected equipment. its not that there is a metal shell on the pool that could come in contact if the liner ripped. im at a loss here, My issue is that all the rebar in the pool wasnt intentionally connected and if it is its just by chance (floor to walls ect). it would be impossible for me to now bond every piece of rebar in the pool and nobody can give me an answer.
Yes that will be done
arudam is offline
The Following User Says Thank You to arudam For This Useful Post:
hdavis (05-04-2019)
Old 05-04-2019, 05:53 PM   #17
rescraft's Avatar
Maybe you and members of your family can wear sealed "survival suits" before they enter??
Seriously, get this done the CORRECT way. I think I am with the rest of us in saying, we don't want to read about this pool in the news.
No offense..............
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
rrk (05-04-2019)
Old 05-04-2019, 08:21 PM   #18
rrk's Avatar
Rewards Points: 3,484
Not that long ago they used to require grounded mesh all of the way around the pool 5 ft wide I believe.
rrk is offline
Old 05-05-2019, 09:22 AM   #19
arudam's Avatar
Trade: Paving stone
the issue is clearly nobody so far can tell me "the right way"
arudam is offline
Old 05-05-2019, 10:26 AM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 454
The issue is clearly that you are building this as a DIY project, without having done due diligence before beginning.
I'm not saying that as a put-down, just as fact. We've all done that at one time or another, though usually with projects more easily rectified than what you have in place. It may well be that the only "right way" is to tear it out and start over. But there's no way for us to say authoritatively one way or the other from behind these keyboards.
Again, you need a competent professional on-site to evaluate all the variables and take responsibility (if he can) to do whatever's necessary to make the project safe and code-compliant.
Fouthgeneration (05-05-2019)
Confirm proper grounding and bonding of a new Siemens panel 67Mustang Electrical 16 12-22-2015 08:15 AM
pool bonding natural1 Electrical 15 08-26-2015 05:59 PM
Question on compacting soil around a pool BCConstruction Masonry 14 09-26-2012 05:38 PM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 06:48 AM
