Plugs Falling Out Of Outlets - Electrical - Contractor Talk
Old 12-17-2016, 10:15 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,368
Been having this problem come up, where the plug slips out over time. When they go to vacuum, the plug keeps coming out so they're always having to stop and plug it back in.
I've been replacing them with the Leviton heavy duty outlets. They cost six dollars an outlet. I can only find them at Home Depot, I've looked at multiple places. So far they are working good, plug never falls out.
My question for the electricians is when you submit a bid, do you just assume that you'll use the cheaper ones? The kind that don't hold a plug? Or do you ever offer to instal the heavy duty kind? And have you had callbacks with the cheaper outlets because of plugs falling out?
Plugs falling out of outlets-imageuploadedbycontractortalk1482030108.170947.jpg
KennMacMoragh is offline
Old 12-17-2016, 10:36 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,652
Re: Plugs Falling Out Of Outlets
Buy P&S instead.
They will hold the CORDS in to the 'outlets' better. If your plugs are falling out, then the device is broken.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
griz (12-17-2016)
Old 12-17-2016, 10:40 PM   #3
slowsol's Avatar
Rewards Points: 2,248
I use the cheap ones. Never had that issue.
-John
slowsol is offline
Old 12-18-2016, 09:04 AM   #4
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
You will, give it time.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 12-18-2016, 09:49 AM   #5
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,553
That's why they're 49 cents instead of a couple bucks.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-18-2016, 09:51 AM   #6
slowsol's Avatar
I've had them in personal house for 10 years. How long do I need to wait?
-John
slowsol is offline
Old 12-18-2016, 10:36 AM   #7
480sparky's Avatar
News flash, everyone: EVERY receptacle will eventually get loose.
A lot depends on how often you insert and remove cords. If you do this two or three times a day (like a razor, hairdryer etc in a bathroom), it will get loose faster than the receptacle in the living room where you plug in the vacuum cleaner once a week.
And that receptacle will fail sooner than the one behind your entertainment center that you plugged your big screen into 10 years ago and covered up.
Yes, a general rule is the more you spend on a device, the longer it will last. But if you use it frequently, it will get loose. Live with it.
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
KennMacMoragh (12-18-2016), TimelessQuality (12-20-2016)
Old 12-18-2016, 11:17 AM   #8
Anti-wingnut's Avatar
Rewards Points: 3,430
If you had electricity, running water and a toilet in your house we could give you a more accurate estimate.
Anti-wingnut is offline
Old 12-18-2016, 11:53 AM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Attachment 355210
Any electrical supplier will have different grades of receptacles. Most manufacturers have standard, construction, commercial and hospital.
Inner10 is offline
Old 12-18-2016, 02:13 PM   #10
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
Am I the only person who hates the way duplex outlets look?
That outlet in your picture looks old just replace it with another one and you should get many years out of it.
Can't recall ever having to change an outlet because of it coming loose
Sent from my XP7700 using Tapatalk
SectorSecurity is offline
Old 12-18-2016, 05:40 PM   #11
slowsol's Avatar
What if I only have a toilet but no running water?
-John
slowsol is offline
Old 12-18-2016, 07:08 PM   #12
Eyeway!'s Avatar
Trade: Electrical
Rewards Points: 156
Then you'd be living in an outhouse!
Sent from my SM-G930T using Tapatalk
Eyeway! is online now
Old 12-18-2016, 09:45 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 1,928
This is why a spec sheet or very specific SOW are critical.
Without specific callouts for products you will get the POS low bid crap.
dealing with high end custom jobs high dollar stuff is automatically included.
griz is online now
Rio (12-19-2016)
Old 12-19-2016, 06:52 PM   #14
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,236
You're not the only one who hates the look of them. I had one client ask for them to be changed to pop outs
Philament is offline
Old 12-19-2016, 08:22 PM   #15
going_commando's Avatar
Trade: Electrician
Rewards Points: 256
Adorne is a pain in the butt.
Receptacles wear out. I just replace them with new resi grade that are tamper resistant. The residential grade seem to last at least 40+ years, so I don't worry about swapping them out for residential grade again.
In the US, we have residential, spec, super-spec, and hospital grade receptacles.
going_commando is offline
The Following User Says Thank You to going_commando For This Useful Post:
gr7707 (12-20-2016)
Old 12-19-2016, 08:29 PM   #16
Philament's Avatar
They are a huge pain in the backside for sure. We had to change the device boxes to double bubble to fit them in. But customer wants, customer gets unless I have a very good reason to say no.
Old 12-19-2016, 08:35 PM   #17
480sparky's Avatar
Originally Posted by griz View Post
This is why a spec sheet or very specific SOW are critical..............
For a house?
Old 12-19-2016, 09:27 PM   #18
Fire up the BBQ
griz's Avatar
For a house?
you bet....absolutely for a house....
that way there are no arguments with HO's and subs know what to supply.
I do not do it any other way........
griz is online now
Old 12-19-2016, 09:41 PM   #19
480sparky's Avatar
I guess I've been doing it wrong for 20+ years then. And I guess I'll keep doing it wrong for another 20+ years.
Never spec'd devices for a dwelling, and I don't think I ever will. I just ask the HO what color and style. I buy what they want, install it, get paid and sleep well.
Old 12-19-2016, 09:46 PM   #20
Fire up the BBQ
griz's Avatar
if what you do works for you don't change.
in my case you are not specking out devices to HO....
I am specking them out to you.....
That way I know what I am getting and can guarantee a quality job.
I work WITH my subs not against you guys....
griz is online now
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 02:58 PM
outlets not working jamestrd Electrical 42 12-24-2011 08:25 PM
Kitchen - use 20A GFCI at start w/ 15A outlets??? tmdelisle Electrical 25 07-28-2009 12:38 AM
How many outlets or recepticles on a circuit?? K2 Electrical 3 01-26-2009 01:23 AM
